    Low Noise Level Fan For Supermicro Chassis CSE-512L
    10 Posts 4 Posters 2.7k Views
    • F
      FasTrak
      Hi
      I have my network rack in a small lumber room on the 1 floor but the server is so loud (60DB) that I can hear it down below
      Any suggestions for a low noise fan? Or can I use a couple 40x40mm fans will it provide enough air flow?
      Picture of the server inside
      1 Reply Last reply
      Reply Quote 0
      • J
        jasonlitka
        What kind of CPU is that?
        I can break anything.
        1 Reply Last reply
        Reply Quote 0
        • F
          FasTrak
          AMD Opteron 148 2.26 GHz MB Supermicro H8SLL-i Socket 939
          1 Reply Last reply
          Reply Quote 0
          • B
            BeerCan
            get something that will reduce the fan speed to a suitable level.  You cold solder in a resistor or get something like this
            http://www.amazon.com/Manual-Variable-Speed-controller-connector/dp/B002D3DK1I
            http://www.amazon.com/Manual-Variable-Speed-controller-connector/dp/B002PNFEM4/ref=pd_sim_pc_7?ie=UTF8&refRID=1ZPPAPS27R0T5C7HH2V0
            Make sure you get a controller with the correct connectors.
            1 Reply Last reply
            Reply Quote 0
            • stephenw10S
              Just had to google 'lumber room' as my first thought was something similar to a wood shed! I assume it's some storage area (is that common terminology?). If it's an attic area does it get hot in summer? If you make any mods to the cooling system make sure you can monitor the system temps and that you load test it.
              1 Reply Last reply
              Reply Quote 0
              • F
                FasTrak
                Yes, I believe you call it a small storage area room is not an attic is fully insulated small room 1,7m x 1,8m
                1 Reply Last reply
                Reply Quote 0
                • J
                  jasonlitka
                  @FasTrak:
                  I don't think you could cool that with a couple 40mm fans, at least not under load.
                  If that fan plugs into the motherboard with a standard 3-pin connector then your best bet would be something like a Zalman Fan Mate 2.
                  http://www.newegg.com/Product/Product.aspx?Item=N82E16835118217
                  1 Reply Last reply
                  Reply Quote 0
                  • F
                    FasTrak
                    I just found a setting in the bios called (server mode) it took 500 RPM of the fan speed.
                    Will try to see if this is not good enough or I will try to buy such a Zalman Fan Mate 2
                    Thanks for the link Jason Litka
                    1 Reply Last reply
                    Reply Quote 0
                    • stephenw10S
                      I was just going to suggest something similar. It would be surprising not to find some thermal fan control on the board. I'm having difficulty finding a manual for it though. The board specs suggest it might.
                      1 Reply Last reply
                      Reply Quote 0
                      • stephenw10S
                        Ok, found a manual.
                        Unfortunately it's still somewhat ambiguous. There appear to be two relevant settings but I would try using the 'workstation' profile, probably quieter than server, and 3-pin since your only fan appears to be 3pin.
                        Is the box mounted in a rack? If you have space above it you could probably improve the cooling considerably and make it quieter by fitting a much larger fan to the top panel above the heatsink. The existing cooling doesn't look great, you appear to have just one fan that blows across the heatsink (plus whatever is in the PSU). There are no fans extracting the hot air and no ducting after the heatsink to stop hot air being recirculated into the box. You have two full sized HDs and an 85W TDP processor that doesn't support any power saving.There seems to be quite a lot of room for improvement.  ;)
                        1 Reply Last reply
                        Reply Quote 0
                        Register Login
