Problem with check_mk packet
19 Posts 8 Posters 10.7k Views
  • A
    Augusto
    hello
    I need monitoring pfSense via check_mk.
    I installed the package but monitoring can not get any information.
    port 6556 is listening usually
    ip Monitoring Server reaches the pfSense …
    Any additional detail to work?
    • T
      tracer
      I think we found the problem:
      There's already a bug ticket:
      https://redmine.pfsense.org/issues/4084
      "The official Check_mk agent package doesn't work because the shebang line at the top of /usr/local/bin/check_mk_agent is wrong: it needs to be #!/usr/local/bin/bash, not #!/bin/bash."
      Maybe we can contact the maintainer to fix this.
      Who can help here ?
      • D
        DarkBeard
        @tracer:
        Who can help here ?
        It is the smallest problem with this package.
        for his work needed statgrab.
        Removed from the system inetd, misconfiguration of which lay in /etc/inetd.conf
        And he run the script in /etc/rc.d/inetd: not found
        • T
          tracer
          ok, you might be right …
          But mine worked after changing the bash line.
          Are you saying that there a problems which prevents the package from working or are we missing infos...
          • M
            mete
            In 2.2-RELEASE the package doesn't work.
            In the "Sockets" tab, there's no open port for the check_mk agent (default 6556).
            Also I've seen this error in the logs, I'm not 100% sure that's from check_mk_agent, but I think so…
            Jan 25 23:46:49 php-fpm[96236]: /pkg_mgr_install.php: The command '/etc/rc.d/inetd restart' returned exit code '127', the output was '/etc/rc.d/inetd: not found'
            Jan 25 23:46:49 check_reload_status: Syncing firewall
            Jan 25 23:46:49 php-fpm[96236]: /pkg_mgr_install.php: Successfully installed package: Check_mk agent.
            Best, mete
            • M
              MathiasM
              Yes, inetd is installed and running…
              /usr/sbin/inet
              But start scripts are missig???
              /etc/rc.d/inetd start
              service inetd start
              I found this…
              https://mathias-kettner.com/checkmk_freebsd.html
              • W
                WhiteSaxo
                To get data for monitoring via port 6556 you have to do the following.
                Its just a workaroud because every time inetd restarts the configfile /var/etc/inetd.conf will be overwritten.
                I dont know yet how i can change this.
                First of all be sure that the check_mk_agent is running probably and than copy this line:
                check_mk  stream  tcp nowait  root  /usr/local/bin/check_mk_agent check_mk_agent
                into /var/etc/inetd.conf
                then you have to kill your running inetd process and start it again with this command:
                /usr/sbin/inetd -wW -R 0 -a 127.0.0.1 /var/etc/inetd.conf
                Now there should be an open socket and the data are available for your monitoring server.
                • M
                  MathiasM
                  Her i post the missing script, but this is not the full solution.
                  1. create new file /etc/rc.d/inetd
                  2. insert code
                  3. chmod +x /etc/rc.d/inetd
                  Now service inetd start,stop,status is working
                  #!/bin/sh
                  # $FreeBSD$
                  # PROVIDE: inetd
                  # REQUIRE: DAEMON LOGIN cleanvar
                  # KEYWORD: shutdown
                  . /etc/rc.subr
                  name="inetd"
                  rcvar="inetd_enable"
                  command="/usr/sbin/${name}"
                  pidfile="/var/run/${name}.pid"
                  required_files="/etc/${name}.conf"
                  extra_commands="reload"
                  load_rc_config $name
                  run_rc_command "$1"
                  • M
                    MathiasM
                    @WhiteSaxo: I follow your post, but it is not working.
                    I have to change the first line from file /usr/local/bin/check_mk_agent from #!/bin/bash intro #!/bin/sh
                    Now, check_mk_agent report no error message, but is not working yet.
                    The check_mk agen (freebsd Version: 1.2.7i1) comes from:
                    http://git.mathias-kettner.de/git/?p=check_mk.git;a=blob_plain;f=agents/check_mk_agent.freebsd;hb=HEAD
                    Recently, some modification were carried out.
                    http://git.mathias-kettner.de/git/?p=check_mk.git&a=search&h=HEAD&st=commit&s=freebsd
                    I create a new installion with pfsense 2.1.5 and check_mk agent, but it even not working.
                    At boot time, i get errors from /usr/local/pkg/checkmk.inc line 107.
                    And i fount errors into /var/log/system.log.
                    • W
                      WhiteSaxo
                      Did you copy
                      in the correct inetd.conf?
                      And did you add
                      check_mk        6556/tcp   #check_mk agent
                      in /etc/services?
                      • M
                        MathiasM
                        The file /usr/local/bin/check_mk_agent is wrong. pfsense install it direkt from git. Look into my older post.
                        I replace check_mk_agent with a older version and it works well.
                        @WhiteSaxo: Can you post your older file? This version is working well with pfsense 2.2 and pfsense 2.1.5
                        • W
                          WhiteSaxo
                          Ah okay good to know.
                          Here is my working check_mk_agent
                          #!/bin/sh
                          # |             ____ _               _        __  __ _  __           |
                          # |            / ___| |__   ___  ___| | __   |  \/  | |/ /           |
                          # |           | |   | '_ \ / _ \/ __| |/ /   | |\/| | ' /            |
                          # |           | |___| | | |  __/ (__|   <    | |  | | . \            |
                          # |            \____|_| |_|\___|\___|_|\_\___|_|  |_|_|\_\           |
                          # | Copyright Mathias Kettner 2014             mk@mathias-kettner.de |
                          # This file is part of Check_MK.
                          # The official homepage is at http://mathias-kettner.de/check_mk.
                          # check_mk is free software;  you can redistribute it and/or modify it
                          # under the  terms of the  GNU General Public License  as published by
                          # the Free Software Foundation in version 2.  check_mk is  distributed
                          # in the hope that it will be useful, but WITHOUT ANY WARRANTY;  with-
                          # out even the implied warranty of  MERCHANTABILITY  or  FITNESS FOR A
                          # PARTICULAR PURPOSE. See the  GNU General Public License for more de-
                          # ails.  You should have  received  a copy of the  GNU  General Public
                          # License along with GNU Make; see the file  COPYING.  If  not,  write
                          # to the Free Software Foundation, Inc., 51 Franklin St,  Fifth Floor,
                          # Boston, MA 02110-1301 USA.
                          # Author: Lars Michelsen <lm@mathias-kettner.de>#         Florian Heigl <florian.heigl@gmail.com>#           (Added sections: df mount mem netctr ipmitool)
                          # NOTE: This agent has beed adapted from the Check_MK linux agent.
                          #       The most sections are commented out at the moment because
                          #       they have not been ported yet. We will try to adapt most
                          #       sections to print out the same output as the linux agent so
                          #       that the current checks can be used.
                          # This might be a good source as description of sysctl output:
                          # http://people.freebsd.org/~hmp/utilities/satbl/_sysctl.html
                          # Remove locale settings to eliminate localized outputs where possible
                          export LC_ALL=C
                          unset LANG
                          export MK_LIBDIR="/usr/lib/check_mk_agent"
                          export MK_CONFDIR="/etc/check_mk"
                          export MK_TMPDIR="/var/run/check_mk"
                          # Make sure, locally installed binaries are found
                          PATH=$PATH:/usr/local/bin
                          # All executables in PLUGINSDIR will simply be executed and their
                          # ouput appended to the output of the agent. Plugins define their own
                          # sections and must output headers with '<<<' and '>>>'
                          PLUGINSDIR=$MK_LIBDIR/plugins
                          # All executables in LOCALDIR will by executabled and their
                          # output inserted into the section <<<local>>>. Please refer
                          # to online documentation for details.
                          LOCALDIR=$MK_LIBDIR/local
                          # close standard input (for security reasons) and stderr
                          #if [ "$1" = -d ]
                          #then
                          #    set -xv
                          #else
                          #    exec /dev/null
                          #fi
                          # Runs a command asynchronous by use of a cache file
                          echo '<<<check_mk>>>'
                          echo Version: 1.2.7i1
                          echo AgentOS: freebsd
                          osver="$(uname -r)"
                          is_jailed="$(sysctl -n security.jail.jailed)"
                          # Partitionen (-P verhindert Zeilenumbruch bei langen Mountpunkten)
                          # Achtung: NFS-Mounts werden grundsaetzlich ausgeblendet, um
                          # Haenger zu vermeiden. Diese sollten ohnehin besser auf dem
                          # Server, als auf dem Client ueberwacht werden.
                          echo '<<<df>>>'
                          # no special zfs handling so far, the ZFS.pools plugin has been tested to
                          # work on FreeBSD
                          if df -T > /dev/null ; then
                              df -kTP -t ufs | egrep -v '(Filesystem|devfs|procfs|fdescfs|basejail)'
                          else
                              df -kP -t ufs | egrep -v '(Filesystem|devfs|procfs|fdescfs|basejail)' | awk '{ print $1,"ufs",$2,$3,$4,$5,$6 }'
                          fi
                          # Check NFS mounts by accessing them with stat -f (System
                          # call statfs()). If this lasts more then 2 seconds we
                          # consider it as hanging. We need waitmax.
                          #if type waitmax >/dev/null
                          #then
                          #    STAT_VERSION=$(stat --version | head -1 | cut -d" " -f4)
                          #    STAT_BROKE="5.3.0"
                          #    echo '<<<nfsmounts>>>'
                          #    sed -n '/ nfs /s/[^ ]* \([^ ]*\) .*/\1/p' < /proc/mounts |
                          #        while read MP
                          #  do
                          #   if [ $STAT_VERSION != $STAT_BROKE ]; then
                          #      waitmax -s 9 2 stat -f -c "$MP ok %b %f %a %s" "$MP" || \
                          #    echo "$MP hanging 0 0 0 0"
                          #   else
                          #      waitmax -s 9 2 stat -f -c "$MP ok %b %f %a %s" "$MP" && \
                          #      printf '\n'|| echo "$MP hanging 0 0 0 0"
                          #   fi
                          #  done
                          #fi
                          # Check mount options.
                          # FreeBSD doesn't do remount-ro on errors, but the users might consider
                          # security related mount options more important.
                          echo '<<<mounts>>>'
                          mount -p -t ufs
                          # processes including username, without kernel processes
                          echo '<<<ps>>>'
                          COLUMNS=10000
                          if [ is_jailed = 0 ]; then
                              ps ax -o state,user,vsz,rss,pcpu,command | sed -e 1d  -e '/\([^ ]*J\) */d' -e 's/*\([^ ]*\) *\([^ ]*\) *\([^ ]*\) *\([^ ]*\) *\([^ ]*\) */(\2,\3,\4,\5) /'
                          else
                              ps ax -o user,vsz,rss,pcpu,command | sed -e 1d -e 's/ *\([^ ]*\) *\([^ ]*\) *\([^ ]*\) *\([^ ]*\) */(\1,\2,\3,\4) /'
                          fi
                          # Produce compatible load/cpu output to linux agent. Not so easy here.
                          echo '<<<cpu>>>'
                          echo `sysctl -n vm.loadavg | tr -d '{}'` `top -b -n 1 | grep -E '^[0-9]+ processes' | awk '{print $3"/"$1}'` `sysctl -n kern.lastpid` `sysctl -n hw.ncpu`
                          # Calculate the uptime in seconds since epoch compatible to /proc/uptime in linux
                          echo '<<<uptime>>>'
                            up_seconds=$(( `date +%s` - `sysctl -n kern.boottime  | cut -f1 -d\, | awk '{print $4}'`))
                          idle_seconds=$(ps axw | grep idle | grep -v grep | awk '{print $4}' | cut -f1 -d\: )
                          # second value can be grabbed from "idle" process cpu time / num_cores
                          echo "$idle_seconds $up_seconds"
                          # Platten- und RAID-Status von LSI-Controlleren, falls vorhanden
                          #if which cfggen > /dev/null ; then
                          #   echo '<<<lsi>>>'
                          #   cfggen 0 DISPLAY | egrep '(Target ID|State|Volume ID|Status of volume)[[:space:]]*:' | sed -e 's/ *//g' -e 's/:/ /'
                          #fi
                          # Multipathing is supported in FreeBSD by now
                          # http://www.mywushublog.com/2010/06/freebsd-and-multipath/
                          if kldstat -v | grep g_multipath > /dev/null ; then
                              echo '<<<freebsd_multipath>>>'
                              gmultipath status | grep -v ^Name
                          fi
                          # Soft-RAID
                          echo '<<<freebsd_geom_mirrors>>>'
                          gmirror status | grep -v ^Name
                          # Performancecounter Kernel
                          echo "<<<kernel>>>"
                          date +%s
                          forks=`sysctl -n vm.stats.vm.v_forks`
                          vforks=`sysctl -n vm.stats.vm.v_vforks`
                          rforks=`sysctl -n vm.stats.vm.v_rforks`
                          kthreads=`sysctl -n vm.stats.vm.v_kthreads`
                          echo "cpu" `sysctl -n kern.cp_time | awk ' { print $1" "$2" "$3" "$5" "$4 } '`
                          echo "ctxt" `sysctl -n vm.stats.sys.v_swtch`
                          echo "processes" `expr $forks + $vforks + $rforks + $kthreads`
                          # Network device statistics (Packets, Collisions, etc)
                          # only the "Link/Num" interface has all counters.
                          echo '<<<lnx_if:sep(58)>>>'
                          date +%s
                          if [ "$(echo $osver | cut -f1 -d\. )" -gt "8" ]; then
                              netstat -inb | egrep -v '(^Name|plip|enc|pfsync|pflog|ovpns)' | grep Link | awk '{print"\t"$1":\t"$8"\t"$5"\t"$6"\t"$7"\t0\t0\t0\t0\t"$11"\t"$9"\t"$10"\t0\t0\t0\t0\t0"}'
                          else
                              # pad output for freebsd 7 and before
                              netstat -inb | egrep -v '(^Name|lo|plip)' | grep Link | awk '{print $1" "$7" "$5" "$6" 0 0 0 0 0 "$10" "$8" "$9" 0 0 "$11" 0 0"}'
                          fi
                          # State of LSI MegaRAID controller via MegaCli.
                          # To install: pkg install megacli
                          if which MegaCli >/dev/null ; then
                              echo '<<<megaraid_pdisks>>>'
                              MegaCli -PDList -aALL -NoLog < /dev/null | egrep 'Enclosure|Raw Size|Slot Number|Device Id|Firmware state|Inquiry'
                              echo '<<<megaraid_ldisks>>>'
                              MegaCli -LDInfo -Lall -aALL -NoLog < /dev/null | egrep 'Size|State|Number|Adapter|Virtual'
                              echo '<<<megaraid_bbu>>>'
                              MegaCli -AdpBbuCmd -GetBbuStatus -aALL -NoLog < /dev/null | grep -v Exit
                          fi
                          # OpenVPN Clients.
                          # Correct log location unknown, sed call might also be broken
                          if [ -e /var/log/openvpn/openvpn-status.log ] ; then
                              echo '<<<openvpn_clients:sep(44)>>>'
                              sed -n -e '/CLIENT LIST/,/ROUTING TABLE/p' < /var/log/openvpn/openvpn-status.log  | sed -e 1,3d -e '$d'
                          fi
                          if which ntpq > /dev/null 2>&1 ; then
                             echo '<<<ntp>>>'
                             # remote heading, make first column space separated
                             ntpq -np | sed -e 1,2d -e 's/^\(.\)/\1 /' -e 's/^ /%/'
                          fi
                          # Checks for cups monitoring
                          #if which lpstat > /dev/null 2>&1; then
                          #  echo '<<<cups_queues>>>'
                          #  lpstat -p
                          #  echo '---'
                          #  for i in $(lpstat -p | grep -E "^(printer|Drucker)" | awk '{print $2}' | grep -v "@"); do
                          #    lpstat -o "$i"
                          #  done
                          #fi
                          # Heartbeat monitoring
                          #if which cl_status > /dev/null 2>&1; then
                          #  # Different handling for heartbeat clusters with and without CRM
                          #  # for the resource state
                          #  if [ -S /var/run/heartbeat/crm/cib_ro ]; then
                          #    echo '<<<heartbeat_crm>>>'
                          #    crm_mon -1 -r | grep -v ^$ | sed 's/^\s/_/g'
                          #  else
                          #    echo '<<<heartbeat_rscstatus>>>'
                          #    cl_status rscstatus
                          #  fi
                          #  echo '<<<heartbeat_nodes>>>'
                          #  for NODE in $(cl_status listnodes); do
                          #    if [ $NODE != $HOSTNAME ]; then
                          #      STATUS=$(cl_status nodestatus $NODE)
                          #      echo -n "$NODE $STATUS"
                          #      for LINK in $(cl_status listhblinks $NODE 2>/dev/null); do
                          #        echo -n " $LINK $(cl_status hblinkstatus $NODE $LINK)"
                          #      done
                          #      echo
                          #    fi
                          #  done
                          #fi
                          # Number of TCP connections in the various states
                          echo '<<<tcp_conn_stats>>>'
                          netstat -na | awk ' /^tcp/ { c[$6]++; } END { for (x in c) { print x, c[x]; } }'
                          # Postfix mailqueue monitoring
                          # Only handle mailq when postfix user is present. The mailq command is also
                          # available when postfix is not installed. But it produces different outputs
                          # which are not handled by the check at the moment. So try to filter out the
                          # systems not using postfix by searching for the postfix user.
                          # Cannot take the whole outout. This could produce several MB of agent output
                          # on blocking queues.
                          # Only handle the last 6 lines (includes the summary line at the bottom and
                          # the last message in the queue. The last message is not used at the moment
                          # but it could be used to get the timestamp of the last message.
                          #if which mailq >/dev/null 2>&1 && getent passwd postfix >/dev/null 2>&1; then
                          #  echo '<<<postfix_mailq>>>'
                          #  mailq | tail -n 6
                          #fi
                          #Check status of qmail mailqueue
                          #if type qmail-qstat >/dev/null
                          #then
                          #   echo "<<<qmail_stats>>>"
                          #   qmail-qstat
                          #fi
                          # check zpool status
                          #if [ -x /sbin/zpool ]; then
                          #   echo "<<<zpool_status>>>"
                          #   /sbin/zpool status -x | grep -v "errors: No known data errors"
                          #fi
                          # Memory Usage
                          # currently we'll need sysutils/muse for this.
                          if [ -x /usr/local/bin/muse ]
                          then
                          echo '<<<mem>>>'
                          # yes, i don't know sed well.
                          muse -k 2>/dev/null | sed 's/Total/MemTotal/' | sed 's/Free/MemFree/'
                          swapinfo -k 1K | tail -n 1 | awk '{ print "SwapTotal: "$2" kB\nSwapFree: "$4" kB" }'
                          fi
                          # Fileinfo-Check: put patterns for files into /etc/check_mk/fileinfo.cfg
                          if [ -r "$MK_CONFDIR/fileinfo.cfg" ] ; then
                              echo '<<<fileinfo:sep(124)>>>'
                              date +%s
                              stat -f "%N|%z|%m" $(cat "$MK_CONFDIR/fileinfo.cfg")
                          fi</fileinfo:sep(124)></mem></zpool_status></qmail_stats></postfix_mailq></tcp_conn_stats></heartbeat_nodes></heartbeat_rscstatus></heartbeat_crm></cups_queues></ntp></openvpn_clients:sep(44)></megaraid_bbu></megaraid_ldisks></megaraid_pdisks></lnx_if:sep(58)></kernel></freebsd_geom_mirrors></freebsd_multipath></lsi></uptime></cpu></ps></mounts></nfsmounts></df></check_mk></local></florian.heigl@gmail.com></lm@mathias-kettner.de>
                          • M
                            MathiasM
                            Here is the solution: (works with pfsende 2.2 and 2.1.5)
                            A) create inetd (only for pfsense 2.2)
                            2. insert code from my post
                            3. run #chmod +x /etc/rc.d/inetd
                            B) Replace check_mk_agent (older version is working well)
                            replace code into file /usr/local/bin/check_mk_agent with post from WhiteSaxo
                            C) Restart daemon
                            service inetd restart
                            • R
                              Roger
                              Just one little change to the check_mk_client script posted by WhiteSaxo above.
                              I took the "date %s" out of the lnx_if section as my check_mk server was not picking up the interfaces. I also added lo0 to the exceptions, as it doesn't quite match up on the awk.
                              So, it now reads
                              #date +%s
                                  netstat -inb | egrep -v '(^Name|plip|enc|lo0|pfsync|pflog|ovpns)' | grep Link | awk '{print"\t"$1":\t"$8"\t"$5"\t"$6"\t"$7"\t
                              else
                              " 0 0"}'
                              fi</lnx_if:sep(58)>
                              • N
                                niccarp89
                                Hi Roger and all.
                                I add your modification but still dont get interfaces links, i notice that $osver variable its empty and i dont have defined over the network section. Anyone know if this its ok???
                                • R
                                  Roger
                                  Hi, I possibly made a mistake with my cut-and-paste.
                                  #date +%s
                                      netstat -inb | egrep -v '(^Name|plip|enc|lo0|pfsync|pflog|ovpns)' | grep Link | awk '{print"\t"$1":\t"$8"\t"$5"\t"$6"\t"$7"\t0\t0\t0\t0\t"$11"\t"$9"\t"$10"\t0\t0\t0\t0\t0"}'
                                  else
                                  fi
                                  It's a line feed issue from my ssh session. Maybe that's the issue with you not getting interfaces.
                                  If not, what do you get from a "telnet host-ip 6556"?
                                  Roger
                                  • N
                                    niccarp89
                                    @Roger:
                                    #date +%s
                                    else
                                    fi
                                    Roger
                                    Hi Roger.
                                    http://pastebin.com/U2yq2nxn
                                    Seems that <<<lnx_if:sep(58)>>>  section in the telnet its ok, but check_mk dont discover the interfaces.
                                    You have for example re0 re1 or whatever detected as a service in the check_mk interface??</lnx_if:sep(58)>
                                    • R
                                      Roger
                                      Hi
                                      Yes, I get re0 and re1 listed after a 'Full Scan', did you do a 'Full Scan' in check_mk ?
                                      My server version is the latest 1.2.4 version.
                                      Roger
                                      • N
                                        niccarp89
                                        @Roger:
                                        Hi
                                        Roger
                                        Perfect Roger, i only have to do a full scan.
                                        Thanks!
                                          [[user:consent.lead]]
                                          [[user:consent.not_received]]
