    Problem on Traffic shaping !! please help
    6 Posts 4 Posters 1.6k Views
      hunderri
      Hello,
      So far i have a 2 wan interfaces and LAN. On Lan interface i created a rule that all my VOIP phone will use WAN1 and Computers WAN2. Wan1 is giving problems on quality, calls dropping, busy, etc. What i did is that i configured traffic shaping on both WAN-s. but i dont know what rule i need to configure, because i don's see traffic on Status: Traffic shaper: Queues - qVOIP.
      Any help will be very much appreciated !!
      Thanks,
        Harvy66
        You could start off by showing the rule that is supposed to work.
          Nullity
          Either via SSH or web-browser, run pftop and see which queues are getting their packet counts increased.
          Please correct any obvious misinformation in my posts.
          -Not a professional; an arrogant ignoramous.
          • KOMK Offline
            KOM
            If running via SSH, use:
            pftop -v queue
              hunderri
              for the VOIP do i need to create rules on NAT? any tutorial on VOIP configuration it will be very helpful !!
              thanks!!
              • KOMK Offline
                KOM
                Have you run the wizard and created a default VoIP queue by filling in the Voice over IP page of the wizard?  For traffic-shaping you use the Floating rules tab.  Add a rule that directs traffic from your VoIP phones into qVoIP with your preferred WAN as the gateway.
