    [Routing Problem] 1 WAN,1 TUN0, 1 LAN
    3 Posts 2 Posters 2.8k Views
      r0n
      I have some problems to route my LAN lan traffic to the network behind my OpenVPN tunnel (tun0 interface).
      details:
      WAN : Dynamic IP with a pppoe ADSL modem.
      LAN subnet : 10.0.10.0/23 - Interface IP : 10.0.11.254
      TUN0 subnet : 10.255.254.0/24 - interface IP : 10.255.254.6 – remote IP of the vpn server : 10.255.254.1  (And here there is NAT to 10.2.0.0/16 subnet).
      test:
      From the pfsense machine, ping 10.2.2.2 works fine.
      From a LAN host, with 10.0.11.254 as the GW, ping time out, the traffic seem to be routed to the WAN gateway
      Do you know how to fix it ??
      regards
        sullrich
        See the OpenVPN beta 1 thread.  Short answer is unless you are VERY familiar with OpenVPN then we do not recommend attempting to use it.
          r0n
          Thanks for your answer sullrich .. and thanks for compiling my kernel ;)
          I fixed this updating with the latest cvs release.
          Now it worfk fine :)
          Regards,
          ron.
