    Help! problem with squid cache
    4 Posts 2 Posters 3.7k Views
    • E Offline
      elvis.nuno
      I'm running pfsense 1.2RC3 and having a problem w/ squid caching. When squid attempts to cache anything it generates the following error in the /var/squid/log/cache.log file:
       storeDiskdSend: msgsnd: (35) Resource temporarily unavailable
      after generating this error 100x squid restarts itself after generating the following error:
      assertion failed: diskd/store_io_diskd.c:512: "++send_errors < 100"
      I have attempted to rebuild cache directory with no change. Anybody have any suggestions?
      Also I am running pfsense off a 2gb cf card with over 1gb free disk space, and 512mb of ram that never runs over 300mb utilized, if that matters.
        mhab12
        Are you running the embedded version of pfSense?  Squid will not run on embedded, you will need the full install.
        • E Offline
          elvis.nuno
          I am running the full install of pfsense.
          • E Offline
            elvis.nuno
            I re-installed 1.2-RC3 and squid and it seems to be working now.
