    Best deal for 802.11ac solely to work for wireless alongside pfsense box
    8 Posts 3 Posters 2.2k Views
    • L Offline
      lostinclarity
      I'm trying to find the best device solely to serve wireless to my network, I already have a dedicated device for pfsense & ethernet so Im trying to find the best for 802.11ac for range & quality signal. I see the ASUS RT-AC87U AC2400 seems to be good in that area but wondering if there would be another cheaper alternative if only working as a "wireless bridge".
      Let me know what you guys think.
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        At that price point you probably want to at least look at the Ubiquiti Unifi-AC.
        Chattanooga, Tennessee, USA
          jasonlitka
          @Derelict:
          I wouldn't.  The benefits from their system are ease of management when using multiple APs.  If the OP only needs one there's little point because they aren't actually very good APs when compared to other hardware out there.
          I can break anything.
          • L Offline
            lostinclarity
            Yeah I only need it solely to propagate G/N/AC wifi around my place! It won't even be in gateway mode! So technically I just need as powerful chipset and antenna quality/range from the unit as possible, without really caring about the other specs meant as router mode.
            • DerelictD Offline
              Careful what you say you're looking for or people might start recommending something like a Ruckus R500 or Aruba 205.
              • L Offline
                lostinclarity
                I need strong coverage for up to 1000sqf apartment, G/N/AC mainly N & AC, whats goooood? :/
                  jasonlitka
                  @Derelict:
                  R500?  Psh…  You want the R700!
                  @lostinclarity:
                  1000 sq-ft isn't much so a single AP will do it, but the apartment part likely means that you're in an area where the signals are going to be congested.  I've had the best luck in environments like that with the Apple AirPort Extreme.  You won't find QOS, VLANs, or any other interesting features here, but if what you need is something that works, it's likely the closest thing you'll get to a guarantee.
                  • DerelictD Offline
                    Re: Airport Extreme: You can run the normal SSID untagged and Apple hard-codes the guest SSID to VLAN 1003 tagged so you can make it do what you need.  If you can stomach needing a config utility to make it work and dealing with Apple's interface, it's a reasonable choice for a simultaneous dual-band .11ac AP for $199.
