    High ping and packet loss in point to point connectivity using pfsense
    3 Posts 2 Posters 1.1k Views
      rajesh_rao1788hotmail.co
      Hi to all!
      I'm new to the world of PFsense.
      Can you guys help me out. I have a big problem with high ping and packet loss with my pfsense.. I have the last version 2.1.3-RELEASE (amd64)
      I have created a point to point connectivity from DC to my office.
      at the dc end my ip is 172.253.250.254 and at office is 172.253.250.77 but the issue is when i ping it from bot the ends i get a very high ping
      samples are mentioned below
      PING 172.253.250.77 (172.253.250.77) from 172.253.250.254: 56 data bytes
      64 bytes from 172.253.250.77: icmp_seq=0 ttl=64 time=0.642 ms
      64 bytes from 172.253.250.77: icmp_seq=1 ttl=64 time=2.605 ms
      64 bytes from 172.253.250.77: icmp_seq=2 ttl=64 time=1004.445 ms
      64 bytes from 172.253.250.77: icmp_seq=3 ttl=64 time=0.510 ms
      64 bytes from 172.253.250.77: icmp_seq=4 ttl=64 time=643.229 ms
      64 bytes from 172.253.250.77: icmp_seq=5 ttl=64 time=1003.465 ms
      64 bytes from 172.253.250.77: icmp_seq=6 ttl=64 time=0.556 ms
      64 bytes from 172.253.250.77: icmp_seq=7 ttl=64 time=1003.473 ms
      64 bytes from 172.253.250.77: icmp_seq=8 ttl=64 time=0.529 ms
      64 bytes from 172.253.250.77: icmp_seq=9 ttl=64 time=957.572 ms
      64 bytes from 172.253.250.77: icmp_seq=10 ttl=64 time=309.481 ms
      64 bytes from 172.253.250.77: icmp_seq=11 ttl=64 time=93.928 ms
      I have not done anything except assigning ip to both the end and bridging the adapter at the DC end (Bridging WAN and Dedicated interface)
      What can be the problem?
      Please help me =)
      if you need some information, ask me, regards.
        Harvy66
        2.1.5 is the newest version, not 2.1.3.
        Can you create a basic graph of your network, and what technology you are using for your links? They hardware your PFSense is running on could also be useful.
          @Harvy66:
          Hi Harvy ,
          Thanks for your reply
          Here is the below Hardware Details of the pfsense server
          Vendor: Dell Inc.
                  Version: 6.3.0
                  Release Date: 07/24/2012
                  Address: 0xF0000
                  Runtime Size: 64 kB
                  ROM Size: 4096 kB
                  Characteristics:
                          ISA is supported
                          PCI is supported
                          PNP is supported
                          BIOS is upgradeable
                          BIOS shadowing is allowed
                          Boot from CD is supported
                          Selectable boot is supported
                          EDD is supported
                          Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
                          5.25"/360 kB floppy services are supported (int 13h)
                          5.25"/1.2 MB floppy services are supported (int 13h)
                          3.5"/720 kB floppy services are supported (int 13h)
                          8042 keyboard services are supported (int 9h)
                          Serial services are supported (int 14h)
                          CGA/mono video services are supported (int 10h)
                          ACPI is supported
                          USB legacy is supported
                          BIOS boot specification is supported
                          Function key-initiated network boot is supported
                          Targeted content distribution is supported
                  BIOS Revision: 6.3
          Handle 0x0D00, DMI type 13, 22 bytes
          BIOS Language Information
                  Language Description Format: Long
                  Installable Languages: 1
                          en|US|iso8859-1
                  Currently Installed Language: en|US|iso8859-1
          Handle 0x0800, DMI type 8, 9 bytes
          Port Connector Information
                  Internal Reference Designator: Not Specified
                  Internal Connector Type: None
                  External Reference Designator: Not Specified
                  External Connector Type: DB-15 female
                  Port Type: Video Port
          Handle 0x0801, DMI type 8, 9 bytes
          Handle 0x0802, DMI type 8, 9 bytes
                  External Connector Type: Access Bus (USB)
                  Port Type: USB
          Handle 0x0803, DMI type 8, 9 bytes
                  Port Type: USB
          Handle 0x0808, DMI type 8, 9 bytes
                  Port Type: USB
          Handle 0x0809, DMI type 8, 9 bytes
                  Port Type: USB
          Handle 0x080A, DMI type 8, 9 bytes
                  Internal Reference Designator: INT_USB
                  Internal Connector Type: Access Bus (USB)
                  External Connector Type: None
                  Port Type: USB
          Handle 0x080B, DMI type 8, 9 bytes
                  Internal Reference Designator: INT_SD
                  Internal Connector Type: Other
                  Port Type: USB
          Handle 0x080E, DMI type 8, 9 bytes
                  External Connector Type: RJ-45
                  Port Type: Network Port
          Handle 0x080F, DMI type 8, 9 bytes
          Handle 0x0810, DMI type 8, 9 bytes
          Handle 0x0811, DMI type 8, 9 bytes
          Handle 0x0812, DMI type 8, 9 bytes
                  External Connector Type: DB-9 male
                  Port Type: Serial Port 16550A Compatible
          and here is the basic graph of the network
          https://www.dropbox.com/s/hjpx0buc7nwhh1p/Nework.JPG?dl=0
