    Problem Creating Interface for Multi-WAN
    5 Posts 2 Posters 904 Views
      Craeft
      Hey everyone. I'm pretty new here, using 2.1.5.
      I am trying to set it up for multiWAN for load balance and failover. Unfortunately, everyone I see post about this says to go to INTERFACE > ASSIGN and then click on the + sign to make a new interface.  However, there is no such option.  When I click on INTERFACE, I have only (assign), WAN, and LAN as options and no way to create a new one. In the area where it lists WAN and LAN, there is no + icon.
      Am I missing something here?
      Any assistance would be most welcome.
      Thanks in advane.
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        There is no '+' if there are no unassigned interfaces.  What type of card has the port that isn't showing up?  Be sure it's supported.
        Chattanooga, Tennessee, USA
          Craeft
          @Derelict:
          Hey Derelict.  Thanks for the reply.
          Got in touch with the one currently near the server and it's running on i8254 which is apparently supported (from what I can find).
          • DerelictD Offline
            You'll have to look through ifconfig -a ,  /var/log/dmesg.boot , etc and see why it's not available for selection.
              Craeft
              @Derelict:
              You're awesome, Derelict. I will delve into that when I can next get my butt back near the machine.
