VNstat2 и PF 2.1 calendar problem
If you do vnstat -u are the dates correct?
In cmd? in cmd result of vnstat -u empty
Look at php front end dates now. does it say 17th
Yes, but in Moscow 18 jan…
so does it say 18th now?
No 17…
Today, 18 jan I (have) test:
I del files re1 re2 re3 .re1 .re2 .re3 and cmd vnstat -u -i re1 and others
I got at the phpfrontend clean base with zero data and date 17 jan (but today 18)
add:
Then I copied old base (end data 16 jan) and refresh phpfrontend - programm add 17 jan, not 18…
In russian thread is another person with same problem - in the base he has two 2013 year. (And I have two 2013 year too)
1. I cleared /cf/vnstat/ folder
2. I executed command, they are created new DB with normal date (today date), then i copied old vnstat data (re1 re2 re3 files) and it shows me old date 16 jan (again).
How can I can save my old vnstat data in new DataBase re1 re 2 re3?So when you create new database files for re1 re2 and re3 is the date right or wrong? You seem to have contradicted yourself. Forget about copying back the old files. We need to know if the new database files have the correct date or not.
Today - 18jan date wrong - 17jan.
But when i created clean DB yesterday (17 jan) it was normal 17 jan!
18 jan I decided to forget about problem and begin life with new base and was shocked when my new base got wrong date!
In 10 minutes I do new test with scrennshots. -
1 screenshot - current base (old data)
2 - kill all DB files
3 cmd command to create DB - wrong data :(After that
1. I copied old base with ovewright - in base old data - to 16 jan
2. in cmd exc command vnstat -u -i re1 and others
and in phpfrontend
I saw plus one day - 16 jan and 17 jan
P.S. today 18 jan
Ok. Very strange. with this clean database can you please post the output of vnstat -i re1 –dumpdb
My guess is you downloaded vnstat_php_frontend current from github and that the timezone is set to something different in config.php
1. Please delete:
/usr/local/www/vnstat_php_frontend-1.4.1
/usr/local/www/vnstat2/vnstat_php_frontend-1.4.12. Please copy and paste all text inside into post:
/usr/local/www/vnstat2/config.php
3. Then delete:
4. Download my vnstat_php_frontend-1.5.1-updated
http://www.sendspace.com/file/0py5vt
5. Extract the vnstat2 folder and place it at:
6. It will not work yet until we setup config.php so it will still be broken but I need information first
1. Please delete:
3. Then delete:
all done
// // vnStat PHP frontend 1.4.1 (c)2006-2008 Bjorge Dijkstra (bjd@jooz.net) // // This program is free software; you can redistribute it and/or modify // it under the terms of the GNU General Public License as published by // the Free Software Foundation; either version 2 of the License, or // (at your option) any later version. // // This program is distributed in the hope that it will be useful, // but WITHOUT ANY WARRANTY; without even the implied warranty of // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the // GNU General Public License for more details. // // You should have received a copy of the GNU General Public License // along with this program; if not, write to the Free Software // Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA // // // see file COPYING or at http://www.gnu.org/licenses/gpl.html // for more information. // error_reporting(E_ALL | E_NOTICE); // // configuration parameters // // edit these to reflect your particular situation // $locale = 'en_US.UTF-8'; $language = 'en'; // list of network interfaces monitored by vnStat $iface_list = array('re1', 're2', 're3'); // // optional names for interfaces // if there's no name set for an interface then the interface identifier // will be displayed instead $iface_title['re1'] = 'MTS'; $iface_title['re2'] = 'WAN'; $iface_title['re3'] = 'LAN'; // // There are two possible sources for vnstat data. If the // variable is set then vnstat is called directly from the PHP script // to get the interface data. // // The other option is to periodically dump the vnstat interface data to // a file (e.g. by a cronjob). In that case the variable // must be cleared and set to the location where the dumps // are stored. Dumps must be named 'vnstat_dump_'. // // You can generate vnstat dumps with the command: // vnstat --dumpdb -i > /path/to/data_dir/vnstat_dump_ // $vnstat_bin = '/usr/local/bin/vnstat'; $data_dir = './dumps'; // graphics format to use: svg or png $graph_format='svg'; // Font to use for PNG graphs define('GRAPH_FONT',dirname(__FILE__).'/VeraBd.ttf'); // Font to use for SVG graphs define('SVG_FONT', 'Verdana'); // color schemes // colors are defined as R,G,B,ALPHA quads where R, G and B range from 0-255 // and ALPHA from 0-127 where 0 is opaque and 127 completely transparent. // define('DEFAULT_COLORSCHEME', 'pfSense'); $colorscheme['light'] = array( 'stylesheet' => 'vnstat.css', 'image_background' => array( 255, 255, 255, 0 ), 'graph_background' => array( 220, 220, 230, 0 ), 'graph_background_2' => array( 205, 205, 220, 0 ), 'grid_stipple_1' => array( 140, 140, 140, 0 ), 'grid_stipple_2' => array( 200, 200, 200, 0 ), 'border' => array( 0, 0, 0, 0 ), 'text' => array( 0, 0, 0, 0 ), 'rx' => array( 190, 190, 20, 50 ), 'rx_border' => array( 40, 80, 40, 90 ), 'tx' => array( 130, 160, 100, 50 ), 'tx_border' => array( 80, 40, 40, 90 ) ); // A red colorscheme based on a contribution by Enrico TrГ¶ger $colorscheme['red'] = array( 'stylesheet' => 'vnstat_red.css', 'image_background' => array( 225, 225, 225, 0 ), 'graph_background' => array( 220, 220, 230, 0 ), 'graph_background_2' => array( 205, 205, 220, 0 ), 'grid_stipple_1' => array( 140, 140, 140, 0 ), 'grid_stipple_2' => array( 200, 200, 200, 0 ), 'border' => array( 0, 0, 0, 0 ), 'text' => array( 0, 0, 0, 0 ), 'rx' => array( 190, 20, 20, 50 ), 'rx_border' => array( 80, 40, 40, 90 ), 'tx' => array( 130, 130, 130, 50 ), 'tx_border' => array( 60, 60, 60, 90 ) ); // A red colorscheme based on a contribution by Perry Mason $colorscheme['pfSense'] = array( 'stylesheet' => 'vnstat_pfSense.css', 'image_background' => array( 240, 240, 240, 0 ), 'graph_background' => array( 255, 255, 255, 0 ), 'graph_background_2' => array( 255, 255, 255, 0 ), 'grid_stipple_1' => array( 144, 0, 0, 0 ), 'grid_stipple_2' => array( 144, 0, 0, 0 ), 'border' => array( 0, 0, 0, 0 ), 'text' => array( 0, 0, 0, 0 ), 'rx' => array( 190, 20, 20, 50 ), 'rx_border' => array( 80, 40, 40, 90 ), 'tx' => array( 130, 130, 130, 50 ), 'tx_border' => array( 60, 60, 60, 90 ) ); ?> -
$iface_list = array('re1', 're2', 're3'); $iface_title['re1'] = 'MTS'; $iface_title['re2'] = 'WAN'; $iface_title['re3'] = 'LAN';1. put those into the new config file you extracted /usr/local/www/vnstat2/config.php by replacing the defaults
2. vnstat -u
3. vnstat -d -i re1
4. paste the output of 3. into a post
5. check php front end date
6. if that fails edit /usr/local/www/vnstat2/config.php and put date_default_timezone_set('Europe/Moscow'); like example below$locale = 'en_US.UTF-8'; $language = 'en'; date_default_timezone_set('Europe/Moscow'); -
2. vnstat -u
3. vnstat -d -i re1
5. check php front end date1. done
2. result of command - empty
3.4. attached file
5. I got normal date! 18 today and I see 18 in base! :)
2. vnstat -u
3. vnstat -d -i re1
3.4. attached file
5. I got normal date! 18 today and I see 18 in base! :)Ok that looks better! By the way I have updated the vnstat package and it got merged but nobody has updated the file on files.pfsense.org yet so install fails. Hopefully someone fixes that soon.
thank for your help, I really appreciate it :)
