    RC1 and failover problem
    4 Posts 2 Posters 1.7k Views
    • V Offline
      vielfede
      Hello,
      Just to point out the following:
      Since I updated from pfSense2.1-RC0-x64-20130624 to pfSense2.1-RC1-x64-20130812 multiwan failover does not work anymore.
      Reverting to RC0 all seems to be ok.
      Is it a bug  or there is something new to consider?
      Thank you in advance.
      FV
        phil.davis
        See this thread: http://forum.pfsense.org/index.php/topic,65231.0/all.html
        I think all these problems are related to the apinger changes.
        • V Offline
          vielfede
          @phil.davis:
          I read it…
          It could be... as on RC0 (20130624) it works...
          I have to point out another issue: proxy failover;
          On 2.1 RC0 and RC1 the configuration described in http://forum.pfsense.org/index.php/topic,60977.0.html does not work!
          as already stated by fabianoheringer
          I had to install 2.0.3 pfsense to get it work.
          • V Offline
            vielfede
            @vielfede:
            @phil.davis:
            I read it…
            [SOLVED by]
            2.1-RC1 (amd64)
            built on Thu Aug 15 16:30:12 EDT 2013
            FreeBSD 8.3-RELEASE-p9
            @vielfede:
            Workaround for failover
            See
            http://forum.pfsense.org/index.php/topic,60977.0.html thread
