    Pf 2.2 not starting after power failure
    10 Posts 3 Posters 2.2k Views
      nikkon
      Hi all,
      I got this in console mode and it seems to be stuck there:
      7731 files, 6781g_vfs_done():18 used, 1180808ufs/pfsense0[WRITE(offset=237568, length=1536)] free (448 fragserror = 30
      , 147545 blocks, 0.0% fragmentation)
      mount reload of '/' failed: Read-only file system
      ** /dev/ufs/cf
      ** Last Mounted on /cf
      ** Phase 1 - Check Blocks and Sizes
      ** Phase 2 - Check Pathnames
      ** Phase 3 - Check Connectivity
      ** Phase 4 - Check Reference Counts
      ** Phase 5 - Check Cyl groups
      25 files, 2666 used, 98389 free (21 frags, 12296 blocks, 0.0% fragmentation)
      ***** FILE SYSTEM IS CLEAN *****
      rm: /conf: Read-only file system
      ln: /conf/conf: Read-only file system
      g_vfs_done():ufs/cf[WRITE(offset=237568, length=512)]error = 30
      Setting up memory disks… done.
      pwd_mkdb: /etc//pwd.db.tmp: Read-only file system
      ___
      / f
      / p _
      / Sense
      _
          _
      _/
      Welcome to pfSense 2.2-RELEASE  ...
      cp: /var/db/pbi/keys/pfSense-BETA.ssl: Read-only file system
      Creating symlinks...rm: /conf: Read-only file systemg
      _vfs_done():ufs/cf[WRITE(offset=26357760, length=4096)]error = 30
      …ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
      32-bit compatibility ldconfig path: /usr/lib32
      done.
      cap_mkdb: /etc/login.conf.db: Read-only file system
      g_vfs_done():ufs/cf[WRITE(offset=8192, length=1536)]error = 30
      g_vfs_done():ufs/cf[WRITE(offset=26353664, length=4096)]error = 30
      g_vfs_done():ufs/cf[WRITE(offset=26357760, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477347840, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477351936, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477356032, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477368320, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477376512, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=477380608, length=4096)]error = 30
      g_vfs_done():ufs/pfsense0[WRITE(offset=490606592, length=4096)]error = 30
      pfsense 2.3.4 on Supermicro A1SRi-2758F + 8GB ECC + SSD
      Happy PfSense user :)
        nikkon
        after a fsck -y seems to work but I still see those errors in logs.system is loaded from an sd card.
          doktornotor Banned
          Stop repairing. Replace the card, reimage and restore latest config backup.
            nikkon
            ok…not what i have expected...card is brand new...but still...i'll do that.
            thx for the answer.
              doktornotor Banned
              I've had tons of "brand new" SD cards DoA. My sad experience is that the "quality" goes quickly down, the higher the class is. Class 10 were a total disaster, more of those were broken than actually working. I assume you have no other option than using an SD card?
                nikkon
                unfortunatelly i only have sd option.damn…lexar must be better i guess...judging from the price...
                • 2 Offline
                  2chemlud Banned
                  Hi!
                  Would be interesting to know the brand/product number of the card. Running a little farm of raspberry pis (24/7) always interested in SD-card experiences…
                  Regards
                  chemlud
                    nikkon
                    now i run the Trancend class 10 4 gb
                      doktornotor Banned
                      @nikkon:
                      Hmmm… Well, you can try to reimage the current card as well, but really chances are high it will either not help or it's gonna crap out again soon... (Repairing filesystem is a total waste of time, wouldn't trust the result at all...)
                        nikkon
                        just ordered new cards.hope this time will work more time :)
