    Advanced pfSense setup help. (Multi-package setup issues)
    28 Posts 4 Posters 8.9k Views
      Gloom
      Once everything is installed and configured correctly SquidGuard will start when squid launches.
      I'm curious, did both versions of squid show on the installed packages page?
      Never underestimate the power of human stupidity
        kejianshi
        I would have kept squid stable and dumped the other squids…
        Then I'd have backed up settings.
        wiped the box and reinstall.
        Then restore settings, check my squid settings...  Apply them again just to be sure.
          Claw22000
          @avp:
          Once you have the full name with pkg_info, you can delete with pkg_delete.
          I tried this and got the following response.
          pkg_delete squid-2.7.9_4
          pkg_delete: package 'squid-2.7.9_4' is required by these other packages
          and may not be deinstalled:
          squidGuard-1.4_4
          In packages it only shows the squid3.
          @kejianshi:
          I like this concept.  But I'm concerned that I will end up with the same problem.  Installing again will end up with the same packages.  I really wish it would not install the older squid automatically.
          If I do undertake this huge task (It was a 3 day ordeal last time to get it exactly like I like it) how do I backup the settings and be sure they will retake? I ask this mainly because if I reinstall I will probably just use the older squid because of obvious reasons.  Will these setting work on the older squid?
          Thanks for everyones help!
          DrClaw
          DrClaw
            kejianshi
            Ordeals with squid shouldn't be longer than 5 minutes.
            It easy to reload pfsense from nothing.  Also easy to rebuild squid cache and restart it.
            Delete all the packages you don't want.  Install the ones you do want.  Save the config even if squid seems broken.
            Wipe the box, reload your pfsense.  Restore your backup of configs.
            You might then have to issue command to rebuild squid cache.
            No biggie.
              avp
              Ok.  There are 5 pkgs for Squid and SG.
              • Squid
              • Squid3
              • SquidGuard
              • squid3-dev
              • squidGuard-squid3
              There are quite a few combinations a user could try.  Then throw in 2.0, and 2.1.
              I have these installed on 2.1:
              • squid3-dev
              • squidGuard-squid3
              I also have HAVP installed.  It has taken me days to get it working.
              Maybe you can fix any squid issue in 5 minutes.  Some of us can't.
              All I'm saying is that depending on your version and the pkgs you choose, plus other pkgs that may have an effect, it isn't always easy to get Squid + SG working.
              DrClaw, do you have things under control now?
                kejianshi
                Well - Since squid is required for squid-guard….
                I'd probably uninstall squid guard, then squid, not the other way around.
                If its too painful to touch it, then you have answered your own question.  Live with it.
                  Claw22000
                  I believe so.  its all working.  just can't uninstall squid 2.  don't know if the changes are perm out not.  typing from my phone.  haven't had much time last few days'Monday us the next day I'll have time today with it.
                  I'll reboot then and  see if it starts automatically.
                  thanks
                  Dr claw
                  DrClaw
                    Claw22000
                    It would appear that all is well.  I halted the system waited 30 seconds powered it back on an were a go.  Everything came up.  Guess I will live with it for now.  Hope they fix the problem with it installing the additional package when its not needed.
                    Is there a place I should post this as a bug to let the SG or Squid package makes know?
                    Thanks again for all the help.
                    DrClaw
                    DrClaw
