    IPsec mobile client problems: no virtual IP found for %any …
    Scheduled Pinned Locked Moved 2.2 Snapshot Feedback and Problems - RETIRED
    24 Posts 4 Posters 14.6k Views
      charliem
      @ermal:
      Well try using a different subnet for the rightsourceip rather than peer ip address.
      SAD and SPD entries can be created if I comment out 'rightsubnet=192.168.3.0/24' from ipsec.conf (not sure that's possible with the current webgui code).  But I still cannot pass any traffic through the tunnel.
      I will start from scratch and take a close look over the weekend, thanks.
        charliem
        This strongswan bug https://wiki.strongswan.org/issues/586 was properly rejected because it was not a strongswan issue, but rather a FreeBSD 10.0 issue.
        Symptoms seem to match what I'm seeing … Was or is this a valid bug?  I can't immediately find a similar patchset in FreeBSD sources, but I can't believe a bug like this would still be around.
          hege
          FYI:
          i have the same issue.
          https://forum.pfsense.org/index.php?topic=81657.msg446613#msg446613
          • E Offline
            eri--
            @charliem:
            The fix is already present in FreeBSD 10 afaik.
            So that patch is already merged!
