    A few basic questions about features from a NOOB -
    62 Posts 12 Posters 17.5k Views
      Guest
      I have a Cron job to do pfctrl -F state 1 min after the block rule kicks in (allow rules didn't work either and I had to have more than one, due to the general limitations on ports/IPs). An eMail Service says 1 h later:
      "This is a periodic report from your firewall
      Current report: states >NAME< 21:00
      Command output: states (pfctl -ss | grep 10.zzz.yyy.xxx)"
      i.e. there are no states, which I checked by hand several times. But half an hour later I found 6-8 states to this notorious ivony.com IP (216.66.6.120). Unfortunately I killed them and took no screenshot in advance…
        Can you post up your rules so we can take a look at what they are and what your trying to do..  I thought you wanted to block his access completely..  Off the top if your saying new states are being created when your trying block them, then your rules are not correct for what your trying to do.
          Guest
          Hello again and many thanks for your patience! :-)
          Here the first 3 rules of my LAN set. The first is the default, the second blocks some domain names (as in alias "blocklist") for the kids IPs (alias "junx", IPs are correct, trust me :-D ).
          The third rule blocks all WAN access according to a schedule called "majo", see below, which kicks in at 21:00. At 21:00 the eMail report for the states (pfctl -ss | grep 10.xxx.yyy.zzz) of one of the IPs blocked is EMPTY, completely empty, Null, NADA, NIENTE…
          EDIT: But I found now that this is not the truth, there ARE states alive at that time, checked by hand (Diagnostics -> States). What is wrong with the eMail report job? :o
          The browser at the kids computers is still alive at that time, of course. Two minutes later the Cron job does (?) its job
          pfctl -F state
          EDIT: However, the states are still alive, not in the eMail report (completely empty), but when I check manually. When I go to Status -> eMail Reports and press "Send now", there ARE states, but not according to the eMail sent out automatically.... STRANGE indeed!
          Now I'm no longer willing to watch this and do
          Diagnostics -> States -> filter for kids IP and press KILL
          States are gone now... dunno if they come up again if they manipulate with their browsers, normally they should NOT. ;)
          So actually the problem appears to be related to my Cron job and the eMail Reports on states send out. Apparently. Or any other explanations? ???
          ![firewallrules kids.JPG](/public/imported_attachments/1/firewallrules kids.JPG)
          ![firewallrules kids.JPG_thumb](/public/imported_attachments/1/firewallrules kids.JPG_thumb)
          ![schedule majo.JPG](/public/imported_attachments/1/schedule majo.JPG)
          ![schedule majo.JPG_thumb](/public/imported_attachments/1/schedule majo.JPG_thumb)
            Well another thing is when are the states being created from your schedule there is 1 minute while its off.  so at 23:59:01 its off til 23:59:59, then turns back on at 00:00
            Just pointing out a possible flaw..  You would need to validate that the states are gone..  Why your email says they are none, but when you check is odd yes.
              Guest
              Same game today:
              21:00 firewall block rule
              21:00 eMail report for "pfctl -ss | grep 10.XXX.YYY.ZZZ" COMPLETELY EMPTY
              21:01 Cron job "01  21  *  *  *  root  pfctl -F state"
              so far so good, but
              21:14 I check states for the blocked IP via Diagnostics -> States and find: 32 states alive AS WELL AS by press "SEND NOW" for the eMail Report job for 21:00, same result dozends of states alive…
              I erased the Cron job as well as the eMail report jobs yesterday and made them new. Makes no difference, as you see. Don't know what to do next...
                Guest
                Question:
                Found this in my logs:
                php: rc.start_packages: The command '/usr/local/etc/rc.d/cron.sh stop' returned exit code '1', the output was ''
                Might this result in impaired Cron functionality?
                  That's not necessarily a problem. Cron is stopped and restarted along with all packages, usually in response to an IP change on one of your interfaces though could be a config change etc. As long as it starts again correctly it shouldn't be causing an issue though you could end up with multiple instances if it wasn't stopped correctly for example.
                    Guest
                    Status -> Services shows Cron as up and running
                    Diagnostics -> Sockets shows only one instance for Cron
                    Re-installed Cron package, but I still don't see proper functioning, as apparently the states are not killed (pfctl -F state) and the output from eMail reports (performed via Cron jobs) doesn't provide accurate information on the states present.
                    No idea why…
                      Guest
                      ..got an idea why. Question:
                      In wich directory are the commands executed in the Diagnosics -> Execute Command window of the GUI?
                      Is it /usr/bin/ ?
                      That could make my Cron job for killing states work, if I find the right directory to execute the Cron job in…
                      • BBcan177B Offline
                        BBcan177 Moderator
                        To display the location of your current working directory, enter the command
                        pwd
                        The output should look similar to:
                        /home/user
                        "Experience is something you don't get until just after you need it."
                        Website: http://pfBlockerNG.com
                        Twitter: @BBcan177  #pfBlockerNG
                        Reddit: https://www.reddit.com/r/pfBlockerNG/new/
                          Guest
                          Hey, many thanx!
                          Apparently it's
                          /usr/local/www
                          … I'll try that this evening... :-D
                            Make sure you use the absolute path to all the commands in your cron job. That way it doesn't matter where it's executed from.
                            Edit: Or, importantly, that the process executing the cron job may not have the same default paths as a shell prompt.
                              Guest
                              Definitely! But at first you have to know the correct absolute path!  ;)
                              • BBcan177B Offline
                                BBcan177 Moderator
                                Stephen is correct always use absolute paths in the scripts.
                                To find the location of a file, you can run the following command.
                                find / -name pfctl
                                  Guest
                                  OK, then it should be /sbin/pfctl … Try this today
                                  What I really don't understand is the problem with the eMail Reports. When I press "Send Now" at the setup page for the respective job everything is fine and the eMail contains the information on the states for the requested IP. But when the Cron runs the respective php script the eMail contains no states at all... tried the /sbin/ path for the eMail Report command, too, let's see if it works... :-D
                                  • BBcan177B Offline
                                    BBcan177 Moderator
                                    Can you post the commandline?
                                      Guest
                                      @chemlud:
                                      Edit: Crazy, I tried the command (without /sbin/) on another box for a different IP (without a block rule at the firewall tab) and there the Cron-sent eMail Report is correct, including the states info for the requested IP. Dunno what's wrong here…
                                      • BBcan177B Offline
                                        BBcan177 Moderator
                                        I set that command to run and it emailed thru without issue. I did include " " around the IP address thou.
                                        /sbin/pfctl -ss | grep "10.XXX.YYY.ZZZ"
                                          Guest
                                          See my edit above, worked for me without the "" for the IP, but not on the box I need the command to work.  Unfortunately the eMail Report page of the GUI allows no minutes to be entered, so only every full hour the job can be tested…
                                          To be continued... :-)
                                          Edith:
                                          Cron job with
                                          /sbin/pfctl -k 10.XXX.YYY.ZZZ
                                          1 minute after the block rule WORKED! PAAARTY!  8)
                                          And the eMail Report for
                                          gave no output, while
                                          /sbin/pfctl -ss | grep 10.XXX.YYY.ZZZ
                                          correctly reported the states!
                                          Problems solved, Block rule works
                                            Persistence pays off!  ;)
