    Multi WAN (Cable + DSL) Failover not working
    4 Posts 2 Posters 1.2k Views
    • Y Offline
      yaboc
      Hi
      I followed the Multi WAN pfsense doc and got the Multi WAN to work.
      My primary WAN connection is CABLE (set up as Tier1 with 8.8.8.8 monitor IP) and secondary is DSL. (set up as Tier2 with 8.8.4.4 monitor IP) all bundled into FAILOVER Gateway Group with Member Down as the Trigger (so i don't load balance the WANs)
      In a testing stage I pulled the Primary WAN cable out and it switched over to DSL just fine by checking if there was Internet Connectivity as well as my public IP change. The I reinserted it back and it switched back to WAN1 (CABLE) just fine.
      However the DSL Gateway shows offline but i can ping any external site using my DSL as source address so the DSL internet connection is fine.
      Any ideas on how to go about this issue ?
      Thank you
      yaboc
      • Y Offline
        yaboc
        bascially my pppoe wan is behaving like in the OP of this thread
        https://forum.pfsense.org/index.php/topic,69179.0.html
          phil.davis
          And my recent reply on that thread: https://forum.pfsense.org/index.php/topic,69179.msg398184.html#msg398184
          If you are able to try an upgrade to 2.1.1-prerelease it might help.
          If you do that, please post back to say if it fixed it or not.
          • Y Offline
            yaboc
            phil.davis
            late reply but i upgraded to 2.1.3 and the gateway for PPPoE WAN still says Pending even though i can ping from DSL connection using the ping app.
            any ideas ?
