    Help Issues with Pfsense 2.2.2 and HP DL360 G8 ,smart array B320i
    3 Posts 3 Posters 875 Views
      tbaror
      Hi All,
      I am trying to install Pfsense 2.2.2 on HP DL360 G8 with smart array B320i,
      I created raid one , but the installer doesn't detect the disk and i bit stacked now
      Any idea
      Please advice
      • jimpJ Offline
        That's not a true RAID controller but a software/driver RAID controller, and it does not appear to be supported by FreeBSD.
        If it can expose the disks directly, you might try that. Otherwise you'll need to use a different controller / remove the RAID /etc.
        Do not Chat/PM for help!
          rainer_d
          These controllers are crap.
          We couldn't get them to work with anything (Linux, FreeBSD) and gave up rather quickly.
          Just buy a regular SmartArray P420 - anything else is not worth the time.
