    {SOLVED} Network Interface module is load after check for interface at boot
    4 Posts 2 Posters 2.4k Views
      bl00d666
      i'm currently setuping pfsense 2.2 on a computer, and the onboard ethernet controller was not detected.
      it's a Qualcomm Atheros ar8171 Gigabit ethernet and i find a module driver for it on the forum "if_alx.ko"
      i copy the file in /boot/modules as instructed. i manually load the module with kldload, setup my Lan interface, and access my webconfiguration page trough it. Work fine.
      now i reboot to see if the module load correctly at boot and i see :
      warning configuration references interfaces that do not exist: alx0
      network interface mismatch – running interface assignement option.
      now i have to config the interface just like i did the first time and as soon as  say yes to the "do you want to proceed" question,  Bam the module is loading
      is there a way to make the module load BEFORE the interface check ?
        charliem
        @bl00d666:
        To load the driver as a module at boot time, add the following line in /boot/loader.conf.local:
        if_alx_load="YES"
        If you don't have a file /boot/loader.conf.local, create one, and put that line in it.
        But, I think that the alx driver you found is an out-of-tree driver, and is now obsolete since support for ar8171 was added to FreeBSD 10.1 stable alc(4) driver.  https://lists.freebsd.org/pipermail/svn-src-stable-10/2014-October/003598.html
        I don't know if that support made it into pfSense 2.2.2, but you should certainly try 2.2.2 rather than 2.2; you may find ar8171 is supported already.  If not, I'd try to get the if_alc.ko module from a FreeBSD 10.1 stable snapshot, and use that rather than if_alx.ko
        alc(4) man page is here: https://www.freebsd.org/cgi/man.cgi?query=alc&apropos=0&sektion=4&manpath=FreeBSD+10.1-stable&arch=default&format=html
          bl00d666
          sorry missing that info, i already add the line in the boot.config.local but i add if_alc_load=yes instead of if_alx_load=yes as it was mention in te other post i saw.
          fyi i am on 2.2.2 but the alx module is still missing. something to do with the cut before the rc of pfsense or something.
          anyway, changing the c for an x WORK !!!
          Thanks CharlieM
            charliem
            @bl00d666:
            So to be clear, 2.2.2 does not detect your ar8171? alc is the proper driver for that chip, not alx.
            I've raised a bug in redmine asking to update alc(4), if it's not already in place for the 2.2.3 release.
            https://redmine.pfsense.org/issues/4725
            [edit] Looks like that will not be included until 2.3, unless someone submits a patch, but r273366 should drop right in.
