Problem with vlan id between pfsense and switch
Hi
I have a problem with my pfsense setup.
I have created 4 vlans(2,3,4 and 5) on the switch and ind the firewall.
I have then tagged the vlans on the switch port 1 and the untagged port 2 with vlan 2 and so on.
If I then connect my computer to vlan 2 I get the dhcp address of vlan 3, and when I connect to 3 I get vlan 4.I have tried connecting the firewall to 2 different switches d-link and Hp 1910, and I'm getting the error on both.
I'm running pfsense 2.1.
on pfsense go to assign under interfaces and make sure what you want is what you have under interface assignments.
