How to fix system menu and help menu problam in pfsene 2.1.5
I'm trying to fix the top menu in pfsene 2.1.5
Help button
Is just below the button systemWhich is a bit of a problem access the system menu
I've seen here at the forum two solutions
I tried the two solutions it does not workclear the browser's cache memory (Fire Fox 34 On ubuntu 14.04)
The second option I did not understand
https://forum.pfsense.org/index.php?topic=81165.0
Which link to use
https://github.com/pfsense/pfsense/commit/6817c18afa737e83756516a7b7c14ff5e5d85814
https://github.com/CharlieMarshall/pfsense/commit/f216a5824fdc12c6b13cd950cc4625445093fe28
What should I do with it
I do not know if it will work for everyone
But it worked for mehttp://makandracards.com/makandra/1258-install-the-verdana-and-tahoma-fonts-under-ubuntu-linux
