    Need help, seems that whatever I do doesn't work.
    10 Posts 4 Posters 2.0k Views
    • I Offline
      ImageJPEG
      I have a full Bitcoin node setup at my house and sometimes it hogs the bandwidth to the point where I can't browse the Internet or anything Internet releated.
      I've tried setting up Traffic Shaper and a Limiter but both seem to do nothing.
      I currently have a 10Mbits/1Mbits ADSL connection.
      For the shaper, I'm using the PRIQ for limiting the bandwidth. I have the Bitcoin node set for the lowest queue (I added a firewall rule under "Floaters" for the Bitcoin port 8333)
      On top of that, I also created a limiter. I've limited it to 500Kbits and set it in the same firewall rule.
      Here's some screenshots.
      Screenshot.png_thumb
      Screenshot-1.png_thumb
      Screenshot-2.png_thumb
      Screenshot-3.png_thumb
      Screenshot-4.png_thumb
      Screenshot-5.png_thumb
      Screenshot-6.png_thumb
      • I Offline
        ImageJPEG
        Another thing, it seems that my download speed is horribly affected when Bitcoin decides it needs to upload lots of stuff.
          Nullity
          @ImageJPEG:
          This is common, which is why "ACK prioritization" is one of the more common traffic-shaping scenarios. http://www.benzedrine.ch/ackpri.html
          You could accomplish your goal with HFSC's "upper-limit" parameter. (Limiters confuse me, so I cannot help you there.) Traffic-shaping is not easy. Just keep reading and testing until it makes sense.
          Please correct any obvious misinformation in my posts.
          -Not a professional; an arrogant ignoramous.
            Harvy66
            Did you rate limit your WAN interface? You show you setup a limiter, but you didn't show if you configured your interface.
            • I Offline
              ImageJPEG
              I deleted the configuration. Wasn't able to get it working. I played around with it. Everything else would work, for example, I could get it to limit http traffic.
              I just want the bitcoin node to have full bandwidth until someone wants to load a web page or download a file etc.
                mcwtim
                @ImageJPEG:
                I think this is more what you want https://forum.pfsense.org/index.php?topic=63531.0
                You may need to use 2.1.5 to get it working though.
                  Harvy66
                  HFSC traffic shaping works just fine for me on 2.2.4
                    mcwtim
                    @Harvy66:
                    More the limiters with NAT rules issue for my 2.1.5 warning.
                      Harvy66
                      So limiters are not working? I never use those.
                        mcwtim
                        @Harvy66:
                        When there is a limiter on a rule where NAT forward or reflection applies.
                        https://redmine.pfsense.org/issues/4326
                        https://redmine.pfsense.org/issues/4590
