    Alix 2c3 problems, kernel: pflog0: promiscuous mode enabled
    25 Posts 6 Posters 10.8k Views
    • L Offline
      lagreca
      Hopefully I will be getting a new PS for it today and will be able to test.  I'll let you know what I find.
      • L Offline
        lagreca
        Tried with a Linksys WRT54G power supply today, 12v, 1,000ma.  I'm still getting weirdness in the logs:
        Last 100 system log entries
        Apr 14 20:40:00 check_reload_status: check_reload_status is starting
        Apr 14 14:50:21 php: : Not a valid interface action ""
        Apr 14 14:50:21 php: : Processing -
        Apr 14 14:50:21 php: : Processing start -
        Apr 14 14:50:21 php: : Hotplug event detected for vr0 but ignoring since interface is not set for DHCP
        Apr 14 14:50:21 php: : Processing vr0 - start
        Apr 14 14:50:20 check_reload_status: rc.linkup starting
        Apr 14 14:50:19 kernel: vr0: link state changed to UP
        Apr 14 14:50:16 kernel: vr0: link state changed to DOWN
        Apr 14 13:56:30 login: login on console as root
        Apr 14 13:56:30 check_reload_status: check_reload_status is starting
        Will try again with a 12v 3.3amps or a 15v 1.2amps.
        • GruensFroeschliG Offline
          GruensFroeschli
          Could it be that your switch or whatever device you have on the other side of this link is broken?
          My log looked similar when my ADSL-modem-router was in the proccess of dying…
          Took me a while to figure that out since it was happening unregularly.
          • L Offline
            lagreca
            I suppose its possible.  However, VR0 is the WAN interface, which is connected to the cable modem.
            I guess a good test would be to hook an ALIX up at my house and see if VR0 goes up and down.  If not, maybe the cable modem ethernet port is going bad?
              tbone
              I changed out my PS last night to an 18V 2.2 amp supply.  It seems to have stopped the random freezing I was experiencing, but time will tell.
              lagreca,
              I'm getting the same messages as you on my vr0, even with the new power supply but I think my vr0 is my lan inteface (need to check tonight).  I'm not sure what is causing it either but now I'm thinking it cold be a switch plugged into the vr0 port.
