    Multi WAN - LAN Problem SOLVED
    3 Posts 2 Posters 591 Views
      dragorekocar
      Hi there,
      I have 2 Wan int. and 2 Lan int., they work on multi-wan "mode" . The problem is about that:
      When I set on the Lan interface gateway the gateways-group called "Balance" (in my Pfsense) connection between LAN's disappear, no ping no HTTP no SSH nothing. When i set the gateway on default everything is ok, I have connection between this two LAN networks. My wish is to have connection between LAN's when the gateway is set to multi wan gateways group.
      If some one have any ideas i'll be glad to read it.
      • pttP Offline
        ptt Rebel Alliance
        https://doc.pfsense.org/index.php/Multi-WAN#Firewall_Rules
        https://doc.pfsense.org/index.php/Bypassing_Policy_Routing
          dragorekocar
          ptt THANKS A LOT for your quick response  :)
          The Bypassing Policy Routing is a problem here and especially the place of this rule!
          THANKS!
