I need help - HAVP is running, but not checking
Hi guys,
HAVP is driving me crazy. I am not able get it working. Does anybody of you see a chance to help me?
First I installed only HAVP and I thought this would be enough. Since HAVP stands for "Antivirus Proxy", I thought I do not need squid. But it simply did not work. Then I installed squid3 and somehow it started working.
But now I made a reboot and something haeppened. I am not able to get HAVP running properly. Websites are browsable, but if I download the eicar-testfile nothing happens. The antivirus proxy is simply not checking the files.
I tried all the settings, but nothing worked. I tried the "transparent" and the "parent for squid" modes, but the did not the trick. Then I uninstalled and reinstalled the packages -> with no success.
I am getting nuts. Please help me.
keinstein
Oct 20 14:44:30 havp[16304]: Use transparent proxy mode Oct 20 14:44:30 havp[16304]: --- Initializing Clamd Socket Scanner Oct 20 14:44:30 havp[16304]: Clamd Socket Scanner passed EICAR virus test (Eicar-Test-Signature) Oct 20 14:44:30 havp[16304]: --- All scanners initialized Oct 20 14:44:30 havp[16437]: Process ID: 16437 Oct 20 14:44:45 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:44:50 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '2013/10/20 14:44:45| aclParseIpData: unknown netmask '0.047109690603708' in '0.57.32.80/0.047109690603708' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.019 seconds = 0.013 user + 0.006 sys Maximum Resident Size: 6040 KB Page faults with physical i/o: 0' Oct 20 14:44:57 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:45:02 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '2013/10/20 14:44:57| aclParseIpData: unknown netmask '0.047109690603708' in '0.57.32.80/0.047109690603708' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.020 seconds = 0.013 user + 0.007 sys Maximum Resident Size: 6272 KB Page faults with physical i/o: 0' Oct 20 14:45:04 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:45:15 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:45:20 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '2013/10/20 14:45:15| aclParseIpData: unknown netmask '0.047109690603708' in '0.57.32.80/0.047109690603708' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.019 seconds = 0.013 user + 0.006 sys Maximum Resident Size: 6124 KB Page faults with physical i/o: 0' Oct 20 14:45:22 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:49:22 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:49:27 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '2013/10/20 14:49:22| aclParseIpData: unknown netmask '0.047109690603708' in '0.57.32.80/0.047109690603708' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.019 seconds = 0.019 user + 0.000 sys Maximum Resident Size: 5468 KB Page faults with physical i/o: 0' Oct 20 14:49:29 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:50:06 php: /pkg_edit.php: Starting Squid Oct 20 14:50:06 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Oct 20 14:50:06 php: /pkg_edit.php: The command '/usr/pbi/squid-amd64/sbin/squid -f /usr/pbi/squid-amd64/etc/squid/squid.conf' returned exit code '1', the output was '2013/10/20 14:50:06| aclParseIpData: unknown netmask '0.047109690603708' in '0.57.32.80/0.047109690603708' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.57.32.80/0.047109690603708 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.023 seconds = 0.023 user + 0.000 sys Maximum Resident Size: 5540 KB Page faults with physical i/o: 0' Oct 20 14:50:16 check_reload_status: Reloading filter Oct 20 14:50:20 check_reload_status: Syncing firewall Oct 20 14:50:22 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:50:22 php: rc.filter_configure_sync: SQUID is installed but not started. Not installing "nat" rules. Oct 20 14:50:22 php: rc.filter_configure_sync: Adding TFTP nat rules Oct 20 14:50:22 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:50:23 php: rc.filter_configure_sync: SQUID is installed but not started. Not installing "pfearly" rules. Oct 20 14:50:23 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:50:23 php: rc.filter_configure_sync: SQUID is installed but not started. Not installing "filter" rules. Oct 20 14:50:23 php: /pkg_edit.php: Starting Squid Oct 20 14:50:23 squid[41282]: Squid Parent: child process 41427 started Oct 20 14:50:27 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:50:27 php: rc.filter_configure_sync: Adding TFTP nat rules Oct 20 14:50:27 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:50:27 php: rc.filter_configure_sync: Havp: Squid is already configured as transparent proxy. Use 'Standard' proxy mode. Oct 20 14:54:20 squid[41282]: Squid Parent: child process 41427 exited with status 0 Oct 20 14:54:21 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '' Oct 20 14:54:23 squid[5530]: Squid Parent: child process 5785 started Oct 20 15:03:14 check_reload_status: Syncing firewall Oct 20 15:03:16 php: /pkg_edit.php: Starting HAVP Oct 20 15:03:20 php: /pkg_edit.php: Reloading Squid for configuration sync Oct 20 15:03:20 havp[43620]: === Starting HAVP Version: 0.91 Oct 20 15:03:20 havp[43620]: === Mandatory locking disabled! KEEPBACK settings not used! Oct 20 15:03:20 havp[43620]: Running as user: havp, group: havp Oct 20 15:03:20 havp[43620]: --- Initializing Clamd Socket Scanner Oct 20 15:03:20 havp[43620]: Clamd Socket Scanner passed EICAR virus test (Eicar-Test-Signature) Oct 20 15:03:20 havp[43620]: --- All scanners initialized Oct 20 15:03:20 havp[43950]: Process ID: 43950 Oct 20 15:03:21 check_reload_status: Reloading filter Oct 20 15:03:26 php: rc.filter_configure_sync: Adding TFTP nat rules Oct 20 15:03:33 php: rc.filter_configure_sync: Adding TFTP nat rules ```      -
two other screenshots..
as I said, I am getting nuts. Now, after a while, it seems to be working and I do not know why. After maybe 15 minutes it suddenly started checking the files.
Can anybody check my settings in the screenshots? Did I configure the package correctly?
keinstein
Hi guys. I do not know, if anybody is out there.
Anyway, I made a reboot and HAVP stopped working.
This is what I found in the syslog:
Oct 20 21:15:44 havp[34823]: === Mandatory locking disabled! KEEPBACK settings not used! Oct 20 21:15:44 havp[34823]: Running as user: havp, group: havp Oct 20 21:15:44 havp[34823]: --- Initializing Clamd Socket Scanner Oct 20 21:15:56 clamd[45503]: Can't open file or directory Oct 20 21:15:58 havp[49172]: === Starting HAVP Version: 0.91 Oct 20 21:15:58 havp[49172]: === Mandatory locking disabled! KEEPBACK settings not used! Oct 20 21:15:58 havp[49172]: Running as user: havp, group: havp Oct 20 21:15:58 havp[49172]: --- Initializing Clamd Socket Scannerand
Oct 20 21:46:13 php: /index.php: Successful login for user 'admin' from: 192.168.222.22 Oct 20 21:46:34 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.121.65.51/0.20866550354197 Oct 20 21:46:39 php: /status_services.php: The command '/usr/local/etc/rc.d/squid.sh stop' returned exit code '1', the output was '2013/10/20 21:46:34| aclParseIpData: unknown netmask '0.20866550354197' in '0.121.65.51/0.20866550354197' FATAL: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.121.65.51/0.20866550354197 Squid Cache (Version 3.1.22): Terminated abnormally. CPU Usage: 0.019 seconds = 0.013 user + 0.006 sys Maximum Resident Size: 6080 KB Page faults with physical i/o: 0' Oct 20 21:46:42 squid: Bungled squid.conf line 22: acl localnet src 192.168.222.0/24 0.121.65.51/0.20866550354197 -
I have the same problem
I get the same message
You can scan files through a graphical interfaceHere is my message
http://forum.pfsense.org/index.php/topic,67949.0.html
I searched the forum and I got another message
Where someone specifies what action he did and fix the problemhttp://forum.pfsense.org/index.php/topic,58254.msg311939.html#msg311939
I have not tried because I do not know it will fit
2 keinstein
You can't use 2 proxies at the same time as transpared.
You must cascade it.
For example use HAVP option Proxy mode = Paren for Squid. -
@dversg: well, that makes sense.
@rest: I found a solutition: I am sorry, but pfsense had its chance. Maybe it has been my fault, but in the end i spent too much time in this. I was even that far to buy an commercial product. Finally I tried ipfire and I am surprised how easy it was to install and activate the squidproxy. I think pfsense is a very good piece of software, but in my case it did not work.
