    CARP on LAN + WIFI issue (using ALIX 2D13)
    2 Posts 1 Posters 1.0k Views
      DaleX001
      Hello all,
      I've been searching for a while and don't seem to find someone having the same issue.
      So first what i want to accomplish :
      Using 2 ALIX 2D13 boxes, i wish to have a complete LAN+WIFI+WAN failover solution.
      What is working :
      • I have LAN CARP working OK (VIP : 192.168.1.1 | ALIX box1 : 192.168.1.2 | ALIX box2 : 192.168.1.3)
      • I have WAN1 CARP working OK
      • I have WAN2 CARP working OK
      • Failover/loadbalancing between WAN1 and WAN2 is working (not CARP related though)
      • Cluster communication is on a dedicated subnet (192.168.99.0/24) and is working as well
      What is not working :
      • When connecting through WIFI i can't ping the LAN VIP (192.168.1.1 which will be used as Internet gateway) I can only ping the LAN IPs
      • Then if I disable and reenable CARP, then I can ping the LAN VIP again (the enable/disable of CARP is "doing something")
      • If I disconnect and reconnect from WIFI, I can't ping the LAN VIP
      I have WIFI and LAN interface bridged (and in a group) so that firewall rules are the same whether i'm wireless or not.
      So far i'm stuck, because I intend to push the LAN VIP as the default gateway to all workstations using my Windows DHCP server (which is on LAN).
      Any idea ?
        DaleX001
        I found a workaround which is not ideal but allows me to move on.
        I noticed that in fact i couldn't ping the LAN VIP if i was connected in WiFi to the active CARP appliance.
        So basically instead of having two active hotspots, I just had to make sure the hotspot was disabled on the active CARP appliance.
        To do so here is what I did:
        1 - Modify /etc/devd.conf to point to custom rc.carp scripts
        # CARP notify hooks. This will call carpup/carpdown with the
        # interface (carp0, carp1) as the first parameter.
        notify 100 {
            match "system"          "IFNET";
            match "type"            "LINK_UP";
            match "subsystem"           "[a-zA-Z0-9_]+_vip[0-9]+";
            action "/etc/rc.carpmaster.custom $subsystem";
        notify 100 {
            match "type"            "LINK_DOWN";
            action "/etc/rc.carpbackup.custom $subsystem";
        2 - Create /etc/rc.carpmaster.custom
        #!/bin/sh
        /etc/rc.carpmaster $1
        ifconfig ath0_wlan0 down
        /usr/local/sbin/pfSsh.php playback svc restart racoon
        3 - Create /etc/rc.carpbackup.custom
        #!/bin/sh
        /etc/rc.carpbackup $1
        ifconfig ath0_wlan0 up
        So basically, when an appliance becomes master:
        • It runs the usual carp scripts
        • It disables the hotspot
        • It restarts racoon (to make sure IPSEC connection are restarted)
        • It enables the hotspot
        Having the same SSID and both appliance not too far from one another makes it almost transparent to end-users (about 30 seconds service interruption in case of a CARP failover).
