Changing Default Boot Device + Multi LAN with DMZ setup
.1.28 is within the range .1.10-.1.245 I see no problem there.
Again, new at this. I derped and thought .28 was the equivalent of .280.
I typo'd that firewall rule sorry. Ping is ICMP (not igmp). :-[[/quote]
I changed the firewall rule and it does indeed block my ability to ping anything. The blocked pings are not showing up in the firewall logs.
So you appear to have several devices on your network that are not being handled by the pfSense DHCP server. Your TP-Link switch is presumably on a static IP at 192.168.0.1? Good job it wasn't at .1.1 because that would have intercepted traffic intended for the LANBRIDGE interface. You say you also have a wireless router handing out IPs? The one connected to the DMZ? That is potentially bad. What range is it using? You can use an additional DHCP instance on the pfSense DMZ interface handing out IPs in a completely different range and then have everything logged and controllable from pfSense. Is the wifi router still routing/NATing?
TP-Link switch = .0.1 not .1.1 .
The wireless router is plugged into the TP-Link 24 port switch on the LANBRIDGE. It is box stock so it should be NATing traffic and doing everything else it should be doing. It was only setup temporarily so I wouldn't have my parents or brother coming over and knocking on my door all the time asking me while the internet isn't working while I'm trying to do something. The IP on the router is .0.1 so the same as the switch. Is it possible that is causing an issue?
I'm going to be creating another OPT interface and adding it to the LANBRIDGE eventually. I need some help fishing CAT5e cables, but despite the fact it is for other people they refuse to help get it done. Originally, when I was trying to set everything up I tried to set each interface as their own DHCP server and firewall rules to pass traffic between interfaces. I kept getting DHCP out of range issues or other problems. Again, that is probably me being new at this, but I finally just reinstalled pfsense, bridged it all, and it worked fine aside from the same ping issue I'm having now.
Those firewall logs are interesting. Why was it blocking traffic from a LAN side client to an external address? You don't seem to have any rules that might do that. Do you have any floating rules? Are you running Snort?
No floating rules or Snort.
Check the dhcp leases table to see what .1.118 was.
It was coming from the wireless router. It means it was either; my phone, brother's tablet, dad's laptop, or mom's phone. I'm leaning towards my phone as I just saw it in the firewall logs again and to my knowledge none of those other devices have connected today.
Just to confirm your sysctl tunables look like the attached picture? Though since you have allow all rules on every interface it shouldn't matter.
Yes, it is set exactly like that:
http://i.imgur.com/ymVFRIm.png -
Hmm, well this is odd. The bridge should just pass all traffic between all it's members . I'll have to run some tests on a bridge here.
So the .1.118 address is that the address of the wifi router if it's still doing NAT? Not that it should matter to the bridge issue. If you have two devices connected to different bridge member interfaces they should both receive an IP address from pfSense via DHCP in the 192.168.1.X range. You should see those two devices in the dhcp leases table. They should be able to ping each other without issue.
Any chance that one of them has a personal firewall running?
Ok, so I have bridge setup here exactly as yours is and I have no problems pinging devices across it.
Some things to check:
Both devices appear in the DHCP leases table. They are both receiving an IP from the same DHCP instance, on bridge0.
Both devices appear in the ARP table.
I have ni firewall rules at all on the bridge member interfaces. It shouldn't be necessary, or even make any difference even, since filtering has been disabled on the bridge members.
When pinging external addresses of the pfSense address the traffic appears in the state table. When pinging other devices on the bridge the traffic does not appear in the state table since it''s neither filtered or routed.My bridge is made up of fxp(4) NICs and yours is re(4) NICs. The Realtek NICs have a bad rep, I wonder if perhaps they're not correctly running in promiscuous mode or some hardware offloading is tripping us up?
If you run ifconfig do you see similar results to my bridge:
bridge0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 ether 00:11:22:33:44:55 inet 192.168.5.1 netmask 0xffffff00 broadcast 192.168.5.255 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: fxp4 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 9 priority 128 path cost 55 member: fxp3 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 8 priority 128 path cost 55 member: fxp2 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 7 priority 128 path cost 55 fxp2: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=42198 <vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso>ether 00:90:7f:31:4b:f3 inet6 fe80::290:7fff:fe31:4bf3%fxp2 prefixlen 64 scopeid 0x7 nd6 options=1 <performnud>media: Ethernet autoselect (100baseTX <full-duplex>) status: active fxp3: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=42198 <vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso>ether 00:90:7f:31:4b:f4 inet6 fe80::290:7fff:fe31:4bf4%fxp3 prefixlen 64 scopeid 0x8 nd6 options=1 <performnud>media: Ethernet autoselect (100baseTX <full-duplex>) status: active fxp4: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=4219b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso>ether 00:90:7f:31:4b:f5 inet6 fe80::290:7fff:fe31:4bf5%fxp4 prefixlen 64 scopeid 0x9 nd6 options=1 <performnud>media: Ethernet autoselect (none) status: no carrier</performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud></vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud></vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwtso></up,broadcast,running,promisc,simplex,multicast></learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></up,broadcast,running,simplex,multicast>Steve
In this test I removed the ICMP rule from the LANBRIDGE and attempted to ping from 192.168.1.119 my desktop to 192.168.1.108 a computer on the TP-Link 24 port switch.
Yes, both appear in the DHCP lease table
Yes, both appear in the ARP table
Rules left exactly the same with filtering disabledAttempting to ping 192.168.2.2 an external address, shows in state filter under, "By Destination IP."
Attempting to ping 192.168.1.108 an internal address also appears in the state table under, "By IP Pair."
I have two of these exact NICs: http://www.newegg.com/Product/Product.aspx?Item=N82E16833166096
The last review mentions he was able to setup link aggregation between the two ports under Windows.ifconfig output:
$ ifconfig re0: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:dd inet6 fe80::6a1c:a2ff:fe12:11dd%re0 prefixlen 64 scopeid 0x1 nd6 options=1 <performnud>media: Ethernet autoselect (1000baseT <full-duplex>) status: active re1: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:de inet6 fe80::6a1c:a2ff:fe12:11de%re1 prefixlen 64 scopeid 0x2 nd6 options=1 <performnud>media: Ethernet autoselect (1000baseT <full-duplex>) status: active re2: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 94:de:80:cc:8d:3b inet XX.XXX.XXX.XX netmask 0xfffffc00 broadcast 255.255.255.255 inet6 fe80::96de:80ff:fecc:8d3b%re2 prefixlen 64 scopeid 0x3 nd6 options=3 <performnud,accept_rtadv>media: Ethernet autoselect (1000baseT <full-duplex,master>) status: active re3: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:db inet6 fe80::6a1c:a2ff:fe12:11db%re3 prefixlen 64 scopeid 0x4 nd6 options=1 <performnud>media: Ethernet autoselect (100baseTX <full-duplex>) status: active re4: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:dc inet6 fe80::6a1c:a2ff:fe12:11dc%re4 prefixlen 64 scopeid 0x5 nd6 options=1 <performnud>media: Ethernet autoselect (none) status: no carrier plip0: flags=8810 <pointopoint,simplex,multicast>metric 0 mtu 1500 enc0: flags=0<> metric 0 mtu 1536 pflog0: flags=100 <promisc>metric 0 mtu 33144 lo0: flags=8049 <up,loopback,running,multicast>metric 0 mtu 16384 options=3 <rxcsum,txcsum>inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9 nd6 options=3 <performnud,accept_rtadv>pfsync0: flags=0<> metric 0 mtu 1460 syncpeer: 224.0.0.240 maxupd: 128 syncok: 1 bridge0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 ether 02:f2:fb:65:02:00 inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255 inet6 fe80::1:1%bridge0 prefixlen 64 scopeid 0xb nd6 options=1 <performnud>id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 1 priority 128 path cost 55 member: re3 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 4 priority 128 path cost 55 member: re1 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 2 priority 128 path cost 55</learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></performnud></up,broadcast,running,simplex,multicast></performnud,accept_rtadv></rxcsum,txcsum></up,loopback,running,multicast></promisc></pointopoint,simplex,multicast></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,simplex,multicast></full-duplex></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast></full-duplex,master></performnud,accept_rtadv></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,simplex,multicast></full-duplex></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast> -
Ok, here's something I see.
You'll notice the MAC address of the bridge on box is fake where as yours appears to be real. I exepct it to be fake as it doesn't have real hardware to get the MAC from. An issue that has cropped up in the past is that Windows systems can be confused by the fake MAC, especially because it can be generated as a new fake address on each boot. This causes systems >Win XP to label the network as a new untrusted environment and block any connections from them. Not sure if that applies to you.Why can you not ping 192.168.2.2? Does it exist on your network?
Attempting to ping within the same subnet should not appear in the state table, I think we have a clue there. Are your clients receving the correct subnet mask?
All clients on the TP-Link 24 port switch are Windows computers. There's thirteen Windows 7 and three Windows 8.1 . My laptop does have Kubuntu 13.10 on it and has the same issue though so I'm not sure.
192.168.2.2 does not exist on my network so I used it as such to test that it would appear in the state table when I attempted to ping it. I haven't done anything of this before so I'm trying to be as thorough as possible.
Despite all the clients being bridged and on the same subnet I am still unable to ping anything, but pfsense. Regardless of the interface, device, or OS. When, I went through all of the computers attempting to determine what device .1.118 was I checked to make sure all computers and my TP-Link switch are on the 255.255.255.0 subnet. Using ifconfig and ipconfig confirmed that and all devices do report the subnet mask as being 255.255.255.0 .
Presumably you can ping other devices that are connected to the same switch?
I thought of one other thing I have that is non-standard on that box. I have IP fast forwarding enabled. That shouldn't make any difference at all but I'm running out of ideas. ::) It's a sysctl on the system tunables table. By default it's off because it breaks IPSec. Try setting it to 1.
You could try disabling the hardware offload options in System: Advanced: Networking: I can't really see how that would help either. :-\
Anyone else got any suggestions for a bridge that isn't forwarding packets? Or more accurately clients that seem to be sending all traffic to their gateway even that for their own subnet?
Time to run some packet captures and see what's up.
Power issues have been raping my life right now, but… While dealing with all of that crap I might have found something.
IP fast forwarding didn't do anything differently.
Windows 8.1 ipconfig shows different results than that of Windows 7. All of my Windows 7 computers show the subnet mask as 255.255.255.0 and my 8.1 machines do as well, but only for the section that says ethernet adapter to ethernet. Where it says something along the lines of local connection 1, 2, 3, 4, etc... it shows the subnet mask as 255.255.0.0 . I'm guessing that despite the bridge being setup and all the subnets of local hardware being set to 255.255.255.0 it is getting switched some where along the way.
A bad subnet mask is exactly the sort of this that might cause this. If your client machines don't realise they're in the same subnet as others on the bridge (or supposed to be as least) then they will send traffic via their gateway instead of directly. However for that to happen they would have to have a smaller subnet mask like 255.255.255.224 not a much larger one as you've discovered.
If that was the case then you might have a problem pinging other clients even on the same switch.
I don't have a Windows 8 machine to look at here so I'm not entirely sure what you're referring to. Do you have a screenshot or the output from ipconfig?
I assume you can't ping ping between two Win 7 clients on different switches though?
I can't ping anything even if they're sitting right next to each other on the same switch. This has been tested with on all of my switches with three different operating systems. Here is what I was speaking of in regards to Windows 8.1 showing odd subnet behavior.
When the bridge originally broke I had to keep using ipconfig release and renew to actually get it to connect automatically. That was due to me changing how the switches were connected around, but it might be a clue?
http://en.wikipedia.org/wiki/IP_address#IPv4_private_addresses - read the Address autoconfiguration section. Windows sets those 169.254 addresses when it does not get a DHCP response within "timeout?" seconds. So that indicates that the Windows client DHCP requests are not getting through to the pfSense DHCP server (or the replies are not getting back).
That makes sense. Again, I'm new at this so what should I start looking in to resolve this?
Ok so this is good problem solving clues we have here. :)
So you can't ping other machines even across the same switch when both are receiving IP addresses in the 192.168.1.X subnet from pfSense. That is interesting because that traffic doesn't go through pfSense at all, or at least it it shouldn't. Hence whatever is causing those machines not respond to the pings is local.The ipconfig result from a Windows client shows, as Phil said, a load of interfaces with self assigned IP addresses along with one correctly assigned IP. I assume that you don't actually have 4 NICs in that box? What are showing up there as 'connections' I would interpret as what Windows does when it thinks you've connected it to a new wired network, it starts a new set of connection settings. Though I have no experience with Windows 8.
Theses two things together strongly point to my earlier hypothesis:@stephenw10:
You said that you've tried a Kubuntu machine as well and that behaved similarly which seemed to rule this out but perhaps you didn't try receving pings with Kubuntu or it has a personal firewall on it.
Check that Windows firewall hasn't assigned the network as 'public'. Change it 'private' or trusted (it'e been a while ::)).
The cause of this is that the pfSense bridge MAC address can change. If you've rebooted your pfSense box check the output of ifconfig again to see if the MAC has changed. If it has then you can get around it by spoofing the MAC to something fixed. I had forgotten earlier but if you look back at my ifconfig output where my bridge has an obviously fake MAC that is because I spoofed it to that to get around this very problem! ;)
I haven't had a lot of time to work on this, but I have been twiddling with it every once in a while. My main issue right now is getting my power to actually stay on. I have a main shutoff that is going bad and a local place wants $225 for the breaker alone… ::) . Back to pinging issues though as I still haven't figured out this issue. This is from the same computer with Windows 8.1 .
Before reboot:
After reboot:
ipconfig /all returns:
You can see it isn't resetting the MAC address on reboot, but each time it has setup a new connection it is. All connections are set to Home and private within Windows firewall.
Pfsense has been rebooted about a million times as I had six power outages today alone. Here is a new ifconfig output:
$ ifconfig re0: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:dd inet6 fe80::6a1c:a2ff:fe12:11dd%re0 prefixlen 64 scopeid 0x1 nd6 options=1 <performnud>media: Ethernet autoselect (1000baseT <full-duplex>) status: active re1: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:de inet6 fe80::6a1c:a2ff:fe12:11de%re1 prefixlen 64 scopeid 0x2 nd6 options=1 <performnud>media: Ethernet autoselect (1000baseT <full-duplex>) status: active re2: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 94:de:80:cc:8d:3b inet 67.190.224.33 netmask 0xfffffc00 broadcast 255.255.255.255 inet6 fe80::96de:80ff:fecc:8d3b%re2 prefixlen 64 scopeid 0x3 nd6 options=3 <performnud,accept_rtadv>media: Ethernet autoselect (1000baseT <full-duplex>) status: active re3: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:db inet6 fe80::6a1c:a2ff:fe12:11db%re3 prefixlen 64 scopeid 0x4 nd6 options=1 <performnud>media: Ethernet autoselect (none) status: no carrier re4: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 options=209b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic>ether 68:1c:a2:12:11:dc inet6 fe80::6a1c:a2ff:fe12:11dc%re4 prefixlen 64 scopeid 0x5 nd6 options=1 <performnud>media: Ethernet autoselect (none) status: no carrier plip0: flags=8810 <pointopoint,simplex,multicast>metric 0 mtu 1500 enc0: flags=0<> metric 0 mtu 1536 pflog0: flags=100 <promisc>metric 0 mtu 33144 lo0: flags=8049 <up,loopback,running,multicast>metric 0 mtu 16384 options=3 <rxcsum,txcsum>inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9 nd6 options=3 <performnud,accept_rtadv>pfsync0: flags=0<> metric 0 mtu 1460 syncpeer: 224.0.0.240 maxupd: 128 syncok: 1 bridge0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500 ether 02:f2:fb:65:02:00 inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255 inet6 fe80::1:1%bridge0 prefixlen 64 scopeid 0xb nd6 options=1 <performnud>id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: re0 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 1 priority 128 path cost 55 member: re3 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 4 priority 128 path cost 55 member: re1 flags=143 <learning,discover,autoedge,autoptp>ifmaxaddr 0 port 2 priority 128 path cost 55</learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></learning,discover,autoedge,autoptp></performnud></up,broadcast,running,simplex,multicast></performnud,accept_rtadv></rxcsum,txcsum></up,loopback,running,multicast></promisc></pointopoint,simplex,multicast></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,simplex,multicast></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud,accept_rtadv></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,simplex,multicast></full-duplex></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,wol_magic></up,broadcast,running,promisc,simplex,multicast>This is the one I posted earlier:
The MAC I was referring to is on the pfSense bridge0 interface. It hasn't changed though which makes me think that's not the issue. Though you say the Windows box creates new connections every time pfSense is rebooted? It's hard to see but most of the connections on your Windows box appear to be TAP VPN connections rather than real Ethernet interfaces, does it actually have more than one real interface showing? Are those other interfaces something you have put there?
The only other thing I see that's different between your bridge setup and mine is that my bridge does not have an IPv6 address. Could this be an IPv6 issue? :-
Try setting the bridge interface to have IPv6 configuration type: 'none'.
Edit: The member interafce are also set to IPv6 type 'none'.
I can't see why that would be an issue to be honest but maybe something is trying route via IPv6.Steve
