Small NAT problem. (1way ping only) LAN-to-OPENVPN
Hello,
I am having a little problem connecting site-to-site my PBX in my data center & my pfsense at home with openvpn.
PBX (10.8.2.1) <====> (10.8.2.2) Pfsense at home <====> (192.168.7.0/24) LAN subnet.
I have a small piece of voip equipment (192.168.7.8) that needs to connect the PBX, in a layer2 , so that they can talk back & forward.
Due to my IP situation (No public IP's at home) I opted for a static shared key setup, where the PBX at my data center is uring it's static IPv4 to provide an OPENVPN server, & my home pfsense is used as an OPENVPN client.
So far, there is nothing magic, my pfsense connects fine to the PBX, which has 10.8.2.1 on a tap01 interface, while my home pfsense is using 10.8.2.2.
PINGS look good!!
I added the proper routing scripts on the linux PBX box to see the LAN behind my pfsense:
add route -net 192.168.7.0 netmask 255.255.255.0 gw 10.8.2.2I added firewall rules to allow traffic & now I have no problems getting PBX to see all lan machins.
PING 192.168.7.7 => OK!!! (from PBX 10.8.2.1)
[root@h03 ~]# ping 192.168.7.7 PING 192.168.7.7 (192.168.7.7) 56(84) bytes of data. 64 bytes from 192.168.7.7: icmp_seq=1 ttl=249 time=68.6 ms 64 bytes from 192.168.7.7: icmp_seq=2 ttl=249 time=90.4 ms 64 bytes from 192.168.7.7: icmp_seq=3 ttl=249 time=66.1 ms 64 bytes from 192.168.7.7: icmp_seq=4 ttl=249 time=66.3 ms 64 bytes from 192.168.7.7: icmp_seq=5 ttl=249 time=66.0 ms 64 bytes from 192.168.7.7: icmp_seq=6 ttl=249 time=66.2 ms ^C --- 192.168.7.7 ping statistics --- 6 packets transmitted, 6 received, 0% packet loss, time 5454ms rtt min/avg/max/mdev = 66.031/70.649/90.470/8.914 ms [root@h03 ~]#PING 10.8.2.1 => OK!!! (From my home pfsense)
[2.1-RELEASE][root@fiber.localdomain]/root(3): ping 10.8.2.1 PING 10.8.2.1 (10.8.2.1): 56 data bytes 64 bytes from 10.8.2.1: icmp_seq=0 ttl=64 time=243.459 ms 64 bytes from 10.8.2.1: icmp_seq=1 ttl=64 time=64.693 ms 64 bytes from 10.8.2.1: icmp_seq=2 ttl=64 time=64.843 ms 64 bytes from 10.8.2.1: icmp_seq=3 ttl=64 time=95.660 ms 64 bytes from 10.8.2.1: icmp_seq=4 ttl=64 time=65.630 ms ^C --- 10.8.2.1 ping statistics --- 5 packets transmitted, 5 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 64.693/106.857/243.459/69.323 msHowever when i ping 10.8.2.1 from any LAN machine, i got no response…
I tired playing with my outbound NAT without luck, ... any help?C:\Users\User>ping 10.8.2.1 Pinging 10.8.2.1 with 32 bytes of data: Request timed out. Request timed out. Request timed out. Request timed out. Ping statistics for 10.8.2.1: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss), C:\Users\User>Here is my openvpn server configurations:
OPENVPN SERVER:
dev tap ifconfig 10.8.2.1 255.255.255.0 secret static.key proto tcp-server port 1195 keepalive 10 60 ping-timer-rem persist-tun persist-key comp-lzo auth none cipher BF-CBC up /etc/openvpn/up.sh down /etc/openvpn/down.sh push "route 192.168.7.0 255.255.255.0" push "route-gateway 10.8.2.1"UP script
route add -net 192.168.7.0 netmask 255.255.255.0 gw 10.8.2.2DOWN Script
UP scriptroute del -net 192.168.7.0 netmask 255.255.255.0 gw 10.8.2.2OPENVPN CLIENT CONFIG:
Server Mode: peer to peer (shared key) Protocol: TCP Device mode: tap Interface: GW Group1 Local port : (left blank) Server host or address: x.x.x.x (ip address of PBX) Server port: 1195 Proxy host or address: (left blank) Proxy port: (left blank) Proxy authentication extra options: (left blank) Authentication method : none Server host name resolution: (checked) Infinitely resolve server IPv4 Tunnel Network: 10.8.2.0/24 IPv4 Remote Network/s: 10.8.2.0/24 Compression (Checked) Compress tunnel packets using the LZO algorithm. Advanced: ifconfig 10.8.2.2 255.255.255.0; keepalive 10 60; ping-timer-rem; persist-tun; persist-key; auth none; route 10.8.2.0 255.255.255.0; route 192.168.7.0 255.255.255.0;Any clue why pfsense 192.168.7.1/24-10.8.2.2/24 can ping 10.8.2.1, & my LAN cannot? I thought the "Automatic outbound NAT rule generation (IPsec passthrough included)" would make it work automatically …. i tried manually adding this outbound manual rule with no luck:
OpenVPN 192.168.7.0/24 * 10.8.2.0/24 * 192.168.7.0/24 * NOAny idea why this is not working?
Do you have rules on LAN that would be blocking (=not passing) the traffic to 10.8.2.1?
And it should work without any NAT rules, because pfSense and the PBX device know routes to all the subnets concerned. -
not that I am aware of.
however i am a newbie to pfsense, & I've been doing openvpn for a long time, just not with pfsense & I've put already 8h of attempts last night without success.
Clarification: I use two internet connections, a vsat & a low latency DSL, & use traffic shaper & gateway groups to seperate my voip traffic. All voip traffic going to PBX's, including openvpn must not go go via VSAT, but via the gw group "voip" I did this by adding all my voip servers IP's to an ALIAS, & prevented those aliases by talking to the VSAT gateway group "visat tier1, DSL tier2"
"voip gw group" has DSL as tier1, & VSAT as tier2, just to keep things working in case of faliure.I've attached a screenshot of my gateway, LAN rules
& here are my openvpn logs as well:
Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: failed to parse/resolve route for host/network: 10.8.2.0 Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: failed to parse/resolve route for host/network: 10.8.2.0 Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options Dec 12 13:15:58 openvpn[91233]: OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.7.0I am kind of clueless on why it won't allow my LAN to talk with 10.8.2.1… I've done this before on another pfsense box for a friend, and it worked like a charm!! hehhe :)
Thanks phil.davis, I apreciate any insight or help.
hmm, strange!!
this NAT problem still eludes me.Why doesn't pfsense route traffic from LAN to OPENVPN?? The fact is that pfsense itself can ping & reach the OPENVPN server, & that the vpnserver is even able to ping the lan clients no problems…
maybe it is in these logs... what could it be? ::)
I'm willing give this problem a quick $50 via paypal for whoever that can spare me another white night like yesterday ;)
P.M please if anyone is interested to help.
I think the 1st LAN rule after the Anti-Lockout rule is the problem. It feeds any traffic from LANnet to anywhere but the voip alias, into "day" gateway group. I think that is going to force packets for 10.8.2.1 into the "day" gateway group, which goes out some WAN connection and into the public internet - but you want those packets to go onto the OpenVPN link and stay "private".
The 3rd-last rule - LANnet to 10.8.2.0/24 needs to be above it, then the traffic to 10.8.2.1 will get passed to the normal routing table and be routed as required across the OpenVPN.
The last 2 rules look like you trying things to see if they will work - 2nd-last is backwards, last is effectively the same as 3rd-last - they can both be deleted to clean things up.
Hope it works - fingers crossed ;) -
That's it!!
it worked like a charm, just moving the rule above that 1st one did the trick… traffic is now going both way like a charm!
Thank you so much.
is there anything i can do to show my appreciation?
I am a volunteer working with INF in Nepal - buy a Christmas gift for someone from our catalog at http://secure.inf.org/gifts/usd/ :)
