    Squidguard… problems and questions
    31 Posts 8 Posters 40.1k Views
    • X Offline
      xhark
      I delete and reinstall ?
      SysNetAdmin & Blogger on http://blogmotion.fr
        dvserg
        @xhark:
        Hm.. Try full reinstall :D
        SquidGuardDoc EN  RU Tutorial
        Localization ru_PFSense
        • X Offline
          xhark
          I talk about package ^^
            dvserg
            @xhark:
            Yes. Reinstall package
            • X Offline
              xhark
              It's done but not filtering is active :(
              Can I delete times ?
              here is my log :
              5.05.2008 16:44:52 : sg_reconfigure: Begin.
              15.05.2008 16:44:52 : sg_reconfigure_user_db: Begin with '/var/db/squidGuard'
              15.05.2008 16:44:52 : sg_reconfigure_user_db: Nothing. User destinations list empty.
              15.05.2008 16:44:52 : sg_remove_unused_db_entries: Begin.
              15.05.2008 16:44:52 : sg_remove_unused_db_entries: end
              15.05.2008 16:44:52 : sg_create_config: Create squidGuard config.
              15.05.2008 16:44:52 : sg_create_config: Checking configuration data.
              15.05.2008 16:44:52 : sg_create_config: Error configuration data. It's all errors:
              BLACKLIST 'blk_blacklists_agressif' error: file '/var/db/squidGuard/blk_blacklists_agressif' not found
              BLACKLIST 'blk_blacklists_drugs' error: file '/var/db/squidGuard/blk_blacklists_drugs' not found
              BLACKLIST 'blk_blacklists_mail' error: file '/var/db/squidGuard/blk_blacklists_mail' not found
              BLACKLIST 'blk_blacklists_porn' error: file '/var/db/squidGuard/blk_blacklists_porn' not found
              BLACKLIST 'blk_blacklists_publicite' error: file '/var/db/squidGuard/blk_blacklists_publicite' not found
              BLACKLIST 'blk_blacklists_redirector' error: file '/var/db/squidGuard/blk_blacklists_redirector' not found
              BLACKLIST 'blk_blacklists_violence' error: file '/var/db/squidGuard/blk_blacklists_violence' not found
              15.05.2008 16:44:52 : sg_create_config: Terminated.
              15.05.2008 16:44:52 : sg_create_simple_config: Begin with dbhome='/var/db/squidGuard'.
              15.05.2008 16:44:52 : sg_redirector_base_url: Select redirector base url (https://192.168.0.254/sgerror.php?url=Error%21%20Check%20squidGuard%20configuration%20data.%20%28sg_create_config%3A%20%5B2%5D%29.&a=%a&n=%n&i=%i&s=%s&t=%t&u=%u)
              15.05.2008 16:44:52 : sg_reconfigure: Generate squidGuard config and save to '/usr/local/etc/squidGuard/squidGuard.conf'.
              15.05.2008 16:44:52 : squid_reconfigure: Begin.
              15.05.2008 16:44:52 : squid_reconfigure: Remove old redirector options from Squid config.
              15.05.2008 16:44:52 : squid_reconfigure: Add new redirector options to Squid config.
              15.05.2008 16:44:52 : sg_init: Start.
              15.05.2008 16:45:01 : sg_init: Start.
              15.05.2008 16:45:02 : sg_init: Start.
                dvserg
                Upload blacklist previous version not make blacklist archive. And temporary set HTTP webGUI pfSense. In https can have troubles.
                • X Offline
                  xhark
                  What can I do ? If I add small GZ blacklist it's OK, but with big blacklist it fails (ftp://ftp.univ-tlse1.fr/pub/reseau/cache/squidguard_contrib/blacklists.tar.gz)
                    dvserg
                    @xhark:
                    Check you url manually - may be broken arhive?
                    Also looking this http://www.squidguard.org/blacklists.html,
                    i use http://www.shallalist.de/Downloads/shallalist.tar.gz
                    • X Offline
                      xhark
                      Yes I've open this with 7zip without any problem.
                      I've test to send this in /tmp/my_directory and precise local directory to SG config, but same problem. I'll test your list and go back here ;)
                        dvserg
                        @xhark:
                        Ok
                        I will test and replay here.
                          jwbrown77
                          I was having some squidguard problems too and tracked down a different issue than what I've seen in this thread.
                          I am attempting to run the shallalist rules and after a lot of troubleshooting I finally noticed in the squidguard log that it couldn't find blk_BL_politics
                          I noticed that there's a blk_BL_politcs (notice no i) but not one with the proper spelling.  So I just symlinked the proper spelling to the improper spelling and after that it seems to work fine.
                          Thanks to the package maintainer for providing this software.
