    Problem setting up FAILOVER
    3 Posts 1 Posters 1.4k Views
    • Y Offline
      Yann Richard
      I've been trying to set up failover on pfsense in an ESX powered environnement.
      What i did so far :
      • Add 1 NIC on each server and make them communicate like this :
      14:55:50.546495 IP 192.168.10.1 > 192.168.10.2: PFSYNCv5 len 1336
          insert count 4
          update compressed count 4
          eof count 1
      14:55:50.579265 IP 192.168.10.1 > 192.168.10.2: PFSYNCv5 len 1410
          insert count 5
          update compressed count 2
          eof count 1
      • Configure Virtual IPs for both my LAN and WAN accesses and witness their propagation to the slave
      Now my problem are  :
      1. Master has LAN & WAN in master as it should be, but… Slave has LAN in master and WAN in backup (as it shouldnt be at all)
      2. Even if WAN is in backup mode on my Slave, the virtual IP is still mounted ! (wtf)
      • Y Offline
        Yann Richard
        Up, any ideas ?
        • Y Offline
          Yann Richard
          In fact the behaviour is totally erratic, sometimes I can get full MASTER on master node and BACKUP on slave nodes, but then some of my servers are unable to reach the network…
          Other time i delete a Virtual IP and recreate it and i can reach my server again but the interface is MASTER on both nodes...
          My last option is to change vSwitchs options as said in troubleshooting (https://doc.pfsense.org/index.php/CARP_Configuration_Troubleshooting) but I can't do it right away.
