    Multi wan "load balance" and "Failover" are not working…Need our experts help
    1 Posts 1 Posters 677 Views
    • I Offline
      isoliman
      Dear All
      After install squid and squidgard, The multi wan "load balance" are not working
      when stop the Main ADSL routers WAN1 "WANGW"  and keep the second ADSL WAN2 "OPT1GW" ONLINE
      The browsing and the ping stopped !!
      While the default WANGW is OFFLINE is should turn to the other ADSL WAN2 "OPT1GW" but doesn't happened  !!!
      I have review all the recommended configurations for the load balance and fail over as well as show below
      Configure interfaces LAN, WAN1 "WANGW" and WAN2 "OPT1GW"
      Configure Routing , Gateways and Groups
      Load_Balance
      Tier 1
      WANGW, Online
      OPT1GW, Online
      Load_Balance
      WANI_Failover
      Tier 1 Tier 2
      WANGW, Online
      OPT1GW, Online
      If WANI_Down>>WANII
      WANII_Failover
      Tier 1 Tier 2
      OPT1GW, Online
      WANGW, Online
      If WANII_Down>>WANI
      When I've forced and switch it manually to OPT1GW (default)  from WANGW
      After switch it manually the ping and browsing return back to normal status "UP"
      Something in the PFsense doesn't start or not triggered the load balance or fail over function
      Appreciate the experts from this respectful forum to advise soon
