    LCDproc and Arduino to control Watchguard FireBox leds
    27 Posts 3 Posters 5.5k Views
    • F Offline
      fmertz
      Not sure what could be wrong:
      • Check the 32/64 "bitness" between the dev machine and pfSense
      • Check the files are actually the same (sha1, md5) as text FTP through a Windows machine can mess things up
      • See what file has to say, i.e. "file fbled"
      • You can build with debug, and remove the symbols later with strip, i.e. "strip fbled"
        subsense
        I just checked as you suggested fmertz, and it works now !
        I used <file>to check the difference. And the binary on the build machine was 'not-stripped' and once I transferred it to the pfSense machine it was suddenly 'stripped'.
        Somehow by zipping it and uploading it thru pfSense's webconfigurator => [upload file] ( prolly a bad idea ;) ) the binary got stripped of the symbols … strange behavior.
        Have to look into that, cause I’m intrigued why that would happen.
        Anyway I just ftp them directly from one machine to the other and no more probs, I can compile and run it !
        I’m not seeing any load or traffic yet but I guess that might have something to do with the nic configuration. Next thing to look at. I just needed to change the "ETHDEV" in fbled.h from "dc" to "em" … all 'text leds' are working ! :)
        So thanks a lot for your time guys, really appreciate it !</file>
        • stephenw10S Online
          Hmm, that is weird. I've never looked into it but I think the file upload in the webgui has some filtering. It won't upload my small compiled binary at all for example.
          • F Offline
            fmertz
            @subsense:
            Yep, my virtual machine had pretend Intel Gigabit adapters (hence "em"), but the real hardware has Macronix adapters handled by the DEC Tulip driver (hence "dc"). I initially wanted to make sure I would not count packets multiple times by looking at just the hardware interfaces. Perils of coding for a particular hardware combination and all that…
            Glad to hear it works in text mode. Now on to coding the Arduino client I suppose? Keep us posted.
              subsense
              Hey fmertz, I’ve got Status, Load and Traffic working with some rudimentary code. (need to do some refactoring ;) )
              But I’m a bit lost in the ‘Bermuda triangle’ :)
              Cause I see definitions for all the LEDs in the triangle in the header file. For the tips and the vertices, LED_T2E_1 and LED_T2E_2, etc …. And I can also see them being used in your code for the LED version.
              So is the triangle fully functional yet ? Or just the tips for the moment ?
              And how are the LEDs mapped to the text output? I’m guessing the tips are 3[ . . . . T E O . . ] ?
              What about the traffic from and to Trust, Ext and Opt, should those led vertices work yet ?  I can’t see them light up.
              Also how would 8 text bits represent 3 firewall block tips + 6 traffic vertices ?
              Can’t seem to find anything about it in the docs or on this forum.
              thanks
              • F Offline
                fmertz
                The triangle is not fully coded, yet, mostly for lack of imagination.
                For the tips, I tried and code something generic, without policy. Users can configure the firewall to log whatever packet they want, and fbled can capture the packet and blink the tip of the interface where the logging occurs. So, you could blink for an ssh attempts on the WAN side for example. It is really open to whatever pf lets you log.
                I would like to do something similar for the triangle sides, but I have not thought through it, yet. I wanted to avoid a fixed scheme that is leading the lights to be just about always on, or off. One line of thought is connection tracking. Another is NAT/port forwarding. Many ways to go…
                  subsense
                  ah right ok.
                  connection tracking or NAT/port forwarding sounds great !
