    Problem to disable autoselect on WAN interface
    13 Posts 6 Posters 7.3k Views
    • F Offline
      fredvr
      Our provider requires to force  100 full duplex on the WAN interface.
      I did set the next option
      => System - Interfaces - WAN - Speed and Duplex, advanced - 100baseTX full-Duplex
      we still have bad inet performance though. The provider says this is due to duplex option is not manual set.
      Status - interfaces shows
      Media 100baseTX <full-duplex>which looks nice at a first glance I think.
      However: goin into the the shell ifconfig output shows
      media: Ethernet autoselect (100baseTX <full-duplex>)
      Is there a way to get rid of autoselect because this is probably causing the issue?
      ifconfig -m shows
      supported media
        media autoselect
        media 1000baseT
        media 1000baseT mediaopt full-duplex
        media 100baseTX mediaopt full-duplex
        media 100baseTX
        media 10baseT/UTP mediaopt full-duplex
        media 10baseT/UTP</full-duplex></full-duplex>
        doktornotor Banned
        Maybe get a non-idiotic ISP instead.
        • F Offline
          fredvr
          Thats not one of the options..
            heper
            did you set the option and reboot?
            i've noticed that sometimes a reboot helps
              doktornotor Banned
              @fredvr:
              Good luck with debugging non-issues and paying for that in addition to broken service, if that's the case…
              • F Offline
                fredvr
                @doktornotor
                It is not uncommon ISP requires no autonegotiation on the WAN interface. We had different ISP's and they all had that requirement.
                @heper
                Yes, pretty sure because after applying the setting from default to 100TX full-duplex there was an auto reboot (ooops)  and this is listed using ifconfig.
                It's also still reporting autoselect though while it shouldn't.
                in config.xml there are no <media>entries in the <interfaces><wan>settings.
                in the <interfaces><lan>it shows <media>autoselect</media> which is correct.
                not sure if I can just add effectively an  <media><mediaopt>  entry in config.xml using the shell whitout causing problems and what the correct settings should be for using 100base full-duplex to force a none autoselect situation on the wan interface</mediaopt></media></lan></interfaces></wan></interfaces></media>
                  doktornotor Banned
                  @fredvr:
                  @doktornotor
                  Dude, maybe move to some sane area? Failing that, different country? Sorry, but an ISP suggesting that something is fixed by disabling autonegotiation just should go out of business.
                    heper
                    perhaps you should investigate that … its not normal
                    • jimpJ Offline
                      What type of NIC is used here?
                      Some NICs like Realtek's re(4) interfaces claim to support media speed/duplex selection but actually fail to apply it at the hardware level on certain cards, notably the ones found in APU devices.
                      In those cases your choices are to replace the NIC or put a managed switch between you and the upstream with the port facing pfSense set to auto, and the port facing the modem forced to 100/full
                      Do not Chat/PM for help!
                      • F Offline
                        fredvr
                        At last the problem seems to be 'solved'.
                        It wasn't pfsense ;)
                        The problem was in the ISP Cisco switch we are connecting to. As soon as Speed/Duplex is set to a fixed value (no autonegotiate) all port activity on the switch port stops..  No link, nothing.
                        We discovered that using a x-cable at that time solves all problems:
                        • autoselect => normal cable working, x-cable isn't
                        • autoselect disabled => x-cable working, normal cable isn't
                        :o :o
                        Not sure if this is a configurable behaviour of the Cisco switch or a mallfunction thing. For now everythings works great though!
                          doktornotor Banned
                          @fredvr:
                          That's extremely "surprising". The idiots who claim themselves to be an ISP and tell you that disabling autonegotiation fixes things actually break it. Apparently they don't even know what kind of equipment they supply? Disabling autonegotiation is known to break MDI-X. Among other things. Your ISP == full retard.
                            robi
                            Yep, that's also one of the things they teach at CCNA, disabling autonegotiation is never ever recommended.
                              donaldk
                              Interesting fault between an X-cable and a straight-thru.  I will make myself a cross over and see how autoselect behaves on my WAN connection.  In my case, setting my WAN to default (which does properly auto negotiate) vs autoselect (erratic operation) makes a difference on my WAN for some very odd reason.
