    Need advice on a pfsense box
    60 Posts 10 Posters 28.7k Views
      super_8
      @Fevan:
      I figured since you mentioned you were installing 2x2TB WD reds,  you would be using it for other reasons other then pfsense.
      I see pfsense system requirements is it takes 1gig hdd space anyhow so a 4tb is kinda overkill to the max.
      if am wrong someone would correct me however!
      well first of you got the size wrong it's 1TB not 2 :P, but the only reason why i chose those disks is because they are supposed to be for 24/7 operation, and like you said i don't need space but 1tb is the smallest from the red version even any other brad of HDDs don't go lower then 250GB (unless you mean ssd disks)
      the reason why i said 2 is because i was thinking of setting them up in RAID.
      but i have been thinking about getting the HP ProLiant ML310 server for the box, it would only cost a bit more. but i don't know if it supports pfsense and it has intel Vpro which i would rather stay away from.
        asterix
        Go for a 1155 system. i3 with 8GB is perfect.
        • F Offline
          Fevan
          yes on the 1tb,  I still feel its total overkill for pfsense,  more so with 2 x 1tb in raid and then installing a 1gig program on it.
          If your desperate for nas class drives why not get this instead ?
          http://www.storagereview.com/wd_red_25_1tb_hdd_review_wd10jfcx
          Its smaller and more energy efficient and server/nas class.
          But yeah I guess with raid setup you can enjoy it even if one dies you could mirror it,  I get what you are trying to do and its still a good idea perhaps more costly though…
          The hp servers are good,  more so if you can get cash back offers on them and pick them up cheaply...
          Still a good set of hardware is good and future proof.  I don't think I can go with intel cpus their low end to mid end cpus don't support AES which is important to my pfsense build I have in mind,  I need something future proof to work with VPNs
          You could if your bb connection is not overall powerful try a test run on an old pc and see how it works out before leaping on am expensive purchase,  just to get the feel and speed of it.....
            super_8
            @Fevan:
            The hp servers are good,  more so if you can get cash back offers on them and pick them up cheaply…
            well for the moment i think i will go with the haswell build any i3 CPUs or the hp server looks like a total overkill for what i need and i also imagine the server makes loud fan noise which could turn out to be anoying.
            i just dont wanna mess up and get equipment that will keep crashing because it's not made for 24/7 stable running (server equipment)
            The AES support is for:
            Sandy bridge: all from i5 up
            Ivy bridge: all from i5 up and some i3
            Haswell: all except Pentium and Celeron
            so if you plan to do a haswell build you can just get an i3.
              Applied
              @super_8:
              And didn't people have problems with SSDs because they started dying after a few months?
              Some people have these problems.
              The ones who use cheap & crappy consumer SSD.
              Very few do have any problems with reliable SSD from reputable manufacturers (think: Intel, Samsung).
              Again: Don't choose their bleeding edge consumer series, and don't let yourself fooled by maximum transfer rates
              SSD wear is a very overrated problem.
              @super_8:
              well i prefer WD HDDs and i chose the wd red because it's designed for 24/7 operation and 1tb is the smallest they got.
              Mechanical hard drives are way more likely to fail than a reliable SSD, in my experience.
              I'd believe there might be a greater variance amongst SSD models / manufacturers.
              While some bad SSD might be more prone to fail than mechanical HDD, good SSD tend to have lower failure/return rates (than any mechanical HDD).
                super_8
                @Applied:
                @super_8:
                i don't know there are a lot of topics here on how SSD disks have failed, i still think a NAS HDD will last longer since it's designed for that type of use + for the price of a quality SSD i can get 2 HDDs.
                  Applied
                  @super_8:
                  I beg to differ.  ;)
                  From my own job experience.
                  And from any sane stats that I can find on the internet.
                  @super_8:
                  The 3.5" is the smallest 3.5" they got (there's a 750GB 2.5").
                  By the way, if you're hell-bent on getting mechanical HD from Western Digital  ;)  and the 1TB is just "the smallest they got", maybe you'd like to consider the WD Re series?
                  The 250GB Re should be about the same price as the Red - though it is slightly louder at up to 30dba and seems to use a little bit more power, it is advertised as having better reliability - and has the longer warranty to boot:
                  Target market:
                  WD Red: "Designed and tested for small scale RAID environments / Personal/Small Office Home Office"
                  WD Re: "Durable capacity storage for high-availability deployments / Medium-Large scale Enterprises"
                  MTBF (hours):
                  WD Red: 1,000,000
                  WD Re: 1,200,000
                  Non-recoverable read errors per bits read:
                  WD Red: <1 in 10^14
                  WD Re: <10 in 10^16
                  Warranty:
                  WD Red: 3 years
                  WD Re: 5 years
                  WD Red: http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-771442.pdf
                  WD Re: http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-771444.pdf
                    super_8
                    @Applied:
                    @super_8:
                    I beg to differ.  ;)
                    @super_8:
                    By the way, if you're hell-bent on getting mechanical HD from Western Digital, and the 1TB i just "the smallest they got", maybe you'd consider the WD Re series?
                    Target market:
                    MTBF (hours):
                    WD Red: 1,000,000
                    WD Re: 1,200,000
                    WD Red: <1 in 10^14
                    WD Re: <10 in 10^16
                    Warranty:
                    WD Red: 3 years
                    WD Re: 5 years
                    The 250GB Re should be about the same price as the Red - though the first is a bit louder at 30dba and seems to use a little bit more power.
                    Hmm..weird, didn't look at the MTBF for the HDD-s but it seems low, in that you are right the samsung 840 ssd claims to have MTBF of 1.5 million.
                    I don't have much experience with SSD disks but i have HDDs that were used a lot and are over 10 years old and they still work without a problem, but they are loud when the head is moving :P
                      Applied
                      @super_8:
                      So your 10+ year old HDDs have been alive and kicking for longer than SSDs have even been on the market at all?
                      Well, these sure don't make for a good comparison. ;D
                      (PS: Just saying… I don't mean this as an argument for or against anything)
                        super_8
                        @Applied:
                        @super_8:
                        I probably should of said that They were used in a pc system, so they weren't running heavy 24/7, if they were they would die years ago :)
                          super_8
                          I was thinking of getting the Corsair http://www.corsair.com/cmx8gx3m2a1333c9.html or kingston value http://www.kingston.com/dataSheets/KVR13N9S8K2_8.pdf.
                          are those any good or should i get a different brand?
                          • F Offline
                            Fevan
                            Regarding my haswell choice and core i3,  I think its too costly and not worth myself going down intel route.
                            An AMD build I can literally pick up the mobo +cpu for under £100 even and can't argue with a 4ghz (65watt) cpu (dual core) with AES Support and 1xpci express 4x and 16x slot.  An 364 hp intel quad Nic for £40-50 can be had also from ebay.  I will custom build it so its using a large silent heatsink + fan and a silent 92% energy efficient p/s.
                            Regarding the SSDs,  agree with other poster who mentioned intel or Samsung for reliability factor…. many people on forums still selling there ones after 3-4 years.
                            We can assume in 3-4 years also technology will be so small and energy efficient to the point our current Pc builds require binning ;)
                            It is tricky to get the hardware right to strike a balance between energy efficiency and price.
                            One could look at this new haswell/dual nic/100% silent and 35watt build that came out today:
                            http://www.atlastsolutions.com/fanless-thin-mini-itx-pc-core-i7-haswell-8gb-128gb-ssd-asus-q87t/
                            But then who knows if pfsense will support those nics,  most likely realtek anyhow so best to avoid.
                            You have this also:
                            https://www.amazon.co.uk/Shuttle-DS61-Barebone-Socket-SODIMM/dp/B00BFOFA78
                            pfsense works and supports these nics,  but then the cpu needs to be put in separate some guys use a celeron low power or xeon but this adds to the cost.
                            Guess the pfsense builds are endless you just need one and once set up hide it away,  you see people on here using p3 and p4 high electricity builds just running 24/7,  but they not fussed you get reliability and all the features and support that puts even the best router on the market today to shame (apart from pfsense wireless side,  routers still beat it for that)
                              super_8
                              whatever works out for you :)
                              Personaly i rather stay away from AMD CPUs + you can get a i3+mobo for only a bit over £100
                              • F Offline
                                Fevan
                                You can but not with AES support ;)
                                I do actually have an core i5 3.2ghz/AES and micro ATX already which would be good for a pfsense build but that cpu is 95watts.
                                Its that balance once again….
                                  jasonlitka
                                  @Fevan:
                                  One of those is an Intel i217 and the other is a Realtek 8111G.  Neither are going to work with pfSense until it moves to FreeBSD 10.
                                  Do yourself a favor and stick with Ivy Bridge.  The slightly lower idle power consumption and slightly better performance per clock of Haswell isn't worth the hassle of compatibility problems.
                                  I can break anything.
                                    super_8
                                    @Jason:
                                    @Fevan:
                                    or you can just buy seperate nic cards and you don't have to use the onboard one, speaking of which will a pcie x1 nic work in a pcie x16 (graphics card) slot?
                                    • F Offline
                                      Fevan
                                      yes it will work
                                      http://forums.anandtech.com/showthread.php?t=2218693
                                      looking at some benchies the amd cpu I liked is pretty poor performer,  so you were right to suggest intel cpus.
                                      May just stick with my core i5 sandy set and transplant to a micro atx case after all :)
                                      Good info on the ivy cpus was not aware of that….
                                        super_8
                                        well i will go with the pentium, 1150, 8gig corsair 1333 and a ssd, it's more then enough for what i need :)
                                        As for the i5, i don't think it uses a lot when it's not under load.
                                        • F Offline
                                          Fevan
                                          yeah was concerned with the power,  but they do not use that much thanks to the speed step and power efficiency :)
                                          Pentium/1150/8gig and ssd sounds great.
                                            midacts
                                            Sorry to resurrect an old thread but did you has well build work for you? I was looking at building something similar but with an i3 4330t because its 35w with aes-ni.
                                            I'm afraid a haswell board is going to have problems working with pfsense 2.1. it looks like it may be a while before v2.2 comes out.
