CARP + LANs not routing between interfaces
Hi Guys,
I have a cenario with 2 pfsense 2.2.2, describes above:
When the eth2 is down, the pfsense2 change the interface to master correctly, but the Server1 and Server2 can't connect each other. Just when I turn off eth1 and pfsense2 change to master.
The Servers are XenServer 6.5 with LAG working well.
I'm looking for a solution like when eth1 or eth2 down, all interfaces down too or a solution not too agressive.
Thanks.
I don't understand "LAGG+CARP." Are you trying to put one LAGG member port to pfSense 1 and one to pfSense 2? That won't ever work. Or are there undiagrammed switches performing the LAGG from the XenServers? What CARP are you using on XenServers? I didn't know they did CARP.
Hi Derelict,
Each interface (eth1,eth2,eth3,eth4) can substituted per lagg1,lagg2,lagg3,lagg4. I did Carp over Lagg.
However, I found other solution: I put in "System >> High Availability Sync >>pfsync Synchronize Peer IP" of the master the ip of the slave and in the slave, I put the ip of the master.
I don't now if is the best solution but is working well.
Derelict, did you understand?
Thanks for your help.
That's how you sync states.
