    Issue with Deliberant CPE 2 EIRP Wireless System
    5 Posts 2 Posters 1.3k Views
    • P
      pfBlense
      I am having an issue with pfSense not being able to communicate through a Deliberant CPE 2. Initially everything will work fine but after a while the internet will just stop. I cannot ping out, either from my computer, or from pfSense. The internal network remains fine. I just loose all WAN access. In an effort to problem solve this I reinstalled pfSense multiple times with different configurations of Hard Drive and Swap Space. I also switched the WAN and LAN ports to make sure it was not the Ethernet card. My network configuration was as follows:
      Deliberant CPE 2 ===> pfSense (LAN 10.6.6.1) ===> LinkSys DD-WRT Switch (10.6.6.4) ===> LAN (DHCP: 10.6.6.10 - 150)
      Frustrated I decided to reconfigure my Network configuration back to the previous way and just have the pfSense box hooked up as a separate subnet though the LinkSys. Here is that configuration:
      Main Network:
      Deliberant CPE 2 ===> LinkSys DD-WRT Router/Gateway (10.6.6.1) ===> LAN (DHCP 10.6.6.10-149)
      pfSense Test Network
      Deliberant CPE 2 ===> LinkSys DD-WRT Router/Gateway (10.6.6.1) ===> pfSense (10.6.6.250) ===> LAN (10.1.1.1)
      I did this for testing purposes but the rest of my network is running through the DD-WRT Router/Gateway. With this configuration I have not had any issues with pfSense. I have had it running for a number of days and it has been solid and perfect. The only variable in all this is that pfSense has not has not had to do any work since I only have one computer hooked to the pfSense LAN up for testing purposes. All of this makes me think that there is some issue with the Deliberant CPE 2 and its communication with pfSense. Does anyone have any ideas?
      During this process I logged some unplug and plug events.
      Public IP = ?.?.?.?
      Public Gateway = &.&.&.&
      Unplug/Plug event Deliberant to pfSense:
      Unplugged 20:17:56
      Plugged 20:18:59
      Unplugged 20:20:56
      Plugged 20:21:58
      Oct 14 20:17:56	check_reload_status: Linkup starting fxp0
      Oct 14 20:17:56	kernel: fxp0: link state changed to DOWN
      Oct 14 20:17:58	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:18:59	check_reload_status: Linkup starting fxp0
      Oct 14 20:18:59	kernel: fxp0: link state changed to UP
      Oct 14 20:19:01	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:19:01	check_reload_status: rc.newwanip starting fxp0
      Oct 14 20:19:04	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 14 20:19:04	php: rc.newwanip: rc.newwanip: on (IP address: ?.?.?.?) (interface: WAN[wan]) (real interface: fxp0).
      Oct 14 20:19:04	check_reload_status: Reloading filter
      Oct 14 20:20:56	check_reload_status: Linkup starting fxp0
      Oct 14 20:20:56	kernel: fxp0: link state changed to DOWN
      Oct 14 20:20:58	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:21:58	check_reload_status: Linkup starting fxp0
      Oct 14 20:21:58	kernel: fxp0: link state changed to UP
      Oct 14 20:22:00	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:22:00	check_reload_status: rc.newwanip starting fxp0
      Oct 14 20:22:03	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 14 20:22:03	php: rc.newwanip: rc.newwanip: on (IP address: ?.?.?.?) (interface: WAN[wan]) (real interface: fxp0).
      Oct 14 20:22:03	check_reload_status: Reloading filter
      Unplug/Plug event DD-WRT to pfSense:
      Unplugged 20:57:00
      Plugged 20:58:01
      Unplugged 21:00:01
      Plugged 21:01:02
      Oct 14 20:57:00	check_reload_status: Linkup starting fxp0
      Oct 14 20:57:00	kernel: fxp0: link state changed to DOWN
      Oct 14 20:57:03	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (10.6.6.250 )
      Oct 14 20:57:20	check_reload_status: updating dyndns WANGW2
      Oct 14 20:57:20	check_reload_status: Restarting ipsec tunnels
      Oct 14 20:57:20	check_reload_status: Restarting OpenVPN tunnels/interfaces
      Oct 14 20:57:20	check_reload_status: Reloading filter
      Oct 14 20:58:01	check_reload_status: Linkup starting fxp0
      Oct 14 20:58:01	kernel: fxp0: link state changed to UP
      Oct 14 20:58:04	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (10.6.6.250 )
      Oct 14 20:58:04	check_reload_status: rc.newwanip starting fxp0
      Oct 14 20:58:06	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 14 20:58:06	php: rc.newwanip: rc.newwanip: on (IP address: 10.6.6.250) (interface: WAN[wan]) (real interface: fxp0).
      Oct 14 20:58:06	php: rc.newwanip: ROUTING: setting default route to 10.6.6.1
      Oct 14 20:58:11	php: rc.newwanip: Resyncing OpenVPN instances for interface WAN.
      Oct 14 20:58:11	php: rc.newwanip: Creating rrd update script
      Oct 14 20:58:11	check_reload_status: updating dyndns WANGW2
      Oct 14 20:58:11	check_reload_status: Restarting ipsec tunnels
      Oct 14 20:58:11	check_reload_status: Restarting OpenVPN tunnels/interfaces
      Oct 14 20:58:11	check_reload_status: Reloading filter
      Oct 14 20:58:13	php: rc.newwanip: pfSense package system has detected an ip change ?.?.?.? -> 10.6.6.250 ... Restarting packages.
      Oct 14 20:58:13	check_reload_status: Starting packages
      Oct 14 20:58:13	check_reload_status: Reloading filter
      Oct 14 20:58:16	php: rc.start_packages: Restarting/Starting all packages.
      Oct 14 21:00:01	check_reload_status: Linkup starting fxp0
      Oct 14 21:00:01	kernel: fxp0: link state changed to DOWN
      Oct 14 21:00:04	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (10.6.6.250 )
      Oct 14 21:00:21	check_reload_status: updating dyndns WANGW2
      Oct 14 21:00:21	check_reload_status: Restarting ipsec tunnels
      Oct 14 21:00:21	check_reload_status: Restarting OpenVPN tunnels/interfaces
      Oct 14 21:00:21	check_reload_status: Reloading filter
      Oct 14 21:01:02	check_reload_status: Linkup starting fxp0
      Oct 14 21:01:02	kernel: fxp0: link state changed to UP
      Oct 14 21:01:05	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (10.6.6.250 )
      Oct 14 21:01:05	check_reload_status: rc.newwanip starting fxp0
      Oct 14 21:01:07	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 14 21:01:07	php: rc.newwanip: rc.newwanip: on (IP address: 10.6.6.250) (interface: WAN[wan]) (real interface: fxp0).
      Oct 14 21:01:07	check_reload_status: Reloading filter
      Oct 14 21:01:12	check_reload_status: updating dyndns WANGW2
      Oct 14 21:01:12	check_reload_status: Restarting ipsec tunnels
      Oct 14 21:01:12	check_reload_status: Restarting OpenVPN tunnels/interfaces
      Oct 14 21:01:12	check_reload_status: Reloading filter
      In addition here are all the syslog files from the last install with Deliberant to pfSense hookup:
      Oct 13 22:08:36	kernel: cpu0 (BSP): APIC ID: 0
      Oct 13 22:08:36	kernel: cpu1 (AP/HT): APIC ID: 1
      Oct 13 22:08:36	kernel: ioapic0 <version 2.0=""> irqs 0-23 on motherboard
      Oct 13 22:08:36	kernel: wlan: mac acl policy registered
      Oct 13 22:08:36	kernel: kbd1 at kbdmux0
      Oct 13 22:08:36	kernel: cryptosoft0: <software crypto=""> on motherboard
      Oct 13 22:08:36	kernel: padlock0: No ACE support.
      Oct 13 22:08:36	kernel: acpi0: <a m="" i="" oemxsdt="">on motherboard
      Oct 13 22:08:36	kernel: acpi0: [ITHREAD]
      Oct 13 22:08:36	kernel: acpi0: Power Button (fixed)
      Oct 13 22:08:36	kernel: acpi0: reservation of 0, a0000 (3) failed
      Oct 13 22:08:36	kernel: acpi0: reservation of 100000, 5fef0000 (3) failed
      Oct 13 22:08:36	kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
      Oct 13 22:08:36	kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
      Oct 13 22:08:36	kernel: cpu0: <acpi cpu="">on acpi0
      Oct 13 22:08:36	kernel: cpu1: <acpi cpu="">on acpi0
      Oct 13 22:08:36	kernel: pcib0: <acpi host-pci="" bridge="">port 0xcf8-0xcff on acpi0
      Oct 13 22:08:36	kernel: pci0: <acpi pci="" bus="">on pcib0
      Oct 13 22:08:36	kernel: agp0: <intel 82865="" host="" to="" agp="" bridge="">on hostb0
      Oct 13 22:08:36	kernel: pcib1: <acpi pci-pci="" bridge="">at device 1.0 on pci0
      Oct 13 22:08:36	kernel: pci1: <acpi pci="" bus="">on pcib1
      Oct 13 22:08:36	kernel: vgapci0: <vga-compatible display="">port 0xc000-0xc0ff mem 0xc0000000-0xcfffffff,0xfe8f0000-0xfe8fffff irq 16 at device 0.0 on pci1
      Oct 13 22:08:36	kernel: pci1: <multimedia, hda="">at device 0.1 (no driver attached)
      Oct 13 22:08:36	kernel: uhci0: <intel 82801eb="" (ich5)="" usb="" controller="" usb-a="">port 0xeec0-0xeedf irq 16 at device 29.0 on pci0
      Oct 13 22:08:36	kernel: uhci0: [ITHREAD]
      Oct 13 22:08:36	kernel: usbus0: <intel 82801eb="" (ich5)="" usb="" controller="" usb-a="">on uhci0
      Oct 13 22:08:36	kernel: uhci1: <intel 82801eb="" (ich5)="" usb="" controller="" usb-b="">port 0xef20-0xef3f irq 19 at device 29.1 on pci0
      Oct 13 22:08:36	kernel: uhci1: [ITHREAD]
      Oct 13 22:08:36	kernel: usbus1: <intel 82801eb="" (ich5)="" usb="" controller="" usb-b="">on uhci1
      Oct 13 22:08:36	kernel: uhci2: <intel 82801eb="" (ich5)="" usb="" controller="" usb-c="">port 0xef40-0xef5f irq 18 at device 29.2 on pci0
      Oct 13 22:08:36	kernel: uhci2: [ITHREAD]
      Oct 13 22:08:36	kernel: usbus2: <intel 82801eb="" (ich5)="" usb="" controller="" usb-c="">on uhci2
      Oct 13 22:08:36	kernel: uhci3: <intel 82801eb="" (ich5)="" usb="" controller="" usb-d="">port 0xef80-0xef9f irq 16 at device 29.3 on pci0
      Oct 13 22:08:36	kernel: uhci3: [ITHREAD]
      Oct 13 22:08:36	kernel: usbus3: <intel 82801eb="" (ich5)="" usb="" controller="" usb-d="">on uhci3
      Oct 13 22:08:37	kernel: ehci0: <intel 82801eb="" r="" (ich5)="" usb="" 2.0="" controller="">mem 0xfebffc00-0xfebfffff irq 23 at device 29.7 on pci0
      Oct 13 22:08:37	kernel: ehci0: [ITHREAD]
      Oct 13 22:08:37	kernel: usbus4: EHCI version 1.0
      Oct 13 22:08:37	kernel: usbus4: <intel 82801eb="" r="" (ich5)="" usb="" 2.0="" controller="">on ehci0
      Oct 13 22:08:37	kernel: pcib2: <acpi pci-pci="" bridge="">at device 30.0 on pci0
      Oct 13 22:08:37	kernel: pci2: <acpi pci="" bus="">on pcib2
      Oct 13 22:08:37	kernel: fxp0: <intel 100="" 82801ba="" (d865)="" pro="" ve="" ethernet="">port 0xdf00-0xdf3f mem 0xfeaff000-0xfeafffff irq 20 at device 8.0 on pci2
      Oct 13 22:08:37	kernel: miibus0: <mii bus="">on fxp0
      Oct 13 22:08:37	kernel: inphy0: <i82562et 10="" 100="" media="" interface="">PHY 1 on miibus0
      Oct 13 22:08:37	kernel: inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto, auto-flow
      Oct 13 22:08:37	kernel: fxp0: [ITHREAD]
      Oct 13 22:08:37	kernel: em0: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6="">port 0xde80-0xdebf mem 0xfeac0000-0xfeadffff,0xfeaa0000-0xfeabffff irq 17 at device 9.0 on pci2
      Oct 13 22:08:37	kernel: em0: [FILTER]
      Oct 13 22:08:37	kernel: em1: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6="">port 0xdd80-0xddbf mem 0xfea60000-0xfea7ffff,0xfea40000-0xfea5ffff irq 21 at device 10.0 on pci2
      Oct 13 22:08:37	kernel: em1: [FILTER]
      Oct 13 22:08:37	kernel: isab0: <pci-isa bridge="">at device 31.0 on pci0
      Oct 13 22:08:37	kernel: isa0: <isa bus="">on isab0
      Oct 13 22:08:37	kernel: atapci0: <intel ich5="" udma100="" controller="">port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfc00-0xfc0f at device 31.1 on pci0
      Oct 13 22:08:37	kernel: ata0: <ata channel="">at channel 0 on atapci0
      Oct 13 22:08:37	kernel: ata0: [ITHREAD]
      Oct 13 22:08:37	kernel: ata1: <ata channel="">at channel 1 on atapci0
      Oct 13 22:08:37	kernel: ata1: [ITHREAD]
      Oct 13 22:08:37	kernel: pci0: <serial bus,="" smbus="">at device 31.3 (no driver attached)
      Oct 13 22:08:37	kernel: pci0: <multimedia, audio="">at device 31.5 (no driver attached)
      Oct 13 22:08:37	kernel: acpi_button0: <power button="">on acpi0
      Oct 13 22:08:37	kernel: atrtc0: <at realtime="" clock="">port 0x70-0x71 irq 8 on acpi0
      Oct 13 22:08:37	kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      Oct 13 22:08:37	kernel: uart0: [FILTER]
      Oct 13 22:08:37	kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
      Oct 13 22:08:37	kernel: uart1: [FILTER]
      Oct 13 22:08:37	kernel: pmtimer0 on isa0
      Oct 13 22:08:37	kernel: orm0: <isa option="" roms="">at iomem 0xcf800-0xd07ff,0xd0800-0xd17ff pnpid ORM0000 on isa0
      Oct 13 22:08:37	kernel: sc0: <system console="">at flags 0x100 on isa0
      Oct 13 22:08:37	kernel: sc0: VGA <16 virtual consoles, flags=0x300>
      Oct 13 22:08:37	kernel: vga0: <generic isa="" vga="">at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
      Oct 13 22:08:37	kernel: atkbdc0: <keyboard controller="" (i8042)="">at port 0x60,0x64 on isa0
      Oct 13 22:08:37	kernel: atkbd0: <at keyboard="">irq 1 on atkbdc0
      Oct 13 22:08:37	kernel: kbd0 at atkbd0
      Oct 13 22:08:37	kernel: atkbd0: [GIANT-LOCKED]
      Oct 13 22:08:37	kernel: atkbd0: [ITHREAD]
      Oct 13 22:08:37	kernel: ppc0: parallel port not found.
      Oct 13 22:08:37	kernel: p4tcc0: <cpu frequency="" thermal="" control="">on cpu0
      Oct 13 22:08:37	kernel: p4tcc1: <cpu frequency="" thermal="" control="">on cpu1
      Oct 13 22:08:37	kernel: Timecounters tick every 1.000 msec
      Oct 13 22:08:37	kernel: IPsec: Initialized Security Association Processing.
      Oct 13 22:08:37	kernel: usbus0: 12Mbps Full Speed USB v1.0
      Oct 13 22:08:37	kernel: usbus1: 12Mbps Full Speed USB v1.0
      Oct 13 22:08:37	kernel: usbus2: 12Mbps Full Speed USB v1.0
      Oct 13 22:08:37	kernel: usbus3: 12Mbps Full Speed USB v1.0
      Oct 13 22:08:37	kernel: usbus4: 480Mbps High Speed USB v2.0
      Oct 13 22:08:37	kernel: ata0: DMA limited to UDMA33, controller found non-ATA66 cable
      Oct 13 22:08:37	kernel: ugen0.1: <intel>at usbus0
      Oct 13 22:08:37	kernel: uhub0: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus0
      Oct 13 22:08:37	kernel: ugen1.1: <intel>at usbus1
      Oct 13 22:08:37	kernel: uhub1: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus1
      Oct 13 22:08:37	kernel: ugen2.1: <intel>at usbus2
      Oct 13 22:08:37	kernel: uhub2: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus2
      Oct 13 22:08:37	kernel: ugen3.1: <intel>at usbus3
      Oct 13 22:08:37	kernel: uhub3: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus3
      Oct 13 22:08:37	kernel: ugen4.1: <intel>at usbus4
      Oct 13 22:08:37	kernel: uhub4: <intel 1="" 9="" ehci="" root="" hub,="" class="" 0,="" rev="" 2.00="" 1.00,="" addr="">on usbus4
      Oct 13 22:08:37	kernel: ad0: 114473MB <wdc wd1200jb-00eva0="" 15.05r15="">at ata0-master UDMA33
      Oct 13 22:08:37	kernel: acd0: CDRW <lite-on combo="" sohc-4832k="" oqkb="">at ata0-slave UDMA33
      Oct 13 22:08:37	kernel: SMP: AP CPU #1 Launched!
      Oct 13 22:08:37	kernel: uhub0: 2 ports with 2 removable, self powered
      Oct 13 22:08:37	kernel: uhub1: 2 ports with 2 removable, self powered
      Oct 13 22:08:37	kernel: uhub2: 2 ports with 2 removable, self powered
      Oct 13 22:08:37	kernel: uhub3: 2 ports with 2 removable, self powered
      Oct 13 22:08:37	kernel: Root mount waiting for: usbus4
      Oct 13 22:08:37	kernel: uhub4: 8 ports with 8 removable, self powered
      Oct 13 22:08:37	kernel: Trying to mount root from ufs:/dev/ad0s1a
      Oct 13 22:08:37	kernel: ugen3.2: <microsoft>at usbus3
      Oct 13 22:08:37	kernel: ukbd0: <microsoft 0="" 2="" microsoft="" digital="" media="" oard="" 3000,="" class="" 0,="" rev="" 2.00="" 2.00,="" addr="">on usbus3
      Oct 13 22:08:37	kernel: kbd2 at ukbd0
      Oct 13 22:08:37	kernel: uhid0: <microsoft 0="" 2="" microsoft="" digital="" media="" oard="" 3000,="" class="" 0,="" rev="" 2.00="" 2.00,="" addr="">on usbus3
      Oct 13 22:08:37	kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
      Oct 13 22:08:37	kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
      Oct 13 22:08:37	kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
      Oct 13 22:08:37	kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
      Oct 13 22:08:37	kernel: in /boot/loader.conf.
      Oct 13 22:08:37	kernel: ZFS filesystem version 5
      Oct 13 22:08:37	kernel: ZFS storage pool version 28
      Oct 13 22:08:37	kernel: fxp0: link state changed to DOWN
      Oct 13 22:08:37	kernel: pflog0: promiscuous mode enabled
      Oct 13 22:08:36	check_reload_status: Linkup starting fxp0
      Oct 13 22:08:36	php: rc.bootup: Resyncing OpenVPN instances.
      Oct 13 22:08:38	check_reload_status: Linkup starting em0
      Oct 13 22:08:38	kernel: em0: link state changed to UP
      Oct 13 22:08:40	php: rc.bootup: ROUTING: setting default route to &.&.&.&
      Oct 13 22:08:41	check_reload_status: Updating all dyndns
      Oct 13 22:08:46	php: rc.bootup: Creating rrd update script
      Oct 13 22:08:46	syslogd: exiting on signal 15
      Oct 13 22:08:46	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 13 22:08:47	php: rc.start_packages: Restarting/Starting all packages.
      Oct 13 22:08:48	login: login on ttyv0 as root
      Oct 13 22:08:48	sshlockout[59748]: sshlockout/webConfigurator v3.0 starting up
      Oct 13 22:08:58	check_reload_status: updating dyndns WANGW
      Oct 13 22:08:58	check_reload_status: Restarting ipsec tunnels
      Oct 13 22:08:58	check_reload_status: Restarting OpenVPN tunnels/interfaces
      Oct 13 22:08:58	check_reload_status: Reloading filter
      Oct 13 22:09:40	php: /index.php: Successful login for user 'admin' from: 10.6.6.14
      Oct 13 22:17:31	check_reload_status: Syncing firewall
      Oct 13 22:17:34	php: /system_gateways.php: ROUTING: setting default route to &.&.&.&
      Oct 13 22:17:34	check_reload_status: Reloading filter
      Oct 13 22:18:03	check_reload_status: Linkup starting fxp0
      Oct 13 22:18:03	kernel: fxp0: link state changed to UP
      Oct 13 22:18:05	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 13 22:18:05	check_reload_status: rc.newwanip starting fxp0
      Oct 13 22:18:08	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 13 22:18:08	php: rc.newwanip: rc.newwanip: on (IP address: ?.?.?.?) (interface: WAN[wan]) (real interface: fxp0).
      Oct 13 22:18:08	php: rc.newwanip: ROUTING: setting default route to &.&.&.&
      Oct 13 22:18:15	php: rc.newwanip: Resyncing OpenVPN instances for interface WAN.
      Oct 13 22:18:15	php: rc.newwanip: Creating rrd update script
      Oct 13 22:18:17	php: rc.newwanip: pfSense package system has detected an ip change 0.0.0.0 -> ?.?.?.? ... Restarting packages.
      Oct 13 22:18:17	check_reload_status: Starting packages
      Oct 13 22:18:17	check_reload_status: Reloading filter
      Oct 13 22:18:19	php: rc.start_packages: Restarting/Starting all packages.
      Oct 13 22:19:09	php: /reboot.php: Stopping all packages.
      Oct 13 22:19:11	shutdown: reboot by root:
      Oct 13 22:19:13	syslogd: exiting on signal 15
      Oct 13 22:20:30	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 13 22:20:30	kernel: pflog0: promiscuous mode disabled
      Oct 13 22:20:30	kernel: Waiting (max 60 seconds) for system process `vnlru' to stop...done
      Oct 13 22:20:30	kernel: Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
      Oct 13 22:20:30	kernel: Waiting (max 60 seconds) for system process `syncer' to stop...
      Oct 13 22:20:30	kernel: Syncing disks, vnodes remaining...0 0 done
      Oct 13 22:20:30	kernel: All buffers synced.
      Oct 13 22:20:30	kernel: Copyright (c) 1992-2012 The FreeBSD Project.
      Oct 13 22:20:30	kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
      Oct 13 22:20:30	kernel: The Regents of the University of California. All rights reserved.
      Oct 13 22:20:30	kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
      Oct 13 22:20:30	kernel: FreeBSD 8.3-RELEASE-p16 #0: Mon Aug 25 08:25:41 EDT 2014
      Oct 13 22:20:30	kernel: root@pf2_1_1_i386.pfsense.org:/usr/obj.i386/usr/pfSensesrc/src/sys/pfSense_SMP.8 i386
      Oct 13 22:20:30	kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
      Oct 13 22:20:30	kernel: CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz (3192.02-MHz 686-class CPU)
      Oct 13 22:20:30	kernel: Origin = "GenuineIntel" Id = 0xf41 Family = f Model = 4 Stepping = 1
      Oct 13 22:20:30	kernel: Features=0xbfebfbff <fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,htt,tm,pbe>Oct 13 22:20:30	kernel: Features2=0x441d <sse3,dtes64,mon,ds_cpl,cnxt-id,xtpr>Oct 13 22:20:30	kernel: TSC: P-state invariant
      Oct 13 22:20:30	kernel: real memory = 1610612736 (1536 MB)
      Oct 13 22:20:30	kernel: avail memory = 1554141184 (1482 MB)
      Oct 13 22:20:30	kernel: ACPI APIC Table:</sse3,dtes64,mon,ds_cpl,cnxt-id,xtpr></fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,htt,tm,pbe></microsoft></microsoft></microsoft></lite-on></wdc></intel></intel></intel></intel></intel></intel></intel></intel></intel></intel></cpu></cpu></at></keyboard></generic></system></isa></at></power></multimedia,></serial></ata></ata></intel></isa></pci-isa></intel(r)></intel(r)></i82562et></mii></intel></acpi></acpi></intel></intel></intel></intel></intel></intel></intel></intel></intel></intel></multimedia,></vga-compatible></acpi></acpi></intel></acpi></acpi></acpi></acpi></a> <a m="" i="" oemapic="">
      Oct 13 22:20:30	kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
      Oct 13 22:20:30	kernel: FreeBSD/SMP: 1 package(s) x 1 core(s) x 2 HTT threads
      Oct 13 22:20:30	kernel: cpu0 (BSP): APIC ID: 0
      Oct 13 22:20:30	kernel: cpu1 (AP/HT): APIC ID: 1
      Oct 13 22:20:30	kernel: ioapic0 <version 2.0="">irqs 0-23 on motherboard
      Oct 13 22:20:30	kernel: wlan: mac acl policy registered
      Oct 13 22:20:30	kernel: kbd1 at kbdmux0
      Oct 13 22:20:30	kernel: cryptosoft0: <software crypto="">on motherboard
      Oct 13 22:20:30	kernel: padlock0: No ACE support.
      Oct 13 22:20:30	kernel: acpi0:</software></version> </a><a m="" i="" oemxsdt="">on motherboard
      Oct 13 22:20:30	kernel: acpi0: [ITHREAD]
      Oct 13 22:20:30	kernel: acpi0: Power Button (fixed)
      Oct 13 22:20:30	kernel: acpi0: reservation of 0, a0000 (3) failed
      Oct 13 22:20:30	kernel: acpi0: reservation of 100000, 5fef0000 (3) failed
      Oct 13 22:20:30	kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
      Oct 13 22:20:30	kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
      Oct 13 22:20:30	kernel: cpu0: <acpi cpu="">on acpi0
      Oct 13 22:20:30	kernel: cpu1: <acpi cpu="">on acpi0
      Oct 13 22:20:30	kernel: pcib0: <acpi host-pci="" bridge="">port 0xcf8-0xcff on acpi0
      Oct 13 22:20:30	kernel: pci0: <acpi pci="" bus="">on pcib0
      Oct 13 22:20:30	kernel: agp0: <intel 82865="" host="" to="" agp="" bridge="">on hostb0
      Oct 13 22:20:30	kernel: pcib1: <acpi pci-pci="" bridge="">at device 1.0 on pci0
      Oct 13 22:20:30	kernel: pci1: <acpi pci="" bus="">on pcib1
      Oct 13 22:20:30	kernel: vgapci0: <vga-compatible display="">port 0xc000-0xc0ff mem 0xc0000000-0xcfffffff,0xfe8f0000-0xfe8fffff irq 16 at device 0.0 on pci1
      Oct 13 22:20:30	kernel: pci1: <multimedia, hda="">at device 0.1 (no driver attached)
      Oct 13 22:20:30	kernel: uhci0: <intel 82801eb="" (ich5)="" usb="" controller="" usb-a="">port 0xeec0-0xeedf irq 16 at device 29.0 on pci0
      Oct 13 22:20:30	kernel: uhci0: [ITHREAD]
      Oct 13 22:20:30	kernel: usbus0: <intel 82801eb="" (ich5)="" usb="" controller="" usb-a="">on uhci0
      Oct 13 22:20:30	kernel: uhci1: <intel 82801eb="" (ich5)="" usb="" controller="" usb-b="">port 0xef20-0xef3f irq 19 at device 29.1 on pci0
      Oct 13 22:20:30	kernel: uhci1: [ITHREAD]
      Oct 13 22:20:30	kernel: usbus1: <intel 82801eb="" (ich5)="" usb="" controller="" usb-b="">on uhci1
      Oct 13 22:20:30	kernel: uhci2: <intel 82801eb="" (ich5)="" usb="" controller="" usb-c="">port 0xef40-0xef5f irq 18 at device 29.2 on pci0
      Oct 13 22:20:30	kernel: uhci2: [ITHREAD]
      Oct 13 22:20:30	kernel: usbus2: <intel 82801eb="" (ich5)="" usb="" controller="" usb-c="">on uhci2
      Oct 13 22:20:30	kernel: uhci3: <intel 82801eb="" (ich5)="" usb="" controller="" usb-d="">port 0xef80-0xef9f irq 16 at device 29.3 on pci0
      Oct 13 22:20:30	kernel: uhci3: [ITHREAD]
      Oct 13 22:20:30	kernel: usbus3: <intel 82801eb="" (ich5)="" usb="" controller="" usb-d="">on uhci3
      Oct 13 22:20:30	kernel: ehci0: <intel 82801eb="" r="" (ich5)="" usb="" 2.0="" controller="">mem 0xfebffc00-0xfebfffff irq 23 at device 29.7 on pci0
      Oct 13 22:20:30	kernel: ehci0: [ITHREAD]
      Oct 13 22:20:30	kernel: usbus4: EHCI version 1.0
      Oct 13 22:20:30	kernel: usbus4: <intel 82801eb="" r="" (ich5)="" usb="" 2.0="" controller="">on ehci0
      Oct 13 22:20:30	kernel: pcib2: <acpi pci-pci="" bridge="">at device 30.0 on pci0
      Oct 13 22:20:30	kernel: pci2: <acpi pci="" bus="">on pcib2
      Oct 13 22:20:30	kernel: fxp0: <intel 100="" 82801ba="" (d865)="" pro="" ve="" ethernet="">port 0xdf00-0xdf3f mem 0xfeaff000-0xfeafffff irq 20 at device 8.0 on pci2
      Oct 13 22:20:30	kernel: miibus0: <mii bus="">on fxp0
      Oct 13 22:20:30	kernel: inphy0: <i82562et 10="" 100="" media="" interface="">PHY 1 on miibus0
      Oct 13 22:20:30	kernel: inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto, auto-flow
      Oct 13 22:20:30	kernel: fxp0: [ITHREAD]
      Oct 13 22:20:30	kernel: em0: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6="">port 0xde80-0xdebf mem 0xfeac0000-0xfeadffff,0xfeaa0000-0xfeabffff irq 17 at device 9.0 on pci2
      Oct 13 22:20:30	kernel: em0: [FILTER]
      Oct 13 22:20:30	kernel: em1: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6="">port 0xdd80-0xddbf mem 0xfea60000-0xfea7ffff,0xfea40000-0xfea5ffff irq 21 at device 10.0 on pci2
      Oct 13 22:20:30	kernel: em1: [FILTER]
      Oct 13 22:20:30	kernel: isab0: <pci-isa bridge="">at device 31.0 on pci0
      Oct 13 22:20:30	kernel: isa0: <isa bus="">on isab0
      Oct 13 22:20:30	kernel: atapci0: <intel ich5="" udma100="" controller="">port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfc00-0xfc0f at device 31.1 on pci0
      Oct 13 22:20:30	kernel: ata0: <ata channel="">at channel 0 on atapci0
      Oct 13 22:20:30	kernel: ata0: [ITHREAD]
      Oct 13 22:20:30	kernel: ata1: <ata channel="">at channel 1 on atapci0
      Oct 13 22:20:30	kernel: ata1: [ITHREAD]
      Oct 13 22:20:30	kernel: pci0: <serial bus,="" smbus="">at device 31.3 (no driver attached)
      Oct 13 22:20:30	kernel: pci0: <multimedia, audio="">at device 31.5 (no driver attached)
      Oct 13 22:20:30	kernel: acpi_button0: <power button="">on acpi0
      Oct 13 22:20:30	kernel: atrtc0: <at realtime="" clock="">port 0x70-0x71 irq 8 on acpi0
      Oct 13 22:20:30	kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      Oct 13 22:20:30	kernel: uart0: [FILTER]
      Oct 13 22:20:30	kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
      Oct 13 22:20:30	kernel: uart1: [FILTER]
      Oct 13 22:20:30	kernel: pmtimer0 on isa0
      Oct 13 22:20:30	kernel: orm0: <isa option="" roms="">at iomem 0xcf800-0xd07ff,0xd0800-0xd17ff pnpid ORM0000 on isa0
      Oct 13 22:20:30	kernel: sc0: <system console="">at flags 0x100 on isa0
      Oct 13 22:20:30	kernel: sc0: VGA <16 virtual consoles, flags=0x300>
      Oct 13 22:20:30	kernel: vga0: <generic isa="" vga="">at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
      Oct 13 22:20:30	kernel: atkbdc0: <keyboard controller="" (i8042)="">at port 0x60,0x64 on isa0
      Oct 13 22:20:30	kernel: atkbd0: <at keyboard="">irq 1 on atkbdc0
      Oct 13 22:20:30	kernel: kbd0 at atkbd0
      Oct 13 22:20:30	kernel: atkbd0: [GIANT-LOCKED]
      Oct 13 22:20:30	kernel: atkbd0: [ITHREAD]
      Oct 13 22:20:30	kernel: ppc0: parallel port not found.
      Oct 13 22:20:30	kernel: p4tcc0: <cpu frequency="" thermal="" control="">on cpu0
      Oct 13 22:20:30	kernel: p4tcc1: <cpu frequency="" thermal="" control="">on cpu1
      Oct 13 22:20:30	kernel: Timecounters tick every 1.000 msec
      Oct 13 22:20:30	kernel: IPsec: Initialized Security Association Processing.
      Oct 13 22:20:30	kernel: usbus0: 12Mbps Full Speed USB v1.0
      Oct 13 22:20:30	kernel: usbus1: 12Mbps Full Speed USB v1.0
      Oct 13 22:20:30	kernel: usbus2: 12Mbps Full Speed USB v1.0
      Oct 13 22:20:30	kernel: usbus3: 12Mbps Full Speed USB v1.0
      Oct 13 22:20:30	kernel: usbus4: 480Mbps High Speed USB v2.0
      Oct 13 22:20:30	kernel: ata0: DMA limited to UDMA33, controller found non-ATA66 cable
      Oct 13 22:20:30	kernel: ugen0.1: <intel>at usbus0
      Oct 13 22:20:30	kernel: uhub0: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus0
      Oct 13 22:20:30	kernel: ugen1.1: <intel>at usbus1
      Oct 13 22:20:30	kernel: uhub1: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus1
      Oct 13 22:20:30	kernel: ugen2.1: <intel>at usbus2
      Oct 13 22:20:30	kernel: uhub2: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus2
      Oct 13 22:20:30	kernel: ugen3.1: <intel>at usbus3
      Oct 13 22:20:30	kernel: uhub3: <intel 1="" 9="" uhci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usbus3
      Oct 13 22:20:30	kernel: ugen4.1: <intel>at usbus4
      Oct 13 22:20:30	kernel: uhub4: <intel 1="" 9="" ehci="" root="" hub,="" class="" 0,="" rev="" 2.00="" 1.00,="" addr="">on usbus4
      Oct 13 22:20:30	kernel: ad0: 114473MB <wdc wd1200jb-00eva0="" 15.05r15="">at ata0-master UDMA33
      Oct 13 22:20:30	kernel: acd0: CDRW <lite-on combo="" sohc-4832k="" oqkb="">at ata0-slave UDMA33
      Oct 13 22:20:30	kernel: SMP: AP CPU #1 Launched!
      Oct 13 22:20:30	kernel: uhub0: 2 ports with 2 removable, self powered
      Oct 13 22:20:30	kernel: uhub1: 2 ports with 2 removable, self powered
      Oct 13 22:20:30	kernel: uhub2: 2 ports with 2 removable, self powered
      Oct 13 22:20:30	kernel: uhub3: 2 ports with 2 removable, self powered
      Oct 13 22:20:30	kernel: Root mount waiting for: usbus4
      Oct 13 22:20:30	kernel: uhub4: 8 ports with 8 removable, self powered
      Oct 13 22:20:30	kernel: Trying to mount root from ufs:/dev/ad0s1a
      Oct 13 22:20:30	kernel: ugen3.2: <microsoft>at usbus3
      Oct 13 22:20:30	kernel: ukbd0: <microsoft 0="" 2="" microsoft="" digital="" media="" oard="" 3000,="" class="" 0,="" rev="" 2.00="" 2.00,="" addr="">on usbus3
      Oct 13 22:20:30	kernel: kbd2 at ukbd0
      Oct 13 22:20:30	kernel: uhid0: <microsoft 0="" 2="" microsoft="" digital="" media="" oard="" 3000,="" class="" 0,="" rev="" 2.00="" 2.00,="" addr="">on usbus3
      Oct 13 22:20:30	kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
      Oct 13 22:20:30	kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
      Oct 13 22:20:30	kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
      Oct 13 22:20:30	kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
      Oct 13 22:20:30	kernel: in /boot/loader.conf.
      Oct 13 22:20:30	kernel: ZFS filesystem version 5
      Oct 13 22:20:30	kernel: ZFS storage pool version 28
      Oct 13 22:20:30	kernel: fxp0: link state changed to DOWN
      Oct 13 22:20:30	kernel: pflog0: promiscuous mode enabled
      Oct 13 22:20:30	check_reload_status: Linkup starting fxp0
      Oct 13 22:20:30	php: rc.bootup: Resyncing OpenVPN instances.
      Oct 13 22:20:32	check_reload_status: Linkup starting em0
      Oct 13 22:20:32	kernel: em0: link state changed to UP
      Oct 13 22:20:32	check_reload_status: Linkup starting fxp0
      Oct 13 22:20:32	kernel: fxp0: link state changed to UP
      Oct 13 22:20:34	php: rc.bootup: ROUTING: setting default route to &.&.&.&
      Oct 13 22:20:36	check_reload_status: Updating all dyndns
      Oct 13 22:20:40	php: rc.bootup: Creating rrd update script
      Oct 13 22:20:41	syslogd: exiting on signal 15
      Oct 13 22:20:41	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 13 22:20:41	php: rc.start_packages: Restarting/Starting all packages.
      Oct 13 22:20:43	login: login on ttyv0 as root
      Oct 13 22:20:43	sshlockout[57713]: sshlockout/webConfigurator v3.0 starting up
      Oct 13 22:27:44	php: /index.php: Successful login for user 'admin' from: 10.6.6.15
      Oct 13 22:36:58	check_reload_status: Linkup starting fxp0
      Oct 13 22:36:58	kernel: fxp0: link state changed to DOWN
      Oct 13 22:37:01	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 13 22:37:05	check_reload_status: Linkup starting em0
      Oct 13 22:37:05	kernel: em0: link state changed to DOWN
      Oct 13 22:37:08	php: rc.linkup: DEVD Ethernet detached event for lan
      Oct 13 23:13:05	check_reload_status: Linkup starting em0
      Oct 13 23:13:05	kernel: em0: link state changed to UP
      Oct 13 23:13:07	php: rc.linkup: DEVD Ethernet attached event for lan
      Oct 13 23:13:07	php: rc.linkup: HOTPLUG: Configuring interface lan
      Oct 13 23:13:12	check_reload_status: updating dyndns lan
      Oct 13 23:45:03	check_reload_status: Linkup starting em0
      Oct 13 23:45:03	kernel: em0: link state changed to DOWN
      Oct 13 23:45:05	php: rc.linkup: DEVD Ethernet detached event for lan
      Oct 14 00:57:55	syslogd: exiting on signal 15
      Oct 14 20:14:48	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 14 20:14:48	kernel: Copyright (c) 1992-2012 The FreeBSD Project.
      Oct 14 20:14:48	kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
      Oct 14 20:14:48	kernel: The Regents of the University of California. All rights reserved.
      Oct 14 20:14:48	kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
      Oct 14 20:14:48	kernel: FreeBSD 8.3-RELEASE-p16 #0: Mon Aug 25 08:25:41 EDT 2014
      Oct 14 20:14:48	kernel: root@pf2_1_1_i386.pfsense.org:/usr/obj.i386/usr/pfSensesrc/src/sys/pfSense_SMP.8 i386
      Oct 14 20:14:48	kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
      Oct 14 20:14:48	kernel: CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz (3192.01-MHz 686-class CPU)
      Oct 14 20:14:48	kernel: Origin = "GenuineIntel" Id = 0xf41 Family = f Model = 4 Stepping = 1
      Oct 14 20:14:48	kernel: Features=0xbfebfbff <fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,htt,tm,pbe>Oct 14 20:14:48	kernel: Features2=0x441d <sse3,dtes64,mon,ds_cpl,cnxt-id,xtpr>Oct 14 20:14:48	kernel: TSC: P-state invariant
      Oct 14 20:14:48	kernel: real memory = 1610612736 (1536 MB)
      Oct 14 20:14:48	kernel: avail memory = 1554141184 (1482 MB)
      Oct 14 20:14:48	kernel: ACPI APIC Table:</sse3,dtes64,mon,ds_cpl,cnxt-id,xtpr></fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,htt,tm,pbe></microsoft></microsoft></microsoft></lite-on></wdc></intel></intel></intel></intel></intel></intel></intel></intel></intel></intel></cpu></cpu></at></keyboard></generic></system></isa></at></power></multimedia,></serial></ata></ata></intel></isa></pci-isa></intel(r)></intel(r)></i82562et></mii></intel></acpi></acpi></intel></intel></intel></intel></intel></intel></intel></intel></intel></intel></multimedia,></vga-compatible></acpi></acpi></intel></acpi></acpi></acpi></acpi></a> <a m="" i="" oemapic="">
      Oct 14 20:14:48	kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
      Oct 14 20:14:48	kernel: FreeBSD/SMP: 1 package(s) x 1 core(s) x 2 HTT threads
      Oct 14 20:14:48	kernel: cpu0 (BSP): APIC ID: 0
      Oct 14 20:14:48	kernel: cpu1 (AP/HT): APIC ID: 1
      Oct 14 20:14:48	kernel: ioapic0 <version 2.0="">irqs 0-23 on motherboard
      Oct 14 20:14:48	kernel: wlan: mac acl policy registered
      Oct 14 20:14:48	kernel: kbd1 at kbdmux0
      Oct 14 20:14:48	kernel: cryptosoft0: <software crypto="">on motherboard
      Oct 14 20:14:48	kernel: padlock0: No ACE support.
      Oct 14 20:14:48	kernel: acpi0:</software></version> </a><a m="" i="" oemxsdt=""> on motherboard
      Oct 14 20:14:48	kernel: acpi0: [ITHREAD]
      Oct 14 20:14:48	kernel: acpi0: Power Button (fixed)
      Oct 14 20:14:48	kernel: acpi0: reservation of 0, a0000 (3) failed
      Oct 14 20:14:48	kernel: acpi0: reservation of 100000, 5fef0000 (3) failed
      Oct 14 20:14:48	kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
      Oct 14 20:14:48	kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
      Oct 14 20:14:48	kernel: cpu0: <acpi cpu=""> on acpi0
      Oct 14 20:14:48	kernel: cpu1: <acpi cpu=""> on acpi0
      Oct 14 20:14:48	kernel: pcib0: <acpi host-pci="" bridge=""> port 0xcf8-0xcff on acpi0
      Oct 14 20:14:48	kernel: pci0: <acpi pci="" bus=""> on pcib0
      Oct 14 20:14:48	kernel: agp0: <intel 82865="" host="" to="" agp="" bridge=""> on hostb0
      Oct 14 20:14:48	kernel: pcib1: <acpi pci-pci="" bridge=""> at device 1.0 on pci0
      Oct 14 20:14:48	kernel: pci1: <acpi pci="" bus=""> on pcib1
      Oct 14 20:14:48	kernel: vgapci0: <vga-compatible display=""> port 0xc000-0xc0ff mem 0xc0000000-0xcfffffff,0xfe8f0000-0xfe8fffff irq 16 at device 0.0 on pci1
      Oct 14 20:14:48	kernel: pci1: <multimedia, hda=""> at device 0.1 (no driver attached)
      Oct 14 20:14:48	kernel: pcib2: <acpi pci-pci="" bridge=""> at device 30.0 on pci0
      Oct 14 20:14:48	kernel: pci2: <acpi pci="" bus=""> on pcib2
      Oct 14 20:14:48	kernel: fxp0: <intel 100="" 82801ba="" (d865)="" pro="" ve="" ethernet=""> port 0xdf00-0xdf3f mem 0xfeaff000-0xfeafffff irq 20 at device 8.0 on pci2
      Oct 14 20:14:48	kernel: miibus0: <mii bus=""> on fxp0
      Oct 14 20:14:48	kernel: inphy0: <i82562et 10="" 100="" media="" interface=""> PHY 1 on miibus0
      Oct 14 20:14:48	kernel: inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto, auto-flow
      Oct 14 20:14:48	kernel: fxp0: [ITHREAD]
      Oct 14 20:14:48	kernel: em0: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6=""> port 0xde80-0xdebf mem 0xfeac0000-0xfeadffff,0xfeaa0000-0xfeabffff irq 17 at device 9.0 on pci2
      Oct 14 20:14:48	kernel: em0: [FILTER]
      Oct 14 20:14:48	kernel: em1: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.6=""> port 0xdd80-0xddbf mem 0xfea60000-0xfea7ffff,0xfea40000-0xfea5ffff irq 21 at device 10.0 on pci2
      Oct 14 20:14:48	kernel: em1: [FILTER]
      Oct 14 20:14:48	kernel: isab0: <pci-isa bridge=""> at device 31.0 on pci0
      Oct 14 20:14:48	kernel: isa0: <isa bus=""> on isab0
      Oct 14 20:14:48	kernel: atapci0: <intel ich5="" udma100="" controller=""> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfc00-0xfc0f at device 31.1 on pci0
      Oct 14 20:14:48	kernel: ata0: <ata channel=""> at channel 0 on atapci0
      Oct 14 20:14:48	kernel: ata0: [ITHREAD]
      Oct 14 20:14:48	kernel: ata1: <ata channel=""> at channel 1 on atapci0
      Oct 14 20:14:48	kernel: ata1: [ITHREAD]
      Oct 14 20:14:48	kernel: pci0: <serial bus,="" smbus=""> at device 31.3 (no driver attached)
      Oct 14 20:14:48	kernel: pci0: <multimedia, audio=""> at device 31.5 (no driver attached)
      Oct 14 20:14:48	kernel: acpi_button0: <power button=""> on acpi0
      Oct 14 20:14:48	kernel: atrtc0: <at realtime="" clock=""> port 0x70-0x71 irq 8 on acpi0
      Oct 14 20:14:48	kernel: atkbdc0: <keyboard controller="" (i8042)=""> port 0x60,0x64 irq 1 on acpi0
      Oct 14 20:14:48	kernel: atkbd0: <at keyboard=""> irq 1 on atkbdc0
      Oct 14 20:14:48	kernel: kbd0 at atkbd0
      Oct 14 20:14:48	kernel: atkbd0: [GIANT-LOCKED]
      Oct 14 20:14:48	kernel: atkbd0: [ITHREAD]
      Oct 14 20:14:48	kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      Oct 14 20:14:48	kernel: uart0: [FILTER]
      Oct 14 20:14:48	kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
      Oct 14 20:14:48	kernel: uart1: [FILTER]
      Oct 14 20:14:48	kernel: pmtimer0 on isa0
      Oct 14 20:14:48	kernel: orm0: <isa option="" roms=""> at iomem 0xcf800-0xd07ff,0xd0800-0xd17ff pnpid ORM0000 on isa0
      Oct 14 20:14:48	kernel: sc0: <system console=""> at flags 0x100 on isa0
      Oct 14 20:14:48	kernel: sc0: VGA <16 virtual consoles, flags=0x300>
      Oct 14 20:14:48	kernel: vga0: <generic isa="" vga=""> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
      Oct 14 20:14:48	kernel: ppc0: parallel port not found.
      Oct 14 20:14:48	kernel: p4tcc0: <cpu frequency="" thermal="" control=""> on cpu0
      Oct 14 20:14:48	kernel: p4tcc1: <cpu frequency="" thermal="" control=""> on cpu1
      Oct 14 20:14:48	kernel: Timecounters tick every 1.000 msec
      Oct 14 20:14:48	kernel: IPsec: Initialized Security Association Processing.
      Oct 14 20:14:48	kernel: ata0: DMA limited to UDMA33, controller found non-ATA66 cable
      Oct 14 20:14:48	kernel: ad0: 114473MB <wdc wd1200jb-00eva0="" 15.05r15=""> at ata0-master UDMA33
      Oct 14 20:14:48	kernel: acd0: CDRW <lite-on combo="" sohc-4832k="" oqkb=""> at ata0-slave UDMA33
      Oct 14 20:14:48	kernel: SMP: AP CPU #1 Launched!
      Oct 14 20:14:48	kernel: Trying to mount root from ufs:/dev/ad0s1a
      Oct 14 20:14:48	kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
      Oct 14 20:14:48	kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
      Oct 14 20:14:48	kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
      Oct 14 20:14:48	kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
      Oct 14 20:14:48	kernel: in /boot/loader.conf.
      Oct 14 20:14:48	kernel: ZFS filesystem version 5
      Oct 14 20:14:48	kernel: ZFS storage pool version 28
      Oct 14 20:14:48	kernel: fxp0: link state changed to DOWN
      Oct 14 20:14:47	check_reload_status: Linkup starting fxp0
      Oct 14 20:14:47	php: rc.bootup: Resyncing OpenVPN instances.
      Oct 14 20:14:48	kernel: pflog0: promiscuous mode enabled
      Oct 14 20:14:49	check_reload_status: Linkup starting fxp0
      Oct 14 20:14:49	kernel: fxp0: link state changed to UP
      Oct 14 20:14:51	check_reload_status: Linkup starting em0
      Oct 14 20:14:51	kernel: em0: link state changed to UP
      Oct 14 20:14:52	php: rc.bootup: ROUTING: setting default route to &.&.&.&
      Oct 14 20:14:53	check_reload_status: Updating all dyndns
      Oct 14 20:14:58	php: rc.bootup: Creating rrd update script
      Oct 14 20:14:58	syslogd: exiting on signal 15
      Oct 14 20:14:58	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 14 20:14:59	php: rc.start_packages: Restarting/Starting all packages.
      Oct 14 20:15:00	login: login on ttyv0 as root
      Oct 14 20:15:00	sshlockout[61064]: sshlockout/webConfigurator v3.0 starting up
      Oct 14 20:15:51	php: /index.php: Successful login for user 'admin' from: 10.6.6.125
      Oct 14 20:27:14	check_reload_status: Syncing firewall
      Oct 14 20:27:14	syslogd: exiting on signal 15
      Oct 14 20:27:14	syslogd: kernel boot file is /boot/kernel/kernel
      Oct 14 20:27:14	kernel: pflog0: promiscuous mode disabled
      Oct 14 20:27:14	kernel: pflog0: promiscuous mode enabled
      Oct 14 20:31:57	check_reload_status: Linkup starting em0
      Oct 14 20:31:57	kernel: em0: link state changed to DOWN
      Oct 14 20:31:59	php: rc.linkup: DEVD Ethernet detached event for lan
      Oct 14 20:36:32	check_reload_status: Linkup starting em0
      Oct 14 20:36:32	kernel: em0: link state changed to UP
      Oct 14 20:36:34	php: rc.linkup: DEVD Ethernet attached event for lan
      Oct 14 20:36:34	php: rc.linkup: HOTPLUG: Configuring interface lan
      Oct 14 20:36:40	check_reload_status: updating dyndns lan
      Oct 14 20:36:47	check_reload_status: Linkup starting fxp0
      Oct 14 20:36:47	kernel: fxp0: link state changed to DOWN
      Oct 14 20:36:50	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:38:31	check_reload_status: Linkup starting fxp0
      Oct 14 20:38:31	kernel: fxp0: link state changed to UP
      Oct 14 20:38:34	php: rc.linkup: Hotplug event detected for WAN(wan) but ignoring since interface is configured with static IP (?.?.?.? )
      Oct 14 20:38:34	check_reload_status: rc.newwanip starting fxp0
      Oct 14 20:38:36	php: rc.newwanip: rc.newwanip: Informational is starting fxp0.
      Oct 14 20:38:36	php: rc.newwanip: rc.newwanip: on (IP address: ?.?.?.?) (interface: WAN[wan]) (real interface: fxp0).</lite-on></wdc></cpu></cpu></generic></system></isa></at></keyboard></at></power></multimedia,></serial></ata></ata></intel></isa></pci-isa></intel(r)></intel(r)></i82562et></mii></intel></acpi></acpi></multimedia,></vga-compatible></acpi></acpi></intel></acpi></acpi></acpi></acpi></a></software></version>
      1 Reply Last reply
      Reply Quote 0
        Guest
        @pfBlense:
        Just read the first few lines and stopped right there!
        Are you saying that you connected pfSense's WAN port to the CPE, and its LAN port is feeding the WAN port of the DD-WRT router?
        If so, is one of these two in bridge mode or are both of them in NAT router mode?
        The IP scheme above seems to indicate that pfSense is in router mode and DD-WRT is in bridge mode, but then why does it have a different IP address? Aren't they in the same subnet? Doesn't make sense. (Did you subdivide the 10.6.6.0/24 subnet?)
        If they are both in router mode you are running probably a double NAT, is it intentional?
        Maybe I don't understand what you are trying to achieve, I admit I didn't read your material past the 4th line as the above line caught my attention and troubled me.
        Halea
        1 Reply Last reply
        Reply Quote 0
          Guest
          I think your problem has to do with the fact that you have two routers in series and you are using the same subnet.
          Just use 10.6.6.0/24 on the first and 10.6.7.0/24 on the second and your outbound traffic should work.
          Halea
          1 Reply Last reply
          Reply Quote 0
          • P
            pfBlense
            Thanks haleakalas for the reply. I have my DD-WRT set up as a WAP/switch like this: http://www.dd-wrt.com/wiki/index.php/Wireless_Access_Point. It does not route any traffic. Also, I am unable to ping directly from the pfSense WebGUI which should not be affected by my network setup at all since it is connected directly to my WAN/Modem. However, I might be missing something so please tell me if I am. But I think it should work on this setup. I feel it is an issue between the Deliberant and pfSense box. However, everything works fine when i have DD-WRT hooked up to the Deliberant as a gateway. Thanks again for the reply!
            1 Reply Last reply
            Reply Quote 0
              Guest
              So, basically you are trying to setup a plain vanilla pfSense and additionally you want a wifi access point in bridge mode with your LAN subnet.
              Start by setting up pfSense and make it work. If your hardware is right, your install is right you should have it up and running in no time.
              At that point you should have nothing but a WAN cable from your pfSense box to your Internet Modem, and a LAN cable to the network switch box. (and a computer connected to the network switch with an ethernet cable - NO WIFI YET, that you would also use to run the WebConfig on pfSense)
              You may want to check that pfSense's console shows your public IP on the WAN side and your LAN private subnet address. You should be able to ping any public server out there assuming that they are willing to respond. Try to ping www.grc.com, it should resolve to a public IP address and give you ping feedback. The same way, you should be able to ping any computer on your LAN by IP address.
              If any of these is not working your pfSense is not properly set. Go back and check your dynamic ip settings on the WAN, the static IP setting on the LAN, the DNS server addresses, your DHCP server settings on the LAN side (if you're using DHCP for your LAN side computers/devices)
              Again, until everything said above is working flawlessly do not even touch to wifi, access point, etc. You are in the wired ethernet world right now.
              Once you're done with the above, it's time to leave pfSense alone!
              Now, setup your wifi access point whatever that is. Linksys with dd-wrt in bridge mode I understand.
              So, you should have only one single wire connecting your wifi A/P to the network switch box. It might go to the WAN side or to the LAN side of your wifi box (Linksys) depending how the bridge is built with dd-wrt.
              Work on it until it is fully functional, meaning that with a wifi connected computer you should be able to ping, and access any computer on your local network.
              If you're not there yet your problem is isolated to dd-wrt and Linkysy wifi box. Just focus on it, do not change anything with your pfSense config. Do not waste your time trying to access public servers on the internet, etc. You should be able to see your own LAN first before you get any internet traffic.
              When this much works, you should also be able to ping the LAN side of your pfSense router.
              So try to ping your static LAN IP address on pfSense. If everything is done, next try to ping some outside, public servers like www.grc.com (from your wifi connected computer/laptop).
              Well, you should be done by now.
              Edit / Addition:
              If you get to make everything work and after a while you notice that you can no longer access the internet via your WAN, check pfSense's console for dynamic IP loss with your internet provider. If that's the case try to reboot and try to figure out if it is going to loose its IP again and how much time after reboot. Repeat your test a few times until you have a firm idea that this is happening over and over and within a certain time-frame. Meanwhile do not change any other parameters/components in your overall system. If you consistently loose your IP, it's likely that you have a NIC problem (hardware or device driver -wise). Install a new, maybe different type of net interface, reconfig pfSense's interfaces and start testing again.
              The WAN dynamic IP loss scenario is what I experienced repeatedly when I was trying to use a USB/Ethernet adapter.
              Hope this helps.
              Halea
              1 Reply Last reply
              Reply Quote 1
              Register Login
