    Options for fan speed control (Winbond SuperIO chips)
    6 Posts 3 Posters 2.3k Views
      pkirkovsky
      I have some 1U "network appliance" type of boxes that currently run pfSense quite well, but they're a bit too loud. These machines use Winbond W83627EHF chips which seem to be supported on other operating systems. On Windows I can control fans successfully with SpeedFan. On Linux, I can apparently use lm_sensors.
      In my research I've tried ipmitool (no IPMI hardware available), editing ACPI cooling settings with sysctwl -w (no apparent effect), and bsdhwmon (unsupported board).
      Are there any other methods of controlling the fan speed in software?
        You can always write to the superio chip registers directly. That's what the Watchguard script does.
          pkirkovsky
          @stephenw10:
          Ah, I didn't realize that the Watchguard boxes use the same SuperIO chip. I'll take a look at your source code and see if I can build on it. Thanks!
            It may not be identical but the Winbond chips share a lot of the registers etc.
            Look at the source and then check the specific datasheet for your chip. It's unfortunately pretty confusing.
            • O Offline
              ohmantics
              I wish there were a general API for this stuff that we could simply write a driver for. Writing one-off tools and adding scripts to manage them is so much less attractive than having the OS self-manage once all the resources are described to it.
                Interestingly the lm driver was ported to FreeBSD in 2007 but never included. There were some reasons given, I forget now though. That would have made things a lot easier.
                http://lists.freebsd.org/pipermail/freebsd-current/2007-September/076966.html
