    CARP Problems
    36 Posts 8 Posters 27.2k Views
      Juve
      I have the same problem (brand new install of beta4).
      After configuring CARP on each firewall, some of the interfaces of the master are in backup mode and some other in master mode, the same appears on the slave firewall.
      if I do an ifconfig carp0 carp1 etc… then I can see that the advskew is set to 200 to all carp interfaces on the two firewalls even if I have set 0 on the master one. Bakcuping the configuring and editing the XML file shows up the right configuration (0 for master VIPs and 200 for slave).
      then if I modify the /tmp/carp.sh on the master by putting the advskew at 0, I destroy all carp interfaces and execute carp.sh all is fine because master is master !
      If I modify the code where the advskee is hard coded on the master firewall then all is fine too.
        sullrich
        @Juve:
        It will have a advertising skew until the final carp bringup process (about 2 minutes after the firewall is completely booted up).  You can view the progress on the console.
        In terms of having interfaces being master or backup and being wrong, this means that carp is not communicating on the interface themselves.  It needs to be able to broadcast and talk to the other firewall on that interface in question.
        • I Offline
          iimre
          @sullrich:
          How could I test it. Because I'm facing the similar problem, one of my carp interfaces out of the four are "master-master" no matter what I do. Simple ping goest fine to and fro'. Nothing seems to be blocked in the logs. I have already changed NIC's and switches without success.
            sullrich
            @iimre:
            @sullrich:
            If you have not seen the CARP tutorial on our site then you need to follow it.  It will guide you in setting up the primary box which sycns the configuration to the secondaries.  The reason this is important is because it ensures that the advskew and also the vhid are correct across all cluster members.  It also ensures that the passwords match per vhid.  Place a crossover cable between the two wan interfaces.  Does the problem persist?  If so you have a mismatched configuration somewhere.
            • I Offline
              iimre
              @sullrich:
              I did exatly that.
              I have already tried this. Not only the wan but all the interface pairs, one by one. I will make some other xover cables tomorrow and will make a try with connecting all interface pairs (WAN, WAN2, DMZ and LAN) with xover (they carp syncronization interface is ofcourse permanently xovered).
              Yes :(
              Yes probably, but I have tried to build up several times from scratch, with only the (as I guess) the minimal neccessary configuration. So now I have no idea what could be the problem.
              Anyhow, it seems to function well, on all the two WAN interfaces either from LAN or DMZ, but I afraid that there is a hidden problem which can cause a collapse in the worst moment.
                sullrich
                Post screen shots of each of the machines virtual ips configuration so we can inspect.
                • I Offline
                  iimre
                  @sullrich:
                  I attached as you asked. I reduced the sizes as possible, hoping that they are still readable.
                  Thank you for your help
                  Imre
                  pfsense1__dmz-carp.jpg_thumb
                  pfsense1__lan-carp.jpg_thumb
                  pfsense1__wan2-carp.jpg_thumb
                  pfsense1__wan-carp.jpg_thumb
                  pfsense2__dmz-carp.jpg_thumb
                  pfsense2__lan-carp.jpg_thumb
                  pfsense2__wan2-carp.jpg_thumb
                  pfsense2__wan-carp.jpg_thumb
                    sullrich
                    Each of the same ip's need to share the same vhid group…  They are unique in your setup which also tells me that you didnt follow the tutorial as it would have sync'd the configuration to the backup node ensuring this is all the way it should be.    >:(
                    • I Offline
                      iimre
                      @sullrich:
                      Sorry .then I probably misunderstandig something :(
                      xxx.xxx.xxx.165's VHID=1
                      xxx.xxx.xxx.116's VHID=2
                      10.0.254.4'd VHID=3
                      192.168.0.10's VHID=4
                      the same kind of interfaces have the same vhid group number.
                      I'm confused. All of the 4 should have the same?
                        sullrich
                        @iimre:
                        @sullrich:
                        10.0.254.4'd VHID=3
                        Each unique IP needs to have its on VHID.  The VHID needs to match on each machine.
                        If you are using the Sync option as the tutorial shows, this is all automatic.
                        • I Offline
                          iimre
                          @sullrich:
                          It is.
                          They do.
                          I did and I see them to be the same, but please let me know which one is not matching. it is probably my fault, but I really don't see.
                            Juve
                            I just want to add something to know before activating sync over XML-RPC. When having a lot of rule in the filter, it is not possible (in terms of 'useability') to use the rule sync over XML-RPC.  I have tested it on a cluster wich have between 700 and 800 rules… when you modify one thing the sync starts and then the firewall goes to 100% CPU (php process) during many many minutes loosing control on everything. This was tested on 2 IBM x336 intel Xeon 3.2Ghz dual core with 2Gb of RAM and 80Gb SATA hard drives.
                            What I do is manual sync using partial backups ;-) and it's fine I'm not adding rules every minute ;-)
                              sullrich
                              @Juve:
                              I don't really want to hijack this thread but could you please start a new topic that explains the pain and frustration of managing such a large ruleset in a new topic?  We can begin to brainstorm how to improve this situation.
                                Juve
                                I really hope you don't think I'm complaining. The previous post was just a sort of "advice" for those who have not tried it yet.
                                Regards.
                                  sullrich
                                  @Juve:
                                  Regards.
                                  Not at all.  I just can imagine that managing that large amount of rules must be painful.  I am looking for information on what you don't like, what is hard to do, etc for future improvements…
                                  • I Offline
                                    iimre
                                    Just for the record, my problem is solved. It was a ruling mistake on DMZ, ie. a directed all traffic destined to elswhere then LAN or DMZ to the load balancer (WAN1 + WAN2), but this way the traffic to 224.0.0.x went out to the net.
                                    Thanks for all who tried to help me to solve this problem.
