    Problem with squid after 2.1.5 fresh install
    16 Posts 3 Posters 2.2k Views
    • F Offline
      firefox
      After that pfsense 2.2
      Did not work right
      I removed it and installed 2.1.5
      I reinstalled the packages that I had
      Everything works well
      Apart from squid
      For some reason
      Works on and off
      All settings are identical to previous
      I used the backup tool
      config-home.plex-20141227195341
      • marcellocM Offline
        marcelloc
        No info, just a doesn't work? ???
        This way is almost impossible to help.
        • F Offline
          firefox
          You're right
          Sorry
          But what information to give ?
          This new installation
          Maybe this will help
          • F Offline
            firefox
            @marcelloc:
            What information is needed ?
            Tell me and I will write
            How do I arrange it
            It should work exactly the same settings as before formatting
            I used a backup option
            Before formatting everything worked well
            If it's the same settings
            Even now everything should work well
            But not
            • KOMK Offline
              KOM
              Go to System - Packages.  Go to the entry for Squid that you have installed.  Click the small PKG button to reinstall it.  It should now work.
              • F Offline
                firefox
                I tried this option
                It is the same situation
                No change
                • KOMK Offline
                  KOM
                  Sorry, thought you were still on 2.2.
                  What information is needed ?  Tell me and I will write
                  Transparent or standard mode?  How does it not work, exactly?  Are there any error messages?  Did you change any options on any of the Squid tabs?  How are you testing?  Which browser are you using?
                  • F Offline
                    firefox
                    I use Fire Fox
                    Transparent or standard mode ?
                    Transparent
                    where can i see error messages ?
                    no
                    It's just like the picture
                    Just like before formatting when it worked
                    I did not understand this question
                    • KOMK Offline
                      KOM
                      Status - System logs - General
                      Also, look at the Squid logs that you can find in /var/squid/logs.  Do you have anything of note in either cache.log or access.log?
                      • F Offline
                        firefox
                        Feb 5 20:01:59 	php: /diag_logs.php: Successful login for user 'admin' from: 192.168.0.2
                        Feb 5 20:01:39 	squid[54001]: Exiting due to repeated, frequent failures
                        Feb 5 20:01:39 	kernel: pid 88906 (squid), uid 62: exited on signal 6
                        Feb 5 20:01:39 	squid[54001]: Squid Parent: child process 88906 exited due to signal 6
                        Feb 5 20:01:39 	squid[88906]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:01:38 	squid[54001]: Squid Parent: child process 88906 started
                        Feb 5 20:01:35 	squid[54001]: Squid Parent: child process 88492 exited due to signal 6
                        Feb 5 20:01:36 	kernel: pid 88492 (squid), uid 62: exited on signal 6
                        Feb 5 20:01:35 	squid[88492]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:01:35 	squid[54001]: Squid Parent: child process 88492 started
                        Feb 5 20:01:34 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 20:01:33 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 20:01:32 	kernel: pid 76606 (squid), uid 62: exited on signal 6
                        Feb 5 20:01:32 	squid[54001]: Squid Parent: child process 76606 exited due to signal 6
                        Feb 5 20:01:32 	squid[76606]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:01:32 	squid[54001]: Squid Parent: child process 76606 started
                        Feb 5 20:01:30 	check_reload_status: Reloading filter
                        Feb 5 20:01:29 	Squid_Alarm[72921]: Squid has resumed. Reconfiguring filter.
                        Feb 5 20:01:29 	kernel: pid 71236 (squid), uid 62: exited on signal 6
                        Feb 5 20:01:29 	squid[54001]: Squid Parent: child process 71236 exited due to signal 6
                        Feb 5 20:01:29 	squid[71236]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:01:29 	check_reload_status: Reloading filter
                        Feb 5 20:01:29 	squid[54001]: Squid Parent: child process 71236 started
                        Feb 5 20:01:28 	Squid_Alarm[70911]: Reconfiguring filter...
                        Feb 5 20:01:26 	kernel: pid 54327 (squid), uid 62: exited on signal 6
                        Feb 5 20:01:26 	squid[54001]: Squid Parent: child process 54327 exited due to signal 6
                        Feb 5 20:01:26 	squid[54327]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:01:25 	squid[54001]: Squid Parent: child process 54327 started
                        Feb 5 20:01:25 	Squid_Alarm[52781]: Attempting restart...
                        Feb 5 20:01:25 	Squid_Alarm[52575]: Squid has exited. Reconfiguring filter.
                        Feb 5 20:00:39 	squid[17360]: Exiting due to repeated, frequent failures
                        Feb 5 20:00:39 	kernel: pid 50065 (squid), uid 62: exited on signal 6
                        Feb 5 20:00:39 	squid[17360]: Squid Parent: child process 50065 exited due to signal 6
                        Feb 5 20:00:39 	squid[50065]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:00:39 	squid[17360]: Squid Parent: child process 50065 started
                        Feb 5 20:00:36 	kernel: pid 49654 (squid), uid 62: exited on signal 6
                        Feb 5 20:00:36 	squid[17360]: Squid Parent: child process 49654 exited due to signal 6
                        Feb 5 20:00:36 	squid[49654]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:00:36 	squid[17360]: Squid Parent: child process 49654 started
                        Feb 5 20:00:35 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 20:00:33 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 20:00:33 	kernel: pid 39792 (squid), uid 62: exited on signal 6
                        Feb 5 20:00:33 	squid[17360]: Squid Parent: child process 39792 exited due to signal 6
                        Feb 5 20:00:33 	squid[39792]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:00:32 	squid[17360]: Squid Parent: child process 39792 started
                        Feb 5 20:00:30 	check_reload_status: Reloading filter
                        Feb 5 20:00:29 	kernel: pid 37034 (squid), uid 62: exited on signal 6
                        Feb 5 20:00:29 	squid[17360]: Squid Parent: child process 37034 exited due to signal 6
                        Feb 5 20:00:29 	squid[37034]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:00:29 	Squid_Alarm[38910]: Squid has resumed. Reconfiguring filter.
                        Feb 5 20:00:29 	squid[17360]: Squid Parent: child process 37034 started
                        Feb 5 20:00:28 	check_reload_status: Reloading filter
                        Feb 5 20:00:28 	Squid_Alarm[36468]: Reconfiguring filter...
                        Feb 5 20:00:25 	kernel: pid 17722 (squid), uid 62: exited on signal 6
                        Feb 5 20:00:25 	squid[17360]: Squid Parent: child process 17722 exited due to signal 6
                        Feb 5 20:00:25 	squid[17722]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 20:00:25 	squid[17360]: Squid Parent: child process 17722 started
                        Feb 5 20:00:25 	Squid_Alarm[16292]: Attempting restart...
                        Feb 5 20:00:25 	Squid_Alarm[15926]: Squid has exited. Reconfiguring filter.
                        Feb 5 20:00:02 	php: sarg.php: The command 'export LC_ALL=C && /usr/pbi/sarg-i386/bin/sarg ' returned exit code '1', the output was 'SARG: File not found: /var/log/squid/access.log'
                        Feb 5 20:00:01 	php: sarg.php: Sarg: force refresh now with args, compress(on) and none action after sarg finish.
                        Feb 5 19:59:38 	squid[91148]: Exiting due to repeated, frequent failures
                        Feb 5 19:59:38 	kernel: pid 8568 (squid), uid 62: exited on signal 6
                        Feb 5 19:59:38 	squid[91148]: Squid Parent: child process 8568 exited due to signal 6
                        Feb 5 19:59:38 	squid[8568]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 19:59:38 	squid[91148]: Squid Parent: child process 8568 started
                        Feb 5 19:59:35 	kernel: pid 7864 (squid), uid 62: exited on signal 6
                        Feb 5 19:59:35 	squid[91148]: Squid Parent: child process 7864 exited due to signal 6
                        Feb 5 19:59:35 	squid[7864]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 19:59:35 	squid[91148]: Squid Parent: child process 7864 started
                        Feb 5 19:59:34 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 19:59:33 	php: rc.filter_configure_sync: Could not find IPv4 gateway for interface (opt1).
                        Feb 5 19:59:32 	kernel: pid 98141 (squid), uid 62: exited on signal 6
                        Feb 5 19:59:32 	squid[91148]: Squid Parent: child process 98141 exited due to signal 6
                        Feb 5 19:59:32 	squid[98141]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 19:59:31 	squid[91148]: Squid Parent: child process 98141 started
                        Feb 5 19:59:30 	check_reload_status: Reloading filter
                        Feb 5 19:59:29 	Squid_Alarm[96538]: Squid has resumed. Reconfiguring filter.
                        Feb 5 19:59:28 	kernel: pid 95045 (squid), uid 62: exited on signal 6
                        Feb 5 19:59:28 	squid[91148]: Squid Parent: child process 95045 exited due to signal 6
                        Feb 5 19:59:28 	squid[95045]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        Feb 5 19:59:28 	check_reload_status: Reloading filter
                        Feb 5 19:59:28 	squid[91148]: Squid Parent: child process 95045 started
                        Feb 5 19:59:28 	Squid_Alarm[94263]: Reconfiguring filter...
                        Feb 5 19:59:25 	kernel: pid 91391 (squid), uid 62: exited on signal 6
                        Feb 5 19:59:25 	squid[91148]: Squid Parent: child process 91391 exited due to signal 6
                        Feb 5 19:59:25 	squid[91391]: Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
                        how do i see this ?
                        • KOMK Offline
                          KOM
                          how do i see this ?
                          pfSense is built on FreeeBSD.  Use the 8) Shell option from the console to get to a command prompt.  Never mind access.log and cache.log for now.  What happens when you shell in and run squid -z?
                            marcelloc
                            First screenshots show a running squid and havp stopped.
                            I suggest you testing a daemon/package at a time.
                            • F Offline
                              firefox
                              @KOM:
                              how do i see this ?
                              it worked
                              I remember this command
                              To my knowledge
                              I used the command after power failure
                              @marcelloc:
                              after i used```
                              squid -z
                              • F Offline
                                firefox
                                @marcelloc:
                                how do i do that ?
                                  marcelloc
                                  @firefox:
                                  how do i do that ?
                                  Disable HAVP integration and test squid package only.
                                  Once you get it working, test havp.
                                  • F Offline
                                    firefox
                                    @marcelloc:
                                    @firefox:
                                    how do i do that ?
                                    I guess I've done it
                                    That's the only way I had Internet access
                                    Only I did not know
                                    The test is done like this
                                    thank you both
