    Advanced pfSense setup help. (Multi-package setup issues)
    28 Posts 4 Posters 9.5k Views
      Claw22000
      I've spent the last few days playing around with pfSense.  Absolutely love it!  This is exactly what I have been looking for.  I have an Autistic Nephew that likes to put viruses on my computers as well as watch porn (hes 12).  So a friend recommended pfSense.
      Now down to my issues.
      I installed with no hassle no problem on my old server box its a Duel Pentium 4 2.4Ghz with 2 Gigs of ram and a 20 Gig Drive.  I have a larger drive but felt this was all that was needed.
      I added the havp along with the widgets with no problems and tested it.  Awesome results!
      I installed Squid3 and got it all setup the way I like it no problem.  Set havp to Parent for Squid and all is well.
      Setup users, Captive portal, Groups, Mac Pass through for all my devices (i.e Satelite TV ect) setup my DDWRT routers as switches for the wireless. Reconfigured my IP security camera to work with the new NAT (port forwarding).  As well as my 2 slingboxes, Wii, Xbox360, cell phones and tablet.
      Needless to say I really don't want to reinstall to make my needs happen.
      With all this in mind.
      After a bit of study I installed Squidguard to use as a porn blocking tool.  followed the best instructions I could find (I read many different howtos and watched youtube vids ect).
      I could not get the squidguard to start.  I went back through all the settings, forums, howtos, youtube, google and so on.  nothing I found worked.  I then came across and old post suggesting a reboot.  Though well I'll give it a shot.  Squid3 and Squidguard would not start.  Both services were down.  I tried reinstalling the package and still would not come back up.
      I uninstalled both packages and reinstalled squid3 and its back up.
      I would really like to get a filter in for porn and a few extras I saw in the list while I was configuring Squidguard.
      If someone could please help I would really appreciate it.
      Thanks in advance for taking the time to consider my request.
      DrClaw
      DrClaw
        Gloom
        A little more info please.
        Is squid set to transparent mode
        Is there anything in the system logs when you try to start squid/squidguard
        Which interface have you got havp bound to and what port
        Never underestimate the power of human stupidity
          Claw22000
          @Gloom:
          Thats for the reply sorry I'm new to pfSense so I didn't know really where to get the best info to post.
          Squid is in transparent mode.
          havp is on LAN bound to 3125
          so I don't really know which log to get you but here is what I think I should post.
          (System Log)
          php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 00:54:55 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 00:55:05 check_reload_status: Reloading filter
          Sep 3 00:55:05 php: : Not calling package sync code for dependency squidreverse of squid3 because some include files are missing.
          Sep 3 00:55:07 php: : Starting Squid
          Sep 3 00:55:07 squid[48352]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 00:55:07 php: : The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 00:55:08 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 00:55:08 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 00:55:08 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 00:55:17 check_reload_status: Reloading filter
          Sep 3 00:55:19 php: : Starting Squid
          Sep 3 00:55:19 squid[57178]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 00:55:19 php: : The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 00:55:20 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 00:55:20 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 00:55:20 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 00:55:29 check_reload_status: Reloading filter
          Sep 3 00:55:31 php: : No pfBlocker action during boot process.
          Sep 3 00:55:32 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 00:55:32 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 00:55:32 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 00:55:36 php: : Starting Squid
          Sep 3 00:55:36 squid[5713]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 00:55:36 php: : The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 00:55:46 check_reload_status: Reloading filter
          Sep 3 00:55:47 check_reload_status: Syncing firewall
          Sep 3 00:55:49 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 00:55:49 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 00:55:49 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 00:55:49 squid[35344]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 00:55:50 php: : IPSEC: One or more IPsec tunnel endpoints has changed its IP. Refreshing.
          Sep 3 00:55:51 login: login on ttyv1 as root
          Sep 3 00:55:51 login: login on ttyv0 as root
          Sep 3 00:55:51 sshlockout[40923]: sshlockout/webConfigurator v3.0 starting up
          Sep 3 00:55:54 Squid_Alarm[49807]: Squid has exited. Reconfiguring filter.
          Sep 3 00:55:54 Squid_Alarm[50125]: Attempting restart…
          Sep 3 00:55:54 squid[51082]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:01:01 php: : DynDns: updatedns() starting
          Sep 3 01:01:01 php: : DynDns debug information: 24.118.3.142 extracted from local system.
          Sep 3 01:01:01 php: : DynDns: Current WAN IP: 24.118.3.142 Cached IP: 24.118.3.142
          Sep 3 01:01:01 php: : phpDynDNS: No change in my IP address and/or 25 days has not passed. Not updating dynamic DNS entry.
          Sep 3 01:03:33 check_reload_status: Syncing firewall
          Sep 3 01:03:33 squid[8257]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:03:38 php: /pkg_mgr_install.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:03:39 check_reload_status: Reloading filter
          Sep 3 01:03:39 php: /pkg_mgr_install.php: Beginning package installation for squid3.
          Sep 3 01:03:41 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:03:41 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:03:43 check_reload_status: Syncing firewall
          Sep 3 01:03:45 php: /pkg_mgr_install.php: Stopping any running proxy monitors
          Sep 3 01:03:46 php: /pkg_mgr_install.php: Starting Squid
          Sep 3 01:03:46 php: /pkg_mgr_install.php: Starting a proxy monitor script
          Sep 3 01:03:46 squid[22008]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:03:49 php: /pkg_mgr_install.php: Starting Squid
          Sep 3 01:03:49 squid[27244]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:03:49 php: /pkg_mgr_install.php: The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:03:51 Squid_Alarm[28799]: Squid has exited. Reconfiguring filter.
          Sep 3 01:03:51 Squid_Alarm[29134]: Attempting restart…
          Sep 3 01:03:51 squid[30102]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:03:59 check_reload_status: Reloading filter
          Sep 3 01:04:02 php: /pkg_mgr_install.php: Starting Squid
          Sep 3 01:04:02 squid[52354]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:04:02 php: /pkg_mgr_install.php: The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:04:02 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:04:03 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:04:03 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 01:04:12 check_reload_status: Reloading filter
          Sep 3 01:04:12 check_reload_status: Syncing firewall
          Sep 3 01:04:15 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:04:15 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:04:15 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 01:05:14 php: /pkg_edit.php: Starting Squid
          Sep 3 01:05:14 squid[23348]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:05:14 php: /pkg_edit.php: The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:05:24 check_reload_status: Reloading filter
          Sep 3 01:05:24 check_reload_status: Syncing firewall
          Sep 3 01:05:27 php: /pkg_edit.php: Starting Squid
          Sep 3 01:05:27 squid[28787]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:05:27 php: /pkg_edit.php: The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:05:27 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:05:27 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:05:27 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 01:05:37 check_reload_status: Reloading filter
          Sep 3 01:05:40 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:05:40 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:05:40 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 01:05:48 squid[40043]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:05:53 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 01:05:55 squid[41847]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 01:19:34 check_reload_status: Syncing firewall
          Sep 3 01:19:55 sasldblistusers2: unable to dlopen /usr/local/lib/sasl2/libgssapiv2.so.3: Shared object "libgssapi.so.10" not found, required by "libgssapiv2.so.3"
          Sep 3 01:19:55 sasldblistusers2: SQL engine 'mysql' not supported
          Sep 3 01:19:55 sasldblistusers2: auxpropfunc error no mechanism available
          Sep 3 01:19:57 check_reload_status: Syncing firewall
          Sep 3 01:19:59 php: /pkg_mgr_install.php: Starting Squid
          Sep 3 01:19:59 php: /pkg_mgr_install.php: The command '/usr/local/sbin/squid -f /usr/local/etc/squid/squid.conf' returned exit code '127', the output was '/usr/local/sbin/squid: not found'
          Sep 3 01:20:09 check_reload_status: Reloading filter
          Sep 3 01:20:09 check_reload_status: Syncing firewall
          Sep 3 01:20:11 php: : SQUID is installed but not started. Not installing "nat" rules.
          Sep 3 01:20:11 php: : SQUID is installed but not started. Not installing "pfearly" rules.
          Sep 3 01:20:12 php: : SQUID is installed but not started. Not installing "filter" rules.
          Sep 3 01:21:29 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '/usr/local/etc/rc.d/squid.sh: /usr/local/sbin/squid: not found'
          Sep 3 01:21:55 check_reload_status: Syncing firewall
          Sep 3 01:22:22 php: /pkg_mgr_install.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '/usr/local/etc/rc.d/squid.sh: /usr/local/sbin/squid: not found'
          Sep 3 01:22:23 check_reload_status: Syncing firewall
          Sep 3 01:22:23 check_reload_status: Reloading filter
          Sep 3 01:24:25 check_reload_status: Syncing firewall
          Sep 3 01:24:25 php: /pkg_edit.php: Starting HAVP
          Sep 3 01:24:26 check_reload_status: Reloading filter
          Sep 3 01:24:28 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:24:30 havp[57522]: === Starting HAVP Version: 0.91
          Sep 3 01:24:30 havp[57522]: === Mandatory locking disabled! KEEPBACK settings not used!
          Sep 3 01:24:30 havp[57522]: Running as user: havp, group: havp
          Sep 3 01:24:30 havp[57522]: Use transparent proxy mode
          Sep 3 01:24:30 havp[57522]: –- Initializing Clamd Socket Scanner
          Sep 3 01:24:30 havp[57522]: Clamd Socket Scanner passed EICAR virus test (Eicar-Test-Signature)
          Sep 3 01:24:30 havp[57522]: –- All scanners initialized
          Sep 3 01:24:30 havp[57869]: Process ID: 57869
          Sep 3 01:26:59 check_reload_status: Syncing firewall
          Sep 3 01:26:59 php: /pkg_mgr_install.php: Beginning package installation for squid3.
          Sep 3 01:28:37 check_reload_status: Syncing firewall
          Sep 3 01:28:40 php: /pkg_mgr_install.php: Stopping any running proxy monitors
          Sep 3 01:28:41 php: /pkg_mgr_install.php: Starting Squid
          Sep 3 01:28:41 php: /pkg_mgr_install.php: Starting a proxy monitor script
          Sep 3 01:28:41 check_reload_status: Reloading filter
          Sep 3 01:28:41 squid[45154]: Squid Parent: child process 45659 started
          Sep 3 01:28:43 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:28:44 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:30:14 check_reload_status: Syncing firewall
          Sep 3 01:30:14 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 01:30:14 check_reload_status: Reloading filter
          Sep 3 01:30:16 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 01:30:17 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:30:40 check_reload_status: Syncing firewall
          Sep 3 01:30:42 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 01:30:43 check_reload_status: Reloading filter
          Sep 3 01:30:45 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:30:46 php: : Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode.
          Sep 3 01:31:04 check_reload_status: Syncing firewall
          Sep 3 01:31:04 php: /pkg_edit.php: Starting HAVP
          Sep 3 01:31:07 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 01:31:07 check_reload_status: Reloading filter
          Sep 3 01:31:08 havp[27752]: === Starting HAVP Version: 0.91
          Sep 3 01:31:08 havp[27752]: === Mandatory locking disabled! KEEPBACK settings not used!
          Sep 3 01:31:08 havp[27752]: Running as user: havp, group: havp
          Sep 3 01:31:08 havp[27752]: –- Initializing Clamd Socket Scanner
          Sep 3 01:31:08 havp[27752]: Clamd Socket Scanner passed EICAR virus test (Eicar-Test-Signature)
          Sep 3 01:31:08 havp[27752]: –- All scanners initialized
          Sep 3 01:31:08 havp[28041]: Process ID: 28041
          Sep 3 01:33:02 check_reload_status: Syncing firewall
          Sep 3 01:40:40 check_reload_status: Syncing firewall
          Sep 3 01:40:47 php: /pkg_mgr_install.php: No pfBlocker action during boot process.
          Sep 3 01:40:48 check_reload_status: Reloading filter
          Sep 3 11:11:03 php: /index.php: Successful webConfigurator login for user 'claw' from 192.168.1.20
          Sep 3 11:29:12 check_reload_status: Syncing firewall
          Sep 3 11:29:12 php: /pkg_mgr_install.php: Beginning package installation for squidGuard.
          Sep 3 11:29:19 saslpasswd2: unable to dlopen /usr/local/lib/sasl2/libgssapiv2.so.3: Shared object "libgssapi.so.10" not found, required by "libgssapiv2.so.3"
          Sep 3 11:29:19 saslpasswd2: SQL engine 'mysql' not supported
          Sep 3 11:29:19 saslpasswd2: auxpropfunc error no mechanism available
          Sep 3 11:29:19 sasldblistusers2: unable to dlopen /usr/local/lib/sasl2/libgssapiv2.so.3: Shared object "libgssapi.so.10" not found, required by "libgssapiv2.so.3"
          Sep 3 11:29:19 sasldblistusers2: SQL engine 'mysql' not supported
          Sep 3 11:29:19 sasldblistusers2: auxpropfunc error no mechanism available
          Sep 3 11:30:30 check_reload_status: Syncing firewall
          Sep 3 11:30:31 check_reload_status: Reloading filter
          Sep 3 11:37:35 php: /index.php: Successful webConfigurator login for user 'claw' from 192.168.1.20
          Sep 3 12:42:02 check_reload_status: Syncing firewall
          Sep 3 12:42:05 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 12:42:05 squid[298]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 12:42:05 php: /pkg_edit.php: The command '/usr/local/sbin/squid -k reconfigure -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          Sep 3 12:42:05 check_reload_status: Reloading filter
          Sep 3 12:42:10 php: /pkg_edit.php: Reloading Squid for configuration sync
          Sep 3 12:42:10 squid[13625]: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept
          Sep 3 12:42:10 php: /pkg_edit.php: The command '/usr/local/sbin/squid -k reconfigure -f /usr/local/etc/squid/squid.conf' returned exit code '1', the output was 'FATAL: Bungled squid.conf line 4: http_port 127.0.0.1:3128 intercept Squid Cache (Version 2.7.STABLE9): Terminated abnormally.'
          (SquidGuard Filter GUI Log)
          03.09.2013 12:42:07 [squid_reconfigure] Add new redirector options to Squid config.
          03.09.2013 12:42:07 [squid_reconfigure] Remove old redirector options from Squid config.
          03.09.2013 12:42:07 [sg_reconfigure] Save squidGuard config to '/usr/local/etc/squidGuard/squidGuard.conf'.
          03.09.2013 12:42:07 [sg_redirector_base_url] Select redirector base url (http://192.168.1.1:80/sgerror.php?url=403%20&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u)
          03.09.2013 12:42:07 [sg_create_config] Add Default
          03.09.2013 12:42:07 [sg_create_config] Add ACL's: ClawAllowPass;
          03.09.2013 12:42:07 [sg_create_config] Add rewrites: safesearch;
          03.09.2013 12:42:07 [sg_create_config] Added: blk_BL_adv; blk_BL_aggressive; blk_BL_alcohol; blk_BL_anonvpn; blk_BL_automobile_bikes; blk_BL_automobile_boats; blk_BL_automobile_cars; blk_BL_automobile_planes; blk_BL_chat; blk_BL_costtraps; blk_BL_dating; blk_BL_downloads; blk_BL_drugs; blk_BL_dynamic; blk_BL_education_schools; blk_BL_finance_banking; blk_BL_finance_insurance; blk_BL_finance_moneylending; blk_BL_finance_other; blk_BL_finance_realestate; blk_BL_finance_trading; blk_BL_fortunetelling; blk_BL_forum; blk_BL_gamble; blk_BL_government; blk_BL_hacking; blk_BL_hobby_cooking; blk_BL_hobby_games-misc; blk_BL_hobby_games-online; blk_BL_hobby_gardening; blk_BL_hobby_pets; blk_BL_homestyle; blk_BL_hospitals; blk_BL_imagehosting; blk_BL_isp; blk_BL_jobsearch; blk_BL_library; blk_BL_military; blk_BL_models; blk_BL_movies; blk_BL_music; blk_BL_news; blk_BL_podcasts; blk_BL_politics; blk_BL_porn; blk_BL_radiotv; blk_BL_recreation_humor; blk_BL_recreation_martialarts; blk_BL_recreation_restaurants; blk_BL_recreation_sports; blk_BL_recreation_travel; blk_BL_recreation_wellness; blk_BL_redirector; blk_BL_religion; blk_BL_remotecontrol; blk_BL_ringtones; blk_BL_science_astronomy; blk_BL_science_chemistry; blk_BL_searchengines; blk_BL_sex_education; blk_BL_sex_lingerie; blk_BL_shopping; blk_BL_socialnet; blk_BL_spyware; blk_BL_tracker; blk_BL_updatesites; blk_BL_urlshortener; blk_BL_violence; blk_BL_warez; blk_BL_weapons; blk_BL_webmail; blk_BL_webphone; blk_BL_webradio; blk_BL_webtv; .
          03.09.2013 12:42:07 [sg_create_config] Add blacklist entries
          03.09.2013 12:42:07 [sg_create_config] Add sources: ClawAllowPass
          03.09.2013 12:42:07 [sg_reconfigure_user_db] Warning User destinations list empty.
          03.09.2013 12:42:07 [sg_reconfigure_user_db] Begin with '/var/db/squidGuard'
          03.09.2013 12:42:02 [squid_reconfigure] Add new redirector options to Squid config.
          03.09.2013 12:42:02 [squid_reconfigure] Remove old redirector options from Squid config.
          03.09.2013 12:42:02 [sg_reconfigure] Save squidGuard config to '/usr/local/etc/squidGuard/squidGuard.conf'.
          03.09.2013 12:42:02 [sg_redirector_base_url] Select redirector base url (http://192.168.1.1:80/sgerror.php?url=403%20&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u)
          03.09.2013 12:42:02 [sg_create_config] Add Default
          03.09.2013 12:42:02 [sg_create_config] Add ACL's: ClawAllowPass;
          03.09.2013 12:42:02 [sg_create_config] Add rewrites: safesearch;
          03.09.2013 12:42:02 [sg_create_config] Added: blk_BL_adv; blk_BL_aggressive; blk_BL_alcohol; blk_BL_anonvpn; blk_BL_automobile_bikes; blk_BL_automobile_boats; blk_BL_automobile_cars; blk_BL_automobile_planes; blk_BL_chat; blk_BL_costtraps; blk_BL_dating; blk_BL_downloads; blk_BL_drugs; blk_BL_dynamic; blk_BL_education_schools; blk_BL_finance_banking; blk_BL_finance_insurance; blk_BL_finance_moneylending; blk_BL_finance_other; blk_BL_finance_realestate; blk_BL_finance_trading; blk_BL_fortunetelling; blk_BL_forum; blk_BL_gamble; blk_BL_government; blk_BL_hacking; blk_BL_hobby_cooking; blk_BL_hobby_games-misc; blk_BL_hobby_games-online; blk_BL_hobby_gardening; blk_BL_hobby_pets; blk_BL_homestyle; blk_BL_hospitals; blk_BL_imagehosting; blk_BL_isp; blk_BL_jobsearch; blk_BL_library; blk_BL_military; blk_BL_models; blk_BL_movies; blk_BL_music; blk_BL_news; blk_BL_podcasts; blk_BL_politics; blk_BL_porn; blk_BL_radiotv; blk_BL_recreation_humor; blk_BL_recreation_martialarts; blk_BL_recreation_restaurants; blk_BL_recreation_sports; blk_BL_recreation_travel; blk_BL_recreation_wellness; blk_BL_redirector; blk_BL_religion; blk_BL_remotecontrol; blk_BL_ringtones; blk_BL_science_astronomy; blk_BL_science_chemistry; blk_BL_searchengines; blk_BL_sex_education; blk_BL_sex_lingerie; blk_BL_shopping; blk_BL_socialnet; blk_BL_spyware; blk_BL_tracker; blk_BL_updatesites; blk_BL_urlshortener; blk_BL_violence; blk_BL_warez; blk_BL_weapons; blk_BL_webmail; blk_BL_webphone; blk_BL_webradio; blk_BL_webtv; .
          03.09.2013 12:42:02 [sg_create_config] Add blacklist entries
          03.09.2013 12:42:02 [sg_create_config] Add sources: ClawAllowPass
          03.09.2013 12:42:02 [sg_reconfigure_user_db] Warning User destinations list empty.
          03.09.2013 12:42:02 [sg_reconfigure_user_db] Begin with '/var/db/squidGuard'
          03.09.2013 11:30:31 [squid_reconfigure] Add new redirector options to Squid config.
          03.09.2013 11:30:31 [squid_reconfigure] Remove old redirector options from Squid config.
          03.09.2013 11:30:31 [sg_reconfigure] Save squidGuard config to '/usr/local/etc/squidGuard/squidGuard.conf'.
          03.09.2013 11:30:31 [sg_redirector_base_url] Select redirector base url (http://192.168.1.1:80/sgerror.php?url=403%20&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u)
          03.09.2013 11:30:31 [sg_create_config] Add Default
          03.09.2013 11:30:31 [sg_create_config] Add ACL's: ClawAllowPass;
          03.09.2013 11:30:31 [sg_create_config] Add rewrites: safesearch;
          03.09.2013 11:30:31 [sg_create_config] Added: blk_BL_adv; blk_BL_aggressive; blk_BL_alcohol; blk_BL_anonvpn; blk_BL_automobile_bikes; blk_BL_automobile_boats; blk_BL_automobile_cars; blk_BL_automobile_planes; blk_BL_chat; blk_BL_costtraps; blk_BL_dating; blk_BL_downloads; blk_BL_drugs; blk_BL_dynamic; blk_BL_education_schools; blk_BL_finance_banking; blk_BL_finance_insurance; blk_BL_finance_moneylending; blk_BL_finance_other; blk_BL_finance_realestate; blk_BL_finance_trading; blk_BL_fortunetelling; blk_BL_forum; blk_BL_gamble; blk_BL_government; blk_BL_hacking; blk_BL_hobby_cooking; blk_BL_hobby_games-misc; blk_BL_hobby_games-online; blk_BL_hobby_gardening; blk_BL_hobby_pets; blk_BL_homestyle; blk_BL_hospitals; blk_BL_imagehosting; blk_BL_isp; blk_BL_jobsearch; blk_BL_library; blk_BL_military; blk_BL_models; blk_BL_movies; blk_BL_music; blk_BL_news; blk_BL_podcasts; blk_BL_politics; blk_BL_porn; blk_BL_radiotv; blk_BL_recreation_humor; blk_BL_recreation_martialarts; blk_BL_recreation_restaurants; blk_BL_recreation_sports; blk_BL_recreation_travel; blk_BL_recreation_wellness; blk_BL_redirector; blk_BL_religion; blk_BL_remotecontrol; blk_BL_ringtones; blk_BL_science_astronomy; blk_BL_science_chemistry; blk_BL_searchengines; blk_BL_sex_education; blk_BL_sex_lingerie; blk_BL_shopping; blk_BL_socialnet; blk_BL_spyware; blk_BL_tracker; blk_BL_updatesites; blk_BL_urlshortener; blk_BL_violence; blk_BL_warez; blk_BL_weapons; blk_BL_webmail; blk_BL_webphone; blk_BL_webradio; blk_BL_webtv; .
          03.09.2013 11:30:31 [sg_create_config] Add blacklist entries
          03.09.2013 11:30:31 [sg_create_config] Add sources: ClawAllowPass
          03.09.2013 11:30:31 [sg_reconfigure_user_db] Warning User destinations list empty.
          03.09.2013 11:30:31 [sg_reconfigure_user_db] Begin with '/var/db/squidGuard'
          03.09.2013 11:30:30 [squid_reconfigure] Add new redirector options to Squid config.
          03.09.2013 11:30:30 [squid_reconfigure] Remove old redirector options from Squid config.
          03.09.2013 11:30:30 [sg_reconfigure] Save squidGuard config to '/usr/local/etc/squidGuard/squidGuard.conf'.
          03.09.2013 11:30:30 [sg_redirector_base_url] Select redirector base url (http://192.168.1.1:80/sgerror.php?url=403%20&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u)
          03.09.2013 11:30:30 [sg_create_config] Add Default
          03.09.2013 11:30:30 [sg_create_config] Add ACL's: ClawAllowPass;
          03.09.2013 11:30:30 [sg_create_config] Add rewrites: safesearch;
          03.09.2013 11:30:30 [sg_create_config] Added: blk_BL_adv; blk_BL_aggressive; blk_BL_alcohol; blk_BL_anonvpn; blk_BL_automobile_bikes; blk_BL_automobile_boats; blk_BL_automobile_cars; blk_BL_automobile_planes; blk_BL_chat; blk_BL_costtraps; blk_BL_dating; blk_BL_downloads; blk_BL_drugs; blk_BL_dynamic; blk_BL_education_schools; blk_BL_finance_banking; blk_BL_finance_insurance; blk_BL_finance_moneylending; blk_BL_finance_other; blk_BL_finance_realestate; blk_BL_finance_trading; blk_BL_fortunetelling; blk_BL_forum; blk_BL_gamble; blk_BL_government; blk_BL_hacking; blk_BL_hobby_cooking; blk_BL_hobby_games-misc; blk_BL_hobby_games-online; blk_BL_hobby_gardening; blk_BL_hobby_pets; blk_BL_homestyle; blk_BL_hospitals; blk_BL_imagehosting; blk_BL_isp; blk_BL_jobsearch; blk_BL_library; blk_BL_military; blk_BL_models; blk_BL_movies; blk_BL_music; blk_BL_news; blk_BL_podcasts; blk_BL_politics; blk_BL_porn; blk_BL_radiotv; blk_BL_recreation_humor; blk_BL_recreation_martialarts; blk_BL_recreation_restaurants; blk_BL_recreation_sports; blk_BL_recreation_travel; blk_BL_recreation_wellness; blk_BL_redirector; blk_BL_religion; blk_BL_remotecontrol; blk_BL_ringtones; blk_BL_science_astronomy; blk_BL_science_chemistry; blk_BL_searchengines; blk_BL_sex_education; blk_BL_sex_lingerie; blk_BL_shopping; blk_BL_socialnet; blk_BL_spyware; blk_BL_tracker; blk_BL_updatesites; blk_BL_urlshortener; blk_BL_violence; blk_BL_warez; blk_BL_weapons; blk_BL_webmail; blk_BL_webphone; blk_BL_webradio; blk_BL_webtv; .
          03.09.2013 11:30:30 [sg_create_config] Add blacklist entries
          03.09.2013 11:30:30 [sg_create_config] Add sources: ClawAllowPass
          03.09.2013 11:30:30 [sg_reconfigure_user_db] Warning User destinations list empty.
          03.09.2013 11:30:30 [sg_reconfigure_user_db] Begin with '/var/db/squidGuard'
          (SquidGuard Filter Log)
          02.09.2013 18:14:48 squidGuard stopped (1378163688.008)
          02.09.2013 18:14:48 db update done
          (SquidGuard Proxy Config
          This file is automatically generated by pfSense
          Do not edit manually !
          http_port 192.168.1.1:3128
          icp_port 7
          dns_v4_first on
          pid_filename /var/run/squid.pid
          cache_effective_user proxy
          cache_effective_group proxy
          error_default_language en
          icon_directory /usr/local/etc/squid/icons
          visible_hostname proxy.OuterNet.localhost
          cache_mgr kunjmail@comcast.net
          access_log /var/squid/logs/access.log
          cache_log /var/squid/logs/cache.log
          cache_store_log none
          sslcrtd_children 0
          logfile_rotate 31
          shutdown_lifetime 3 seconds
          Allow local network(s) on interface(s)
          acl localnet src  192.168.1.0/24
          httpd_suppress_version_string on
          uri_whitespace strip
          acl dynamic urlpath_regex cgi-bin ?
          cache deny dynamic
          cache_mem 128 MB
          maximum_object_size_in_memory 5120 KB
          memory_replacement_policy heap LFUDA
          cache_replacement_policy heap LFUDA
          cache_dir ufs /var/squid/cache 14000 16 256
          minimum_object_size 0 KB
          maximum_object_size 102400 KB
          offline_mode offcache_swap_low 90
          cache_swap_high 95
          No redirector configured
          #Remote proxies
          Setup some default acls
          acl allsrc src all
          acl localhost src 127.0.0.1/32
          acl safeports port 21 70 80 210 280 443 488 563 591 631 777 901  3128 1025-65535
          acl sslports port 443 563
          acl manager proto cache_object
          acl purge method PURGE
          acl connect method CONNECT
          Define protocols used for redirects
          acl HTTP proto HTTP
          acl HTTPS proto HTTPS
          http_access allow manager localhost
          http_access deny manager
          http_access allow purge localhost
          http_access deny purge
          http_access deny !safeports
          http_access deny CONNECT !sslports
          Always allow localhost connections
          http_access allow localhost
          request_body_max_size 0 KB
          delay_pools 1
          delay_class 1 2
          delay_parameters 1 -1/-1 -1/-1
          delay_initial_bucket_level 100
          delay_access 1 allow allsrc
          Reverse Proxy settings
          Package Integration
          never_direct allow all
          cache_peer 127.0.0.1 parent 3125 0 name=havp no-query no-digest no-netdb-exchange default
          redirect_program /usr/local/bin/squidGuard -c /usr/local/etc/squidGuard/squidGuard.conf
          redirector_bypass off
          url_rewrite_children 5
          Custom options
          Setup allowed acls
          http_access allow localnet
          Default block all to be sure
          http_access deny allsrc
          (SquidGuard Filter Config)
          SquidGuard configuration file
          This file generated automaticly with SquidGuard configurator
          (C)2006 Serg Dvoriancev
          email: dv_serg@mail.ru
          logdir /var/squidGuard/log
          dbhome /var/db/squidGuard
          src ClawAllowPass {
          ip    192.168.1.20
          dest blk_BL_adv {
          domainlist blk_BL_adv/domains
          urllist blk_BL_adv/urls
          log block.log
          dest blk_BL_aggressive {
          domainlist blk_BL_aggressive/domains
          urllist blk_BL_aggressive/urls
          log block.log
          dest blk_BL_alcohol {
          domainlist blk_BL_alcohol/domains
          urllist blk_BL_alcohol/urls
          log block.log
          dest blk_BL_anonvpn {
          domainlist blk_BL_anonvpn/domains
          urllist blk_BL_anonvpn/urls
          log block.log
          dest blk_BL_automobile_bikes {
          domainlist blk_BL_automobile_bikes/domains
          urllist blk_BL_automobile_bikes/urls
          log block.log
          dest blk_BL_automobile_boats {
          domainlist blk_BL_automobile_boats/domains
          urllist blk_BL_automobile_boats/urls
          log block.log
          dest blk_BL_automobile_cars {
          domainlist blk_BL_automobile_cars/domains
          urllist blk_BL_automobile_cars/urls
          log block.log
          dest blk_BL_automobile_planes {
          domainlist blk_BL_automobile_planes/domains
          urllist blk_BL_automobile_planes/urls
          log block.log
          dest blk_BL_chat {
          domainlist blk_BL_chat/domains
          urllist blk_BL_chat/urls
          log block.log
          dest blk_BL_costtraps {
          domainlist blk_BL_costtraps/domains
          urllist blk_BL_costtraps/urls
          log block.log
          dest blk_BL_dating {
          domainlist blk_BL_dating/domains
          urllist blk_BL_dating/urls
          log block.log
          dest blk_BL_downloads {
          domainlist blk_BL_downloads/domains
          urllist blk_BL_downloads/urls
          log block.log
          dest blk_BL_drugs {
          domainlist blk_BL_drugs/domains
          urllist blk_BL_drugs/urls
          log block.log
          dest blk_BL_dynamic {
          domainlist blk_BL_dynamic/domains
          urllist blk_BL_dynamic/urls
          log block.log
          dest blk_BL_education_schools {
          domainlist blk_BL_education_schools/domains
          urllist blk_BL_education_schools/urls
          log block.log
          dest blk_BL_finance_banking {
          domainlist blk_BL_finance_banking/domains
          urllist blk_BL_finance_banking/urls
          log block.log
          dest blk_BL_finance_insurance {
          domainlist blk_BL_finance_insurance/domains
          urllist blk_BL_finance_insurance/urls
          log block.log
          dest blk_BL_finance_moneylending {
          domainlist blk_BL_finance_moneylending/domains
          urllist blk_BL_finance_moneylending/urls
          log block.log
          dest blk_BL_finance_other {
          domainlist blk_BL_finance_other/domains
          urllist blk_BL_finance_other/urls
          log block.log
          dest blk_BL_finance_realestate {
          domainlist blk_BL_finance_realestate/domains
          urllist blk_BL_finance_realestate/urls
          log block.log
          dest blk_BL_finance_trading {
          domainlist blk_BL_finance_trading/domains
          urllist blk_BL_finance_trading/urls
          log block.log
          dest blk_BL_fortunetelling {
          domainlist blk_BL_fortunetelling/domains
          urllist blk_BL_fortunetelling/urls
          log block.log
          dest blk_BL_forum {
          domainlist blk_BL_forum/domains
          urllist blk_BL_forum/urls
          log block.log
          dest blk_BL_gamble {
          domainlist blk_BL_gamble/domains
          urllist blk_BL_gamble/urls
          log block.log
          dest blk_BL_government {
          domainlist blk_BL_government/domains
          urllist blk_BL_government/urls
          log block.log
          dest blk_BL_hacking {
          domainlist blk_BL_hacking/domains
          urllist blk_BL_hacking/urls
          log block.log
          dest blk_BL_hobby_cooking {
          domainlist blk_BL_hobby_cooking/domains
          urllist blk_BL_hobby_cooking/urls
          log block.log
          dest blk_BL_hobby_games-misc {
          domainlist blk_BL_hobby_games-misc/domains
          urllist blk_BL_hobby_games-misc/urls
          log block.log
          dest blk_BL_hobby_games-online {
          domainlist blk_BL_hobby_games-online/domains
          urllist blk_BL_hobby_games-online/urls
          log block.log
          dest blk_BL_hobby_gardening {
          domainlist blk_BL_hobby_gardening/domains
          urllist blk_BL_hobby_gardening/urls
          log block.log
          dest blk_BL_hobby_pets {
          domainlist blk_BL_hobby_pets/domains
          urllist blk_BL_hobby_pets/urls
          log block.log
          dest blk_BL_homestyle {
          domainlist blk_BL_homestyle/domains
          urllist blk_BL_homestyle/urls
          log block.log
          dest blk_BL_hospitals {
          domainlist blk_BL_hospitals/domains
          urllist blk_BL_hospitals/urls
          log block.log
          dest blk_BL_imagehosting {
          domainlist blk_BL_imagehosting/domains
          urllist blk_BL_imagehosting/urls
          log block.log
          dest blk_BL_isp {
          domainlist blk_BL_isp/domains
          urllist blk_BL_isp/urls
          log block.log
          dest blk_BL_jobsearch {
          domainlist blk_BL_jobsearch/domains
          urllist blk_BL_jobsearch/urls
          log block.log
          dest blk_BL_library {
          domainlist blk_BL_library/domains
          urllist blk_BL_library/urls
          log block.log
          dest blk_BL_military {
          domainlist blk_BL_military/domains
          urllist blk_BL_military/urls
          log block.log
          dest blk_BL_models {
          domainlist blk_BL_models/domains
          urllist blk_BL_models/urls
          log block.log
          dest blk_BL_movies {
          domainlist blk_BL_movies/domains
          urllist blk_BL_movies/urls
          log block.log
          dest blk_BL_music {
          domainlist blk_BL_music/domains
          urllist blk_BL_music/urls
          log block.log
          dest blk_BL_news {
          domainlist blk_BL_news/domains
          urllist blk_BL_news/urls
          log block.log
          dest blk_BL_podcasts {
          domainlist blk_BL_podcasts/domains
          urllist blk_BL_podcasts/urls
          log block.log
          dest blk_BL_politics {
          domainlist blk_BL_politics/domains
          urllist blk_BL_politics/urls
          log block.log
          dest blk_BL_porn {
          domainlist blk_BL_porn/domains
          urllist blk_BL_porn/urls
          log block.log
          dest blk_BL_radiotv {
          domainlist blk_BL_radiotv/domains
          urllist blk_BL_radiotv/urls
          log block.log
          dest blk_BL_recreation_humor {
          domainlist blk_BL_recreation_humor/domains
          urllist blk_BL_recreation_humor/urls
          log block.log
          dest blk_BL_recreation_martialarts {
          domainlist blk_BL_recreation_martialarts/domains
          urllist blk_BL_recreation_martialarts/urls
          log block.log
          dest blk_BL_recreation_restaurants {
          domainlist blk_BL_recreation_restaurants/domains
          urllist blk_BL_recreation_restaurants/urls
          log block.log
          dest blk_BL_recreation_sports {
          domainlist blk_BL_recreation_sports/domains
          urllist blk_BL_recreation_sports/urls
          log block.log
          dest blk_BL_recreation_travel {
          domainlist blk_BL_recreation_travel/domains
          urllist blk_BL_recreation_travel/urls
          log block.log
          dest blk_BL_recreation_wellness {
          domainlist blk_BL_recreation_wellness/domains
          urllist blk_BL_recreation_wellness/urls
          log block.log
          dest blk_BL_redirector {
          domainlist blk_BL_redirector/domains
          urllist blk_BL_redirector/urls
          log block.log
          dest blk_BL_religion {
          domainlist blk_BL_religion/domains
          urllist blk_BL_religion/urls
          log block.log
          dest blk_BL_remotecontrol {
          domainlist blk_BL_remotecontrol/domains
          urllist blk_BL_remotecontrol/urls
          log block.log
          dest blk_BL_ringtones {
          domainlist blk_BL_ringtones/domains
          urllist blk_BL_ringtones/urls
          log block.log
          dest blk_BL_science_astronomy {
          domainlist blk_BL_science_astronomy/domains
          urllist blk_BL_science_astronomy/urls
          log block.log
          dest blk_BL_science_chemistry {
          domainlist blk_BL_science_chemistry/domains
          urllist blk_BL_science_chemistry/urls
          log block.log
          dest blk_BL_searchengines {
          domainlist blk_BL_searchengines/domains
          urllist blk_BL_searchengines/urls
          log block.log
          dest blk_BL_sex_education {
          domainlist blk_BL_sex_education/domains
          urllist blk_BL_sex_education/urls
          log block.log
          dest blk_BL_sex_lingerie {
          domainlist blk_BL_sex_lingerie/domains
          urllist blk_BL_sex_lingerie/urls
          log block.log
          dest blk_BL_shopping {
          domainlist blk_BL_shopping/domains
          urllist blk_BL_shopping/urls
          log block.log
          dest blk_BL_socialnet {
          domainlist blk_BL_socialnet/domains
          urllist blk_BL_socialnet/urls
          log block.log
          dest blk_BL_spyware {
          domainlist blk_BL_spyware/domains
          urllist blk_BL_spyware/urls
          log block.log
          dest blk_BL_tracker {
          domainlist blk_BL_tracker/domains
          urllist blk_BL_tracker/urls
          log block.log
          dest blk_BL_updatesites {
          domainlist blk_BL_updatesites/domains
          urllist blk_BL_updatesites/urls
          log block.log
          dest blk_BL_urlshortener {
          domainlist blk_BL_urlshortener/domains
          urllist blk_BL_urlshortener/urls
          log block.log
          dest blk_BL_violence {
          domainlist blk_BL_violence/domains
          urllist blk_BL_violence/urls
          log block.log
          dest blk_BL_warez {
          domainlist blk_BL_warez/domains
          urllist blk_BL_warez/urls
          log block.log
          dest blk_BL_weapons {
          domainlist blk_BL_weapons/domains
          urllist blk_BL_weapons/urls
          log block.log
          dest blk_BL_webmail {
          domainlist blk_BL_webmail/domains
          urllist blk_BL_webmail/urls
          log block.log
          dest blk_BL_webphone {
          domainlist blk_BL_webphone/domains
          urllist blk_BL_webphone/urls
          log block.log
          dest blk_BL_webradio {
          domainlist blk_BL_webradio/domains
          urllist blk_BL_webradio/urls
          log block.log
          dest blk_BL_webtv {
          domainlist blk_BL_webtv/domains
          urllist blk_BL_webtv/urls
          log block.log
          rew safesearch {
          s@(google../search?.q=.)@&safe=active@i
          s@(google..
          /images.q=.)@&safe=active@i
          s@(google../groups.q=.)@&safe=active@i
          s@(google..
          /news.q=.)@&safe=active@i
          s@(yandex../yandsearch?.text=.)@&fyandex=1@i
          s@(search.yahoo..
          /search.p=.)@&vm=r&v=1@i
          s@(search.live../.q=.)@&adlt=strict@i
          s@(search.msn..
          s@(.bing..*/.q=.)@&adlt=strict@i
          log block.log
          acl  {
          ClawAllowPass  {
          pass all
          default  {
          pass !in-addr !blk_BL_porn !blk_BL_redirector !blk_BL_spyware blk_BL_adv blk_BL_aggressive blk_BL_alcohol blk_BL_anonvpn blk_BL_automobile_bikes blk_BL_automobile_boats blk_BL_automobile_cars blk_BL_automobile_planes blk_BL_chat blk_BL_costtraps blk_BL_dating blk_BL_downloads blk_BL_drugs blk_BL_dynamic blk_BL_education_schools blk_BL_finance_banking blk_BL_finance_insurance blk_BL_finance_moneylending blk_BL_finance_other blk_BL_finance_realestate blk_BL_finance_trading blk_BL_fortunetelling blk_BL_forum blk_BL_gamble blk_BL_government blk_BL_hacking blk_BL_hobby_cooking blk_BL_hobby_games-misc blk_BL_hobby_games-online blk_BL_hobby_gardening blk_BL_hobby_pets blk_BL_homestyle blk_BL_hospitals blk_BL_imagehosting blk_BL_isp blk_BL_jobsearch blk_BL_library blk_BL_military blk_BL_models blk_BL_movies blk_BL_music blk_BL_news blk_BL_podcasts blk_BL_politics blk_BL_radiotv blk_BL_recreation_humor blk_BL_recreation_martialarts blk_BL_recreation_restaurants blk_BL_recreation_sports blk_BL_recreation_travel blk_BL_recreation_wellness blk_BL_religion blk_BL_remotecontrol blk_BL_ringtones blk_BL_science_astronomy blk_BL_science_chemistry blk_BL_searchengines blk_BL_sex_education blk_BL_sex_lingerie blk_BL_shopping blk_BL_socialnet blk_BL_tracker blk_BL_updatesites blk_BL_urlshortener blk_BL_violence blk_BL_warez blk_BL_weapons blk_BL_webmail blk_BL_webphone blk_BL_webradio blk_BL_webtv all
          redirect http://192.168.1.1:80/sgerror.php?url=403%20&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u
          I didn't see any log options for Squid it self.
          However I did notice durring the install of Squidguard it installed squidlight?  is this somthing that will conflict with the already installed squid3?
          Thanks so much for you help
          DrClaw
            avp
            Which version of pfSense are you using?
            Which squid pkg have you installed?
            I've fought with pf +Squid + HAVP + SG for quite some time.  I usually come out on top, but sometimes it takes time…  So I would say there is a way to get it to work, just need to work through the issues...
              Claw22000
              @avp:
              2.0.3-RELEASE (i386)
              built on Fri Apr 12 10:22:21 EDT 2013
              FreeBSD 8.1-RELEASE-p13
              Squid3 3.1.20 pkg 2.0.6
              So do I have to install the pkgs in that order?  I installed hvap then squid then SG.
              Thanks again for everyone looking in to this for me.
              DrClaw
                avp
                So right now you have squid3 running, with havp, in transparent proxy mode?  And you haven't tried to install SG again yet?
                Is that about right?
                  Claw22000
                  because the previous poster asked me about logs I installed SG again to see if I could find anything for them.  So it is installed and SG is again not running.  I'm sure if I restarted the server right now both services would be down.
                  DrClaw
                    avp
                    try SSHing into the pfsense box (You need to enable SSH under System/Advanced). ( ssh admin@ <pf ip="">or use Putty on Windows)
                    change to
                    /usr/local/etc/rc.d
                    and then
                    ./squid.sh start
                    and see if there is an error
                    (I'm on 2.1RC, but I imagine the directories would be the same…)</pf>
                      Claw22000
                      @Claw22000:
                      The first time I tried it. I got nothing.  However thats because squid was still running.  So I wen to Status > Services, and stopped the service.  Then went back to the shell and tried again.
                      This is what I got
                      FATAL: Unable to open configuration file: /usr/local/etc/squid/squid.conf: (13) Permission denied
                      CPU Usage: 0.007 seconds = 0.007 user + 0.000 sys
                      Maximum Resident Size: 1348 KB
                      Page faults with physical i/o: 0
                      Abort trap
                      I went back to the services and tried starting it there and it still won't start.
                      DrClaw
                        Claw22000
                        For lack of a better Idea I tried uninstalling the pkgs and installing them in reverse order and no that does not work.  So I will wait till I'm instructed to do something further as I am completely clueless as to what to try next.
                        Thanks to all who take the time to assist.
                        DrClaw
                          Gloom
                          Your squid.conf has an error in it. The line http_port 127.0.0.1:3128 intercept should read http_port 127.0.0.1:3128 transparent
                          If it still acts up after the change please post you squid.conf
                            avp
                            To me, it sounds like there are a couple of issues:
                            1. "Squid Cache (Version 2.7.STABLE9)" sounds like Squid v2.7 - I seem to recall, that maybe if you install SG, a certain version, it may install Squid 2.7 automatically.  This may or may not be an issue.
                            2. in the same dir as before, do "less squid.sh", paste the contents of squid.sh here.
                            3. do "find / -name squid.sh" to locate all instances of squid.conf.
                            I'm wondering if your system is trying to use squid2.7, and squid 2.7 either doesn't have a conf file, or doesn't have one configured correctly for pf.
                            4. do a "pkg_info", it will list all installed packages, paste here
                              avp
                              If there is a squid.conf at /usr/local/etc/squid/squid.conf, what are the permissions on it?
                              do an "ls -l"
                              If the file is there, paste its contents too.
                                Claw22000
                                @Gloom:
                                I have checked more that once and it is set as transparent in Services > Proxy Server.
                                I have also edited the file and changed the setting.
                                @avp:
                                @avp:
                                do an "ls -l"
                                Ok here goes (I've noticed theres an formatting command in this so I added spaces to fix this. The spaces are not in the real file just this example to prevent the site from slashin out the writing.)
                                less squid.sh
                                #!/bin/sh
                                This file was automatically generated
                                by the pfSense service handler.
                                rc_start() {
                                        if [ -z "ps auxw | grep "[ s ]quid "|awk '{print $2}'" ];then
                                fi
                                rc_stop() {
                                        /usr/local/sbin/squid -k shutdown -f /usr/local/etc/squid/squid.conf
                                Just to be sure…
                                sleep 5
                                killall -9 squid 2>/dev/null
                                killall pinger 2>/dev/null
                                case $1 in
                                        start)
                                                rc_start
                                        stop)
                                                rc_stop
                                        restart)
                                                rc_stop
                                                rc_start
                                esac
                                find: /etc/ntp: Permission denied
                                find: /var/spool/opielocks: Permission denied
                                find: /var/log/squid: Permission denied
                                find: /var/heimdal: Permission denied
                                find: /var/db/ipf: Permission denied
                                find: /var/db/freebsd-update: Permission denied
                                find: /var/db/entropy: Permission denied
                                find: /var/cron: Permission denied
                                find: /var/crash: Permission denied
                                find: /var/backups: Permission denied
                                find: /var/audit: Permission denied
                                find: /var/squid/cache: Permission denied
                                find: /tmp/lighttpdcompress/javascript: Permission denied
                                pkg_info
                                arc-5.21p          Create & extract files from DOS .ARC files
                                arj-3.10.22_4      Open-source ARJ
                                bsdinstaller-2.0.2013.0412 BSD Installer mega-package
                                clamav-0.97.5_1    Command line virus scanner written entirely in C
                                cyrus-sasl-2.1.23_3 RFC 2222 SASL (Simple Authentication and Security Layer)
                                cyrus-sasl-2.1.26_2 RFC 2222 SASL (Simple Authentication and Security Layer)
                                db41-4.1.25_4      The Berkeley DB package, revision 4.1
                                gettext-0.18.1.1    GNU gettext package
                                havp-0.91_1        HTTP Antivirus Proxy
                                lha-1.14i_6        Archive files using LZSS and Huffman compression (.lzh file
                                libiconv-1.14      A character set conversion library
                                libltdl-2.4.2      System independent dlopen wrapper
                                libwww-5.4.0_4      The W3C Reference Library
                                openldap-client-2.4.31_1 Open source LDAP client implementation
                                openldap-client-2.4.35 Open source LDAP client implementation
                                perl-5.14.2_3      Practical Extraction and Report Language
                                perl-threaded-5.12.4_4 Practical Extraction and Report Language
                                sqlite3-3.7.17_1    SQL database engine in a C library
                                squid-2.7.9_4      HTTP Caching Proxy
                                squid-3.1.20        HTTP Caching Proxy
                                squidGuard-1.4_4    A fast redirector for squid
                                unzoo-4.4_2        A zoo archive extractor
                                ls -l
                                total 318
                                -rw-r-----  1 proxy  proxy    419 Sep  3 20:06 cachemgr.conf
                                -r--r--r--  1 proxy  proxy    419 Jun 19  2012 cachemgr.conf.default
                                -rw-r-----  1 proxy  proxy    1547 Sep  3 20:10 errorpage.css
                                -r--r--r--  1 proxy  proxy    1547 Jun 19  2012 errorpage.css.default
                                drwxr-xr-x  81 proxy  proxy    3072 Sep  3 20:10 errors
                                drwxr-xr-x  2 proxy  proxy    1024 Sep  3 20:09 icons
                                -r--r--r--  1 proxy  proxy  30845 Jun 19  2012 mib.txt
                                -rw-r-----  1 proxy  proxy  11651 Sep  3 20:06 mime.conf
                                -r--r--r--  1 proxy  proxy  11651 Jun 19  2012 mime.conf.default
                                -rw-r-----  1 proxy  proxy    421 Sep  3 20:10 msntauth.conf
                                -r--r--r--  1 proxy  proxy    421 Jun 19  2012 msntauth.conf.default
                                -rw-r-----  1 proxy  proxy    2003 Sep  3 20:04 squid.conf
                                -r--r--r--  1 proxy  proxy    2425 Jun 19  2012 squid.conf.default
                                -r--r--r--  1 proxy  proxy  208245 Jun 19  2012 squid.conf.documented
                                -rw-r--r--  1 proxy  proxy  11136 Sep  3 20:08 squidGuard.conf
                                -rw-r--r--  1 proxy  proxy    1616 Jun 10 13:03 squidGuard.conf.sample
                                I have noticed the squid it self is working now that I reinstalled them in reverse order.  I can stop and start squid with no problems now.
                                Just need to get that squidguard working now.
                                Thanks so much for all the attention to my issues guys.
                                so whats next?
                                DrClaw
                                DrClaw
                                  avp
                                  ok, so as you can see, there are 2 squid pkgs installed.  This may or may not be a problem.  I'd be inclined to uninstall the 2.7 one…
                                  Are you actually running from a shell, or are you using the Execute shell command from the gui?  The reason I ask, is that if you are logged into the box via SSH, you would/should have root access, and you shouldn't see so many permissions denied msgs.  This is what you want to do, SSH in, use putty for Windows, or SSH on *nix variants...
                                  In the squid gui config page, closer to the bottom, Custom settings, Integrations, you will see this:
                                  you can try this from the shell to see if you can manually run SG.  report any errors.
                                    Claw22000
                                    @avp:
                                    I am using putty.  I used to run a BBS software on telnet so me and my friend could play some old BBS games we liked.
                                    I will try this and report what happens.
                                    Again Thanks so much!
                                    DrClaw
                                      Claw22000
                                      @avp:
                                      How do I uninstall just the 2.7 version?
                                      I think the issue with the shell was I was logged in as my own user.  In *nix varians I was taught to always login as a secondary user and only use root, or in this case Admin, for those rare occasions you absolutely need to.
                                      Ok so heres what happened.
                                      I ran that code and waited for quite a long time and the it just sat there. So I went in to the GUI and it says started!  tried surfing too redtube dot com and playboy dot com and it didn't block either one.  Went in and told it to download the block list from shallalist it completed successfully.  check to see if the right blocks were still there.  They were.  saved, and applied changes.  Surfed to the two sites again and still able to go there.
                                      So it shows its up.  But its not working.
                                      Is this due to having 2 installs of Squid?
                                      if so how do I remove just one 1?
                                      DrClaw
                                        Claw22000
                                        I know its tacky to reply 2 times let alone 3 on your own question, but I just tested it and notice it was blocking the sites I listed previously.  So I guess what needs to be done next is just uninstall the older version of squid, and make the needed changes so if power fails or for some reason I need to power down the box to move it I can.  At lease without having to manually enter that every time.
                                        Again Thanks so much for all the help everyone!
                                        DrClaw
                                          avp
                                          Once you have the full name with pkg_info, you can delete with pkg_delete.
                                            Claw22000
                                            @avp:
                                            I will get right on that after work.
                                            How do I make the change permanent?
                                            I don't want to have to manually start SG every time.
                                            DrClaw
                                            DrClaw
