    IPsec tunnel problem with 2.1.5 and 2.2rc
    Scheduled Pinned Locked Moved 2.2 Snapshot Feedback and Problems - RETIRED
    35 Posts 4 Posters 19.9k Views
      tracer
      set optimization normal
      set timeout { adaptive.start 0, adaptive.end 0 }
      set limit states 324000
      set limit src-nodes 324000
      #System aliases
      loopback = "{ lo0 }"
      WAN = "{ pppoe2 }"
      LAN = "{ em0 }"
      KABELDE = "{ em1 }"
      IPsec = "{ enc0 }"
      #SSH Lockout Table
      table <sshlockout>persist
      table <webconfiguratorlockout>persist
      #Snort tables
      table <snort2c>table <virusprot>table <bogons>persist file "/etc/bogons"
      table <bogonsv6>persist file "/etc/bogonsv6"
      table <vpn_networks>{ 10.0.47.0/24 10.0.48.0/24 }
      table <negate_networks>{ 10.0.47.0/24 10.0.48.0/24 }
      # User Aliases
      table <bad_peers>{   84.72.100.85  88.217.16.69 }
      bad_peers = "<bad_peers>"
      table <blockedhosts>persist
      blockedhosts = "<blockedhosts>"
      table <easyruleblockhostsopt2>{   fe80::1/128 }
      EasyRuleBlockHostsOPT2 = "<easyruleblockhostsopt2>"
      table <gamenetworks>{   107.21.244.12/32  23.21.42.15/16  216.74.41.14/32  50.16.200.11/32  107.20.146.165/32  23.20.61.27/32  23.14.93.41/32  23.23.142.220/32  107.20.99.121/32  75.101.200.255/32  54.243.91.151/32  174.129.59.97/32  50.17.29.77/32  54.242.56.44/32  204.236.253.208/32  23.20.27.49/32  23.22.164.163/32  50.17.243.27/32  50.19.6.207/32  17.149.32.49/32  50.19.44.186/32  50.19.50.48/32  54.224.124.89/32  23.22.107.155/32  95.100.249.19/32 }
      gamenetworks = "<gamenetworks>"
      guest_ports = "{   25  53  80  443  993  995  123  16385  16386  16384  5222  5223 }"
      GWPorts = "{   1677  7100 }"
      ineports = "{   80  443  1677  8300  7191 }"
      table <kabelhosts>{   192.168.24.106  192.168.24.112  192.168.24.175  192.168.24.131  192.168.24.152  192.168.24.108  192.168.24.145  192.168.24.133 }
      Kabelhosts = "<kabelhosts>"
      table <macmini>{   192.168.24.175  192.168.24.176  192.168.24.146 }
      Macmini = "<macmini>"
      table <nodirect>{   192.168.24.188  192.168.24.170 }
      Nodirect = "<nodirect>"
      table <server>{   192.168.24.2  192.168.24.4  192.168.24.12  192.168.24.8 }
      Server = "<server>"
      table <torpig>{   91.19.0.0/16  91.20.0.0/16 }
      torpig = "<torpig>"
      table <webdevices>{   192.168.24.21  192.168.24.20  192.168.24.11 }
      WebDevices = "<webdevices>"
      table <youtube>persist
      youtube = "<youtube>"
      # Gateways
      GWKABELDE_DHCP = " route-to ( em1 188.194.217.254 ) "
      GWWAN_PPPOE = " route-to ( pppoe2 82.135.16.28 ) "
      GWSurf_redundant = "  route-to { ( em1 188.194.217.254 )  }  "
      set loginterface em0
      set skip on pfsync0
      scrub from any to <vpn_networks>max-mss 1400
      scrub from <vpn_networks>to any max-mss 1400
      scrub on $WAN all no-df random-id  fragment reassemble
      scrub on $LAN all no-df random-id  fragment reassemble
      scrub on $KABELDE all no-df random-id  fragment reassemble
      no nat proto carp
      no rdr proto carp
      nat-anchor "natearly/*"
      nat-anchor "natrules/*"
      # Outbound NAT rules (automatic)
      # Subnets to NAT
      tonatsubnets	= "{ 127.0.0.0/8 192.168.24.0/24 }"
      nat on $WAN  from $tonatsubnets to any port 500 -> 93.104.178.7/32  static-port
      nat on $WAN  from $tonatsubnets to any -> 93.104.178.7/32 port 1024:65535
      nat on $KABELDE  from $tonatsubnets to any port 500 -> 188.194.217.58/32  static-port
      nat on $KABELDE  from $tonatsubnets to any -> 188.194.217.58/32 port 1024:65535
      # Load balancing anchor
      rdr-anchor "relayd/*"
      # TFTP proxy
      rdr-anchor "tftp-proxy/*"
      rdr pass on em0 proto udp from any to any port tftp -> 127.0.0.1 port 6969
      # NAT Inbound Redirects
      rdr on em1 proto { tcp udp } from any to 188.194.217.58 port $GWPorts -> 192.168.24.6
      # Reflection redirect
      rdr on { em0 enc0 } proto { tcp udp } from any to 188.194.217.58 port $GWPorts -> 192.168.24.6
      no nat on em0 proto { tcp udp } from em0 to 192.168.24.6 port $GWPorts
      nat on em0 proto { tcp udp } from 192.168.24.0/24 to 192.168.24.6 port $GWPorts -> 192.168.24.1 port 1024:65535
      rdr on em1 proto tcp from any to 188.194.217.58 port 993 -> 192.168.24.6
      rdr on { em0 enc0 } proto tcp from any to 188.194.217.58 port 993 -> 192.168.24.6
      no nat on em0 proto tcp from em0 to 192.168.24.6 port 993
      nat on em0 proto tcp from 192.168.24.0/24 to 192.168.24.6 port 993 -> 192.168.24.1 port 1024:65535
      rdr on pppoe2 proto tcp from any to 93.104.178.7 port 22 -> 192.168.24.6
      rdr on { em0 enc0 } proto tcp from any to 93.104.178.7 port 22 -> 192.168.24.6
      no nat on em0 proto tcp from em0 to 192.168.24.6 port 22
      nat on em0 proto tcp from 192.168.24.0/24 to 192.168.24.6 port 22 -> 192.168.24.1 port 1024:65535
      rdr on pppoe2 proto tcp from any to 93.104.178.7 port 25 -> 192.168.24.6
      rdr on { em0 enc0 } proto tcp from any to 93.104.178.7 port 25 -> 192.168.24.6
      no nat on em0 proto tcp from em0 to 192.168.24.6 port 25
      nat on em0 proto tcp from 192.168.24.0/24 to 192.168.24.6 port 25 -> 192.168.24.1 port 1024:65535
      rdr on pppoe2 proto tcp from any to 93.104.178.7 port 993 -> 192.168.24.6
      rdr on { em0 enc0 } proto tcp from any to 93.104.178.7 port 993 -> 192.168.24.6
      rdr on pppoe2 proto { tcp udp } from any to 93.104.178.7 port $GWPorts -> 192.168.24.6
      rdr on { em0 enc0 } proto { tcp udp } from any to 93.104.178.7 port $GWPorts -> 192.168.24.6
      # UPnPd rdr anchor
      rdr-anchor "miniupnpd"
      anchor "relayd/*"
      anchor "openvpn/*"
      anchor "ipsec/*"
      # block IPv4 link-local. Per RFC 3927, link local "MUST NOT" be forwarded by a routing device,
      # and clients "MUST NOT" send such packets to a router. FreeBSD won't route 169.254./16, but
      # route-to can override that, causing problems such as in redmine #2073
      block in log quick from 169.254.0.0/16 to any tracker 1000000101 label "Block IPv4 link-local"
      block in log quick from any to 169.254.0.0/16 tracker 1000000102 label "Block IPv4 link-local"
      # default deny rules
      block in log inet all tracker 1000000103 label "Default deny rule IPv4"
      block out log inet all tracker 1000000104 label "Default deny rule IPv4"
      block in log inet6 all tracker 1000000105 label "Default deny rule IPv6"
      block out log inet6 all tracker 1000000106 label "Default deny rule IPv6"
      # IPv6 ICMP is not auxilary, it is required for operation
      # See man icmp6(4)
      # 1    unreach         Destination unreachable
      # 2    toobig          Packet too big
      # 128  echoreq         Echo service request
      # 129  echorep         Echo service reply
      # 133  routersol       Router solicitation
      # 134  routeradv       Router advertisement
      # 135  neighbrsol      Neighbor solicitation
      # 136  neighbradv      Neighbor advertisement
      pass  quick inet6 proto ipv6-icmp from any to any icmp6-type {1,2,135,136} tracker 1000000107 keep state
      # Allow only bare essential icmpv6 packets (NS, NA, and RA, echoreq, echorep)
      pass out  quick inet6 proto ipv6-icmp from fe80::/10 to fe80::/10 icmp6-type {129,133,134,135,136} tracker 1000000108 keep state
      pass out  quick inet6 proto ipv6-icmp from fe80::/10 to ff02::/16 icmp6-type {129,133,134,135,136} tracker 1000000109 keep state
      pass in  quick inet6 proto ipv6-icmp from fe80::/10 to fe80::/10 icmp6-type {128,133,134,135,136} tracker 1000000110 keep state
      pass in  quick inet6 proto ipv6-icmp from ff02::/16 to fe80::/10 icmp6-type {128,133,134,135,136} tracker 1000000111 keep state
      pass in  quick inet6 proto ipv6-icmp from fe80::/10 to ff02::/16 icmp6-type {128,133,134,135,136} tracker 1000000112 keep state
      # We use the mighty pf, we cannot be fooled.
      block log quick inet proto { tcp, udp } from any port = 0 to any tracker 1000000113
      block log quick inet proto { tcp, udp } from any to any port = 0 tracker 1000000114
      block log quick inet6 proto { tcp, udp } from any port = 0 to any tracker 1000000115
      block log quick inet6 proto { tcp, udp } from any to any port = 0 tracker 1000000116
      # Snort package
      block log quick from <snort2c>to any tracker 1000000117 label "Block snort2c hosts"
      block log quick from any to <snort2c>tracker 1000000118 label "Block snort2c hosts"
      # SSH lockout
      block in log quick proto tcp from <sshlockout>to (self) port 22 tracker 1000000301 label "sshlockout"
      # webConfigurator lockout
      block in log quick proto tcp from <webconfiguratorlockout>to (self) port 443 tracker 1000000351 label "webConfiguratorlockout"
      block in log quick from <virusprot>to any tracker 1000000400 label "virusprot overload table"
      # block bogon networks (IPv4)
      # http://www.cymru.com/Documents/bogon-bn-nonagg.txt
      block in log quick on $WAN from <bogons>to any tracker 1000001551 label "block bogon IPv4 networks from WAN"
      # block bogon networks (IPv6)
      # http://www.team-cymru.org/Services/Bogons/fullbogons-ipv6.txt
      block in log quick on $WAN from <bogonsv6>to any tracker 1000001552 label "block bogon IPv6 networks from WAN"
      antispoof log for $WAN tracker 1000001570
      # block anything from private networks on interfaces with the option set
      block in  quick on $WAN from 10.0.0.0/8 to any tracker 1000001581 label "Block private networks from WAN block 10/8"
      block in  quick on $WAN from 127.0.0.0/8 to any tracker 1000001582 label "Block private networks from WAN block 127/8"
      block in  quick on $WAN from 100.64.0.0/10 to any tracker 1000001583 label "Block private networks from WAN block 100.64/10"
      block in  quick on $WAN from 172.16.0.0/12 to any tracker 1000001584 label "Block private networks from WAN block 172.16/12"
      block in  quick on $WAN from 192.168.0.0/16 to any tracker 1000001585 label "Block private networks from WAN block 192.168/16"
      block in  quick on $WAN from fc00::/7 to any tracker 1000001586 label "Block ULA networks from WAN block fc00::/7"
      antispoof log for $LAN tracker 1000002620
      # allow access to DHCP server on LAN
      pass in  quick on $LAN proto udp from any port = 68 to 255.255.255.255 port = 67 tracker 1000002641 label "allow access to DHCP server"
      pass in  quick on $LAN proto udp from any port = 68 to 192.168.24.1 port = 67 tracker 1000002642 label "allow access to DHCP server"
      pass out  quick on $LAN proto udp from 192.168.24.1 port = 67 to any port = 68 tracker 1000002643 label "allow access to DHCP server"
      antispoof log for $KABELDE tracker 1000003670
      # allow our DHCP client out to the KABELDE
      pass in  on $KABELDE proto udp from any port = 67 to any port = 68 tracker 1000003691 label "allow dhcp client out KABELDE"
      pass out  on $KABELDE proto udp from any port = 68 to any port = 67 tracker 1000003692 label "allow dhcp client out KABELDE"
      # Not installing DHCP server firewall rules for KABELDE which is configured for DHCP.
      # loopback
      pass in  on $loopback inet all tracker 1000004761 label "pass IPv4 loopback"
      pass out  on $loopback inet all tracker 1000004762 label "pass IPv4 loopback"
      pass in  on $loopback inet6 all tracker 1000004763 label "pass IPv6 loopback"
      pass out  on $loopback inet6 all tracker 1000004764 label "pass IPv6 loopback"
      # let out anything from the firewall host itself and decrypted IPsec traffic
      pass out  inet all keep state allow-opts tracker 1000004765 label "let out anything IPv4 from firewall host itself"
      pass out  inet6 all keep state allow-opts tracker 1000004766 label "let out anything IPv6 from firewall host itself"
      pass out  route-to ( pppoe2 82.135.16.28 ) from 93.104.178.7 to !93.104.178.7/32 tracker 1000004861 keep state allow-opts label "let out anything from firewall host itself"
      pass out  route-to ( em1 188.194.217.254 ) from 188.194.217.58 to !188.194.217.0/24 tracker 1000004862 keep state allow-opts label "let out anything from firewall host itself"
      pass out  on $IPsec all tracker 1000005161 tracker 1000005162 keep state label "IPsec internal host to host"
      # make sure the user cannot lock himself out of the webConfigurator or SSH
      pass in  quick on em0 proto tcp from any to (em0) port { 443 80 22 } tracker 1000005171 keep state label "anti-lockout rule"
      # NAT Reflection rules
      pass in  inet tagged PFREFLECT tracker 1000005191 keep state label "NAT REFLECT: Allow traffic to localhost"
      # User-defined rules follow
      anchor "userrules/*"
      pass  in  quick  on $IPsec inet from any to any tracker 1415483079 keep state  label "USER_RULE: Allow ipsec to any mchome net"
      # array key "pptp" does not exist for "allow all for pptp" in array: {WAN LAN KABELDE IPsec } label "USER_RULE: allow all for pptp"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 ) inet from 6.1.47..0/25 to any tracker 1415483058 keep state  label "USER_RULE: allow ping from inetra"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 ) inet proto tcp  from any to 192.168.24.6 port 22 tracker 1415483053 flags S/SA keep state  label "USER_RULE: NAT SSH auf lxhome"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 ) inet proto tcp  from any to 192.168.24.6 port 25 tracker 1415483054 flags S/SA keep state  label "USER_RULE: NAT SMTP fuer GWAVA Proxy"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 ) inet proto tcp  from any to 192.168.24.6 port 993 tracker 1415483055 flags S/SA keep state  label "USER_RULE: NAT IMAPs auf GWIA"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 )  proto { tcp udp }  from any to 192.168.24.6 port $GWPorts tracker 1415483061 keep state  label "USER_RULE: NAT GWMTP IN auf SLES"
      pass  in  quick  on $WAN reply-to ( pppoe2 82.135.16.28 )  proto tcp  from any to 192.168.24.6 port 993 tracker 1415483062 flags S/SA keep state  label "USER_RULE: NAT IMAP auf GWIA"
      block  in  quick  on $WAN inet6 from any to any tracker 1415483060  label "USER_RULE: remove ipv6 from log"
      pass  in  quick  on $LAN  proto { tcp udp }  from 192.168.24.0/24 to 192.168.24.1 port 123 tracker 1415483066 keep state  label "USER_RULE: allow NTP"
      pass  in  quick  on $LAN inet proto { tcp udp }  from 192.168.24.0/24 to 10.0.47.0/24 tracker 1415483067 keep state  label "USER_RULE: redirect traffic to tunnel"
      pass  in  quick  on $LAN inet proto { tcp udp }  from 10.0.47.9 to 192.168.24.0/24 port 6556 tracker 1415483068 keep state  label "USER_RULE: allow check_mk to agent"
      pass  in  quick  on $LAN inet proto { tcp udp }  from 192.168.24.0/24 to 192.168.24.0/24 port 6556 tracker 1419415183 keep state  label "USER_RULE: allow check_mk to agent"
      pass  in  quick  on $LAN  proto tcp  from any to 6.1.47..0/25 port $ineports tracker 1415483069 flags S/SA keep state  label "USER_RULE: allow all inetra services"
      pass  in  quick  on $LAN  proto tcp  from any to 17.149.32.0/24 tracker 1415483070 flags S/SA keep state  label "USER_RULE: allow Apple Server"
      pass  in  quick  on $LAN inet proto { tcp udp }  from any  to <negate_networks>port 53 tracker 1419794934 keep state  label "NEGATE_ROUTE: Negate policy routing for destination"
      pass  in  quick  on $LAN  $GWWAN_PPPOE inet proto { tcp udp }  from any to any port 53 tracker 1419794934 keep state  label "USER_RULE: direct DNS to MNET"
      pass  in  quick  on $LAN inet proto { tcp udp }  from 192.168.24.0/24 to any port $guest_ports tracker 1415657006 keep state  label "USER_RULE: allow min ports for all"
      block  in  quick  on $LAN  proto { tcp udp }  from any to 169.254.255.255 port 136 >< 139 tracker 1415483076  label "USER_RULE: block cifs bc"
      # schedule finished - scheduled Zugriff auf Gamenetworks label "USER_RULE: scheduled Zugriff auf Gamenetworks"
      pass  in  quick  on $LAN inet from 192.168.24.0/24 to any tracker 1415483078 keep state  label "USER_RULE: Default LAN -> allow any"
      pass  in  quick  on $KABELDE reply-to ( em1 188.194.217.254 ) inet from 6.1.47..0/25 to any tracker 1415615732 keep state  label "USER_RULE: allow everything from inetra"
      pass  in  quick  on $KABELDE reply-to ( em1 188.194.217.254 )  proto tcp  from any to 192.168.24.6 port 993 tracker 1415483082 flags S/SA keep state  label "USER_RULE: NAT IMAP auf GWIA"
      pass  in  quick  on $KABELDE reply-to ( em1 188.194.217.254 ) inet proto icmp  from any to any tracker 1415483083 keep state  label "USER_RULE: allow ping from anywhere"
      # VPN Rules
      pass out   route-to ( pppoe2 82.135.16.28 )  proto udp from any to 6.1.47.71 port = 500 tracker 1000105301 keep state label "IPsec: inetra_LAN-DMZ - outbound isakmp"
      pass in  on $WAN  reply-to ( pppoe2 82.135.16.28 )  proto udp from 6.1.47.71 to any port = 500 tracker 1000105302 keep state label "IPsec: inetra_LAN-DMZ - inbound isakmp"
      pass out   route-to ( pppoe2 82.135.16.28 )  proto udp from any to 6.1.47.71 port = 4500 tracker 1000105303 keep state label "IPsec: inetra_LAN-DMZ - outbound nat-t"
      pass in  on $WAN  reply-to ( pppoe2 82.135.16.28 )  proto udp from 6.1.47.71 to any port = 4500 tracker 1000105304 keep state label "IPsec: inetra_LAN-DMZ - inbound nat-t"
      pass out   route-to ( pppoe2 82.135.16.28 )  proto esp from any to 6.1.47.71 tracker 1000105305 keep state label "IPsec: inetra_LAN-DMZ - outbound esp proto"
      pass in  on $WAN  reply-to ( pppoe2 82.135.16.28 )  proto esp from 6.1.47.71 to any tracker 1000105306 keep state label "IPsec: inetra_LAN-DMZ - inbound esp proto"
      anchor "miniupnpd"</negate_networks></bogonsv6></bogons></virusprot></webconfiguratorlockout></sshlockout></snort2c></snort2c></vpn_networks></vpn_networks></youtube></youtube></webdevices></webdevices></torpig></torpig></server></server></nodirect></nodirect></macmini></macmini></kabelhosts></kabelhosts></gamenetworks></gamenetworks></easyruleblockhostsopt2></easyruleblockhostsopt2></blockedhosts></blockedhosts></bad_peers></bad_peers></negate_networks></vpn_networks></bogonsv6></bogons></virusprot></snort2c></webconfiguratorlockout></sshlockout>
      these ips: 6.1.47..0 have been modified later.
        tracer
        # This file is automatically generated. Do not edit
        config setup
        	uniqueids = yes
        	charondebug="dmn 0,mgr 1,ike 2,chd 2,cfg 1,net 1,imv 0,esp 1"
        conn con1000
        	reqid = 1
        	fragmentation = yes
        	keyexchange = ikev1
        	reauth = yes
        	forceencaps = no
        	rekey = yes
        	installpolicy = yes
        	type = tunnel
        	dpdaction = restart
        	dpddelay = 10s
        	dpdtimeout = 40s
        	auto = route
        	left = 93.104.178.7
        	right = 6.1.47.71
        	leftid = @net.dyn.org
        	ikelifetime = 7200s
        	lifetime = 28800s
        	ike = aes128-sha1-modp1024!
        	esp = aes256-sha1-modp1024,aes256-sha1-modp1024!
        	leftauth = psk
        	rightauth = psk
        	rightid = 6.1.47.71
        	aggressive = no
        	rightsubnet = 10.0.47.0/24
        	leftsubnet = 192.168.24.0/24
        conn con1001
        	reqid = 2
        	fragmentation = yes
        	keyexchange = ikev1
        	reauth = yes
        	forceencaps = no
        	rekey = yes
        	installpolicy = yes
        	type = tunnel
        	dpdaction = restart
        	dpddelay = 10s
        	dpdtimeout = 40s
        	auto = route
        	left = 9.1.178.7
        	right = 6.1.47.71
        	ikelifetime = 7200s
        	lifetime = 28800s
        	leftauth = psk
        	rightauth = psk
        	rightid = 6.1.47.71
        	aggressive = no
        	rightsubnet = 10.0.48.0/24
        • E Offline
          eri--
          This happens even when you are initiator?
          I belive your other side is coming on your other interface while you expect it on WAN?
            tracer
            I think this end is initiator and responder, b/c the other side opens the tunnels as well.
            BTW I already did a packettrace on the "other" interface to see if there's traffic (UDP&port 500) coming or going.
            Nothing !
            But I can check the other Pfs 2.1.5 tomorrow.
            I deliberately change the tunnel to this other IF and check the the dyn address points to the correct IP and IF.
              tracer
              Update:
              Just check the 2.1.5 side and no packets go to the wrong Public IF of the 2.2.
                tracer
                Updated and still same tunnnel problems ?
                2.2-RC (amd64)
                built on Fri Jan 16 11:53:08 CST 2015
                @Ermal: Do you think my NAT & Firewall Rules are ok on the WAN IF ?
                  doktornotor Banned
                  What NAT again? You've already been told you cannot NAT IPsec.
                    tracer
                    Outbound NAT:
                    Automatic Rules.
                    And pls let me know where I was told to "not NAT IPsec" ?
                      tracer
                      And BTW a just captured packets on my WAN and could see ISAKMP (Main Mode) going forth and back between both pfsenses.
                        doktornotor Banned
                        @tracer:
                        https://forum.pfsense.org/index.php?topic=86590.msg475029#msg475029
                          tracer
                          @doktornotor: Checking my reply, I said I remove "any NAT rules" meaning the ones I manually created !
                          But as known, the "Automatic Outbound NAT rules" persist due the mode !
                          So I'm pretty sure that if config is correctly interpreted by pfSense no manual rule should interfere.
                          But my Question was if any of the other inbound rules could interfere with VPN ?
                          Do you have an answer for this ?
                            cmb
                            The automatic outbound NAT rules won't hurt anything with IPsec.
                            For inbound, if you have a port forward on UDP 500 or ESP traffic, that'll break it also. If you have a 1:1 NAT using the public IP where it terminates, that'll forward the traffic to an internal host and break things as well.
                              tracer
                              Hmm, thanks, but I can't find any inbound NATs with 500.
                              Maybe we should look at it using our old support contract ?
                                cmb
                                @tracer:
                                Commercial support is definitely the best answer. Your support expired over 5 years ago though, if you purchase to activate support on your account again, we can definitely assist.
                                  tracer
                                  I'll pm you on this, ok ?
