    PfSense internet does not work ( Need desperate help!! )
    43 Posts 9 Posters 10.1k Views
      Koenvuurens
      Welp… Not getting ethernet anymore.
      I set up this:
      WAN: 192.168.2.99 /24
      LAN: 192.168.1.1 /24
      I have one and only direct connection with my server to the pfSense box. (the pfSense does have the WAN and the LAN connected)
      When I go to my browser and type 192.168.1.1:24 then I get the error: This Webpage Isn't available.
      Soo... What do I need to do?
        doktornotor Banned
        @Koenvuurens:
        What? ??? Why are you pointing your browser to port 24? You do NOT type 24 into the browser, that is a netmask!  :o
          Koenvuurens
          whoops I said it wrong, No I dont type :24
          • KOMK Offline
            KOM
            OK, we have spent enough time hunting and guessing in the dark.  Please take and post the following screenshots:
            Interfaces - WAN
            Interfaces - LAN
            Firewall - Rules - LAN
            Your Windows Network IP4 Ethernet Properties
            If you are paranoid, scrub any public IP addresses in your shots.
              Koenvuurens
              Yes, but that is not the problem ! I cant acces the WebConfigurator. So I can make screenshots if you want but I cant acces it!!
                Dude can you ping pfsense lan IP from the computer your trying to access the web gui from?
                So can you ping 192.168.1.1 ?
                From you computer is static or dhcp?  Please post ipconfig /all – assuming your on windows?
                  Koenvuurens
                  Yes I can ping the pfsense box
                  and the settings are in the attachment!
                  Untitled.png_thumb
                    then you should just be able to go http://192.168.1.1
                    Unless your browser is using a proxy that should open, or redirect you to https://192.168.1.1 and the webgui.
                      Koenvuurens
                      Okey, got it working again.
                      but still no ethernet through my pfSense
                      Attachments are:
                      Interfaces - WAN
                      Interfaces - LAN
                      screen1.png_thumb
                      screen2.png_thumb
                      screen3.png_thumb
                      screen4.png_thumb
                        Well sure looks like ethernet is working to me if your connected to the gui..
                        So you set static on your PC.. If you meant no internet on your pc, yeah you didn't set any dns.. So how would you expect your pc to lookup anything?
                          Koenvuurens
                          err… sorry... I dont understand that!
                          Would you like to explain that a liiiiiiiiiiiiiiiitle bit more?
                          but I said already in the first post that I ask a lot of questions
                            Koenvuurens
                            Oh do I need to set the DNS to the pfSense box? maybe? …
                              you said ethernet, ethernet is not the internet.. That is your local network connection, etc..  which is clearly working if you can access the pfsense webgui via IP address.
                              Normally yes pfsense would dns for your network, but it can be anything you want.  But if your going to setup a static IP and you want that box to resolve say www.google.com then yeah needs dns.. your picture was NOTHING..  So no shit kind of hard to resolve www.google.com or www.pfsense.com or www.cnn.com, etc. etc..
                                Koenvuurens
                                Sorry about the ethernet/internet problem, I am dutch already I said…(my english is not very good)
                                So... I can just put anything in the DNS box?
                                  you can put in anything you want that is a valid nameserver that will resolve what you want.. Putting in say 8.8.8.8 (googledns) isn't going to resolve any local stuff that pfsense would know about, etc.
                                    Koenvuurens
                                    So …? Do I need to put in the dns box 8.8.8.8 ?
                                    also I already tried that and still not getting internet
                                      So from the web gui, go to diag, dns lookup - can you look up www.google.com for example
                                      Go to diag, ping - can you ping 8.8.8.8 ?  See attached screenshots
                                      If you can not get to the internet, how are you posting this stuff?
                                      doesthiswork.png_thumb
                                      ping.png_thumb
                                        Koenvuurens
                                        I post these posts with my 2nd link to the internet, but want do put an better router inbetween it.
                                        See attachments.
                                        screen5.png_thumb
                                        screen6.png_thumb
                                          Koenvuurens
                                          I mean an powerfuller router with 6 links( 1 WAN and 5 LAN) and a WIFI- card.
                                            Koenvuurens
                                            Can somebody help …?
