    NAT Reflection (Pure NAT) not working for same subnet (v2.2.2)
    43 Posts 14 Posters 19.1k Views 7 Watching
      And do you have this checked?
      • rossc719R Offline
        rossc719
        Yes.
          Well works fine here..
          I just created a port forward to 192.168.9.10 port 80..
          I enabled nat reflection, pure nat... Hit my wan IP 64.53 - and there you go it WAD..
          You can see it natted my traffic from 192.168.9.100 to 64.53.x.x to souce IP of my lan interface 192.168.9.253
          • rossc719R Offline
            rossc719
            Ok. I believe that it works for you. But, It does not work for me.
            Whatever this bug is, it is clear that it is not happening to everyone.
            I don't know what would be peculiar about my setup.
            It is relatively fresh, only a few weeks old, and I have only a few rules set up (so far). Nothing complex at all. This NAT reflection was the first "interesting" thing I tried.
            I don't know what I could do to convince you that I really am experiencing this issue, but I'm happy to try if you have suggestions.
              @rossc719 said in NAT Reflection (Pure NAT) not working for same subnet (v2.2.2):
              A "bug" can be duplicated and normally easy to replicated...
              Whatever is going on with your specific scenario is not a bug, unless you can show other people having the issues that is not from 5 years ago - which I just tried and works as designed..
              When create the port forward and you have that checked, it will auto create the rule that does the source natting... Did you check that after the fact? After you have created your port forward?
              To be honest they really could just rip out and remove all the nat reflection shit to be honest.. Its NOT how things should be done in the first place... I would never in a million years setup such a hack ;) If I wanted to get to my webserver next to me, then I would resolve its fully qualified domain to that IP, or use that IP... Makes ZERO sense to hit my wan IP in the first place ;)
              But as you can see, even someone that doesn't use nat reflection, and hates it at professional level - it clearly WAD.. It was couple clicks to get that nonsense working. Simple 1 click setting up host override easier and cleaner solution ;)
              BTW - what mask are you running on your network?
              I've got a web server running @ 192.168.5.1.
              I am testing using my phone @ 192.168.10.1.
              My LAN interface of the pfsense is @ 192.168.0.1.
              To any sane person that would be 3 different networks.. Are you using a /16 or something? To allow for the 65K devices you have on it? ;)
              rossc719R 1 Reply Last reply Reply Quote 0
              • rossc719R Offline
                rossc719 @johnpoz
                Yes. It was not there.
                Specifically, there were no "nat on" lines that related to port 80 at all.
                In fact, there still aren't:
                [2.4.5-RELEASE][admin@juno.wombat.net]/root: grep "nat on" /tmp/rules.debug
                nat on $LAN inet from 192.168.0.0/18 to 192.168.0.0/18 -> 192.168.0.1/32 port 1024:65535
                nat on $WAN inet from $tonatsubnets to any port 500 -> WAN_ADDRESS/32  static-port
                nat on $WAN inet6 from $tonatsubnets to any port 500 -> (igb0)  static-port
                nat on $WAN inet from $tonatsubnets to any -> WAN_ADDRESS/32 port 1024:65535
                nat on $WAN inet6 from $tonatsubnets to any -> (igb0) port 1024:65535
                no nat on igb1 proto udp from (igb1) to 192.168.0.2 port 53
                nat on igb1 proto udp from 192.168.0.0/18 to 192.168.0.2 port 53 -> 192.168.0.1 port 1024:65535
                But as you can see, ... It was couple clicks to get that nonsense working.
                Indeed. For you.
                Again... I really do believe that it works for you.
                192.168.0.0/18
                  192.168.0.0/18
                  Use something sane! ;)
                  • rossc719R Offline
                    rossc719 @johnpoz
                    @johnpoz said in NAT Reflection (Pure NAT) not working for same subnet (v2.2.2):
                    I don't see that this is related to the issue at hand.
                      Maybe its a bug for when people use insane masks and try and do nat reflection ;)
                      2.4.5-RELEASE][admin@sg4860.local.lan]/root: grep "nat on" /tmp/rules.debug
                      no nat on igb0 proto tcp from (igb0) to 192.168.9.10 port 6666
                      nat on igb0 proto tcp from 192.168.9.0/24 to 192.168.9.10 port 6666 -> 192.168.9.253 port 1024:65535
                      [2.4.5-RELEASE][admin@sg4860.local.lan]/root:
                      These get created when I do nat reflection, just did another one for 6666 port
                      • rossc719R Offline
                        rossc719 @johnpoz
                        Perhaps, but seems unlikely. Especially given that the OP seems to have used 10.121.12.0/24.
                          The OP was using version 2.2 of pfsense.. So whatever has ZERO to do with today... Unless your using version 2.2 of pfsense?
                          Thought you said pfsense IP was 0.1 here there are nat rules to 0.2
                          • rossc719R Offline
                            rossc719 @johnpoz
                            Nope, I am using 2.4.5-RELEASE.
                            Again, I believe that it works for you.
                            But, it does not work for me.
                            This is unrelated to the issue at hand.
                            0.2 is my DNS server.
                            0.1 is pfsense.
                              Have no idea what else is unique to your setup... Someone using a /18 mask prob has all sorts of nonsense setup ;)
                              • rossc719R Offline
                                rossc719
                                If anyone is interested in debugging this at a later date, please let me know.
                                I am very interested in working with anyone who has any constructive ideas for how to move forward.
                                For now, the hack I described above, (The manually created outgoing NAT rule) seems to patch over the bug, so I will go ahead and use that.
                                Cheers
                                  There is no BUG.. The problem your seeing is something unique to your setup.. More than happy to help you work through it.. But as I have shown, I can not reproduce your issue. The problem is something unique to your setup.
                                  • rossc719R Offline
                                    rossc719 @johnpoz
                                    Excellent. How would you like to proceed?
                                    • rossc719R Offline
                                      rossc719
                                      FWIW, I'm still interested in trying to work through it with anyone who is up for it.
                                      I guess I'll stop updating this thread, but if someone is reading this in 2028, and is interested in helping, please assume I am still interested.
                                      A 1 Reply Last reply Reply Quote 2
                                        andy_redpoint @rossc719
                                        Old thread, but in context on an edge case bug I think an update is relevant - I have just been having this exact same issue, and @rossc719 's input on this thread plus the document he contributed (https://docs.google.com/document/d/1DCtqI2q3RlaK6HkTgp_xFw6poxWg6wiJlzw0V7lDtGU/edit?usp=sharing) was exactly what I needed to fix it.
                                        I have version 2.4.5-RELEASE-p1, the 'Enable automatic outbound NAT for Reflection' tick box is definitely set and, for whatever reason, does nothing. TCP dump showed all the traffic traversing the NAT correctly, but retaining its original source address. I added in a manual outbound NAT and the problem is fixed straight away.
                                          DTM_NV @andy_redpoint
                                          @andy_redpoint Exactly my experience. I was testing OPNsense 21 with this configuration and had no issues. Rebuilt with pfSense 2.5.2 last month and spent a good hour or two trying to work out why the same settings weren't working.
                                          I would add that the other "hacky" thing I'm doing is bridging the interfaces of a dual port NIC and assigning the bridge to the LAN interface. But I have turned off filtering for the bridge members.
                                          Thanks for all the posts on this thread and the consideration for future Googlers @rossc719 with your outbound NAT solution which has resolved my issue. Reflective NAT isn't ideal, but it least it works until I can do something like build a reverse proxy in front of my web servers.
                                            rtw915
                                            Hello @rossc719 we have not passed 2028 yet and I ran into the same issue. For me I did not have Enable automatic outbound NAT for Reflection selected, but I did have Pure NAT selected for NAT Reflection mode for port forwards. However, after enabling Enable automatic outbound NAT for Reflection nothing changed, it still was not working. It was not until I forced a filter reload after enabling that option that it started to work.
