    Apu1d4 max lan network speed? [SOLVED]
    13 Posts 3 Posters 3.7k Views
      aGeekhere
      Hi all, I have a apu1d4 with pfsense installed onto a msata card with squid installed. Been testing the local lan transfer rate (downloading from squid cache ,have not tested using iperf yet) and was only getting about 20 megabytes per second before hitting 100% CPU load.
      Is that the max lan transfer rate for the apu1d or is this a squid limitation? Was kind of hoping to get higher transfer rates (90 to 115 megabytes per second).
      Never Fear, A Geek is Here!
        Guest
        Hello,
        you can do the two following things:  ;)
        • enable PowerD (high adaptive Mode)
        • reboot
        • enable TRIM support for the mSATA
        • reboot
        SPI/NAT & firewall rules & additional installed packages & some services on top will narrow down the entire
        performance step by step for sure.
          aGeekhere
          Done.
          reboot
          Done.
          Done.(there really should be a menu option for that, but anyway).
          Very basic rules, block port 80 and 443 (using squid proxy) and allow a few computers to have direct access, also have a few ports open.
          installed packages
          bandwidthd
          Dansguardian (Disabled)
          iperf
          Lightsquid
          Sarg
          squid3
          squidGuard
          System load before downloading file from cache
          last pid: 26782;  load averages:  0.29,  0.30,  0.38  up 0+00:18:13    19:11:31
          164 processes: 3 running, 140 sleeping, 4 zombie, 17 waiting
          Mem: 232M Active, 595M Inact, 574M Wired, 413M Buf, 2513M Free
          Swap: 8192M Total, 8192M Free
            PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME    WCPU COMMAND
             11 root     155 ki31     0K    32K CPU0    0  14:38 100.00% [idle{idle: cpu0}]
             11 root     155 ki31     0K    32K RUN     1  14:09  99.27% [idle{idle: cpu1}]
          98435 root      52    0   223M 32344K piperd  1   0:01   4.59% php-fpm: pool lighty (php-fpm)
          83019 proxy     20    0   228M   110M kqread  1   0:57   0.00% (squid-1) -f /usr/pbi/squid-amd64/local/et
              0 root     -16    0     0K   160K swapin  0   0:40   0.00% [kernel{swapper}]
             12 root     -92    -     0K   272K WAIT    0   0:30   0.00% [intr{irq261: re2}]
             12 root     -92    -     0K   272K WAIT    0   0:09   0.00% [intr{irq260: re1}]
          While downloading from cache
          last pid: 33398;  load averages:  1.21,  0.52,  0.45  up 0+00:20:36    19:13:54
          165 processes: 5 running, 140 sleeping, 4 zombie, 16 waiting
          Mem: 232M Active, 359M Inact, 809M Wired, 645M Buf, 2512M Free
          83019 proxy    100    0   228M   110M CPU0    0   1:29  96.39% (squid-1) -f /usr/pbi/squid-amd64/local/et
             12 root     -92    -     0K   272K WAIT    1   0:51  63.09% [intr{irq261: re2}]
             11 root     155 ki31     0K    32K RUN     1  15:59  22.17% [idle{idle: cpu1}]
             11 root     155 ki31     0K    32K RUN     0  16:23   4.39% [idle{idle: cpu0}]
          32325 root      33    0   223M 32312K piperd  1   0:00   1.56% php-fpm: pool lighty (php-fpm)
          79307 root      20    0 55724K  7312K bpf     0   0:01   1.17% /usr/pbi/bandwidthd-amd64/local/bandwidthd
          Same speed about 20 megabytes per second
          Just running out of CPU? would have thought that I would be able to get gigabit speeds with a apu1d.
            Guest
            Oh sorry it was my false! If you have enabled PowerD & TRIM support you should also
            create a file that is named loader.conf.local to make all of your special or custom settings
            persistent against reboots, updates & upgrades! once more again sorry please!  :o
            /boot/loader.conf.local
            No, the APU is powerful enough to run several things such as Squid and Snort, but please
            don´t forget that each packet is harming the CPU and taking some power.
            Without the PowerD (high adaptive) enabled you will be able to archive something around ~450 MBit/s
            and with enabled PowerD you could get something around ~650 MBit/s - ~750 MBit/s.  ;)
              aGeekhere
              I already have the file in /boot/loader.conf.local
              When I open up the file it shows
              kern.cam.boot_delay=10000
              Is there anything else I need to add to it?
              Well i just did a iperf (so not going through squid) and I get.
              Client connecting to 192.168.1.244, TCP port 5001
              TCP window size: 65.0 KByte (default)
              [  9] local 192.168.1.1 port 21527 connected with 192.168.1.20 port 5001
              [ ID] Interval       Transfer     Bandwidth
              [  9]  0.0-10.0 sec   223 MBytes   187 Mbits/sec
              Only getting 187 Mbits/sec
              My msata card (Samsung 850 EVO MZ) can do
              540 MB/sec Sequential Read
              520 MB/sec Sequential Write
              And the pc I am testing it with also has a ssd, all gigabit lan.
                aGeekhere
                IN System: Advanced: Networking
                I tired disabling/enabling Disable hardware checksum offload and Disable hardware TCP segmentation offload and Disable hardware large receive offload.
                Which does not seem to affect anything.
                  aGeekhere
                  Any other ideas I can try?
                    aGeekhere
                    Ok a few more tests
                    Running
                    systat -iostat 1
                    First test
                    diskinfo -c /dev/ada0
                    See attachment 1
                    result
                    See attachment 2
                    Second test downloading a 1GB file from squid cache
                    result
                    See attachment 3
                    ![01 hdSpeedTest.jpg](/public/imported_attachments/1/01 hdSpeedTest.jpg)
                    ![01 hdSpeedTest.jpg_thumb](/public/imported_attachments/1/01 hdSpeedTest.jpg_thumb)
                    ![02 hdSpeedTestResults.jpg](/public/imported_attachments/1/02 hdSpeedTestResults.jpg)
                    ![02 hdSpeedTestResults.jpg_thumb](/public/imported_attachments/1/02 hdSpeedTestResults.jpg_thumb)
                    ![03 networkSpeedResults.jpg](/public/imported_attachments/1/03 networkSpeedResults.jpg)
                    ![03 networkSpeedResults.jpg_thumb](/public/imported_attachments/1/03 networkSpeedResults.jpg_thumb)
                      aGeekhere
                      unticking
                      Now gives me about 27.5 Megabytes per second (220mbps).
                      That helped a little.
                        aGeekhere
                        Ok ran some more test, have two computers downloading the test file. When both are running the transfer speed halves, when 1 computer stops the transfer speed doubles, looking like a slowdown somewhere.
                          aGeekhere
                          Ok I think I solved the issue, updated squid to 0.3.8 and removed dansguardian (dansguardian was disabled and I was not using it).
                          Now I get 500 to 600 mbps from iperf, going to test squid cache speed soon.
                            Is that just from iperf running on the APU to an iperf client on another machine? I.e. not through the APU but to/from it, only using one NIC?
                            If that's really through the unit, routed and firewalled traffic, that the fastest result I've ever seen.
                              aGeekhere
                              The setup
                              APUd4 running
                              iperf 2.0.5.2
                              squid3 0.3.8
                              squidGuard 1.9.15
                              iperf test
                              pfsense as client
                              pc as server
                              pfsense connected to gigabit router
                              pc connected to gigabit router
                              Only using lan nic
                              results
                              [  9]  0.0-10.0 sec   593 MBytes   497 Mbits/sec
                              So when I said between 500 to 600 mbits it is really between 450 to 550 mbps.
                              However, this is only using 1 core (50% CPU), need iperf v3 for multi threading testing.
                              Squid cache test
                              A 1GB test file
                              Speed is about 250 mbps
                              using full CPU power
                              So that is about what I get.
