    Please Help with DHCP6C on native /56
    35 Posts 10 Posters 11.6k Views
      det
      @753951:
      That patch did it. pfSense now picks up IPv6 after reboot and my LAN gets assigned public IPv6 addresses. Thanks.
      Excellent, that's good to hear.
      It's by no means perfect.  rtsold will superfluously restart dhcp6c after you've already got a PD, but that shouldn't be too noticeable.  At least it triggers authentication with the ISP and lets you on the network.
      One thing, can you check your logs for any XID session mismatch/errors?  I don't think we'd be introducing any duplicate instances of dhcp6c by doing this, but just want to make sure.
        hda
        @753951:
        This is my WAN config:
        Try this:  Use Interfaces-WAN with DHCP6 and DHCP6c conf:
        Check, Only request an IPv6 prefix, do not request an IPv6 address
        DHCPv6 Prefix Delegation size == 56
        Check, Send an IPv6 prefix hint to indicate the desired prefix size for delegation
        & check: Advanced config, it is no more than:
        (send options(ia-pd 0) and Prefix delegation = checked only).
        Then create Static LAN's config's i.s.o. Track Interface…
          hda
          @753951:
          Yes, hn0 is my WAN.
          …re-enabled DHCPv6 for WAN...
          Only part for hn0 (LAN) is there...
          Makes no sense. DHCPv6/RA is about your LAN's.
          • 7 Offline
            753951
            @hda:
            @753951:
            Yes, hn0 is my WAN.
            Sorry. It was supposed to be "Only part for hn1 (LAN) is there…"
            • 7 Offline
              753951
              @det:
              Yes, there are four of them in the log after reboot. Here is pertinent part of the log (public IP addresses are mangled), if that helps
              dhcp6c[14001]: script "/var/etc/dhcp6c_wan_script.sh" terminated
              dhcp6c[14001]: removing an event on hn0, state=REQUEST
              dhcp6c[14001]: removing server (ID: 00:03:00:02:c0:d4:12:14:18:11)
              dhcp6c[14001]: got an expected reply, sleeping.
              dhcp6c[14001]: release an IA: PD-0
              dhcp6c[14001]: reset a timer on hn0, state=RELEASE, timeo=0, retrans=991
              dhcp6c[14001]: a new XID (acf098) is generated
              dhcp6c[14001]: set client ID (len 14)
              dhcp6c[14001]: set server ID (len 10)
              dhcp6c[14001]: set elapsed time (len 2)
              dhcp6c[14001]: set IA_PD prefix
              dhcp6c[14001]: send release to ff02::1:2%hn0
              dhcp6c[14001]: remove an IA: PD-0
              dhcp6c[14001]: remove a site prefix 2001:fff:ffff:ca00::/56
              dhcp6c[14001]: remove an address 2001:fff:ffff:ca99:215:5dff:fe63:cc03/64 on hn1
              dhcp6c[14001]: reset a timer on hn0, state=INIT, timeo=0, retrans=793
              dhcp6c[14001]: removing an event on hn0, state=INIT
              dhcp6c[14001]: receive advertise from fe80::ea4:2ff:fe94:7801%hn0 on hn0
              dhcp6c[14001]: get DHCP option server ID, len 10
              dhcp6c[14001]: DUID: 00:03:00:02:c0:d4:12:14:18:11
              dhcp6c[14001]: get DHCP option client ID, len 14
              dhcp6c[14001]: DUID: 00:01:00:01:1e:3d:d6:32:01:18:5a:73:dc:02
              dhcp6c[14001]: get DHCP option IA_PD, len 41
              dhcp6c[14001]: IA_PD: ID=0, T1=86400, T2=144000
              dhcp6c[14001]: get DHCP option IA_PD prefix, len 25
              dhcp6c[14001]: IA_PD prefix: 2001:fff:ffff:ca00::/56 pltime=172800 vltime=345600
              dhcp6c[14001]: get DHCP option DNS, len 32
              dhcp6c[14001]: XID mismatch
              dhcp6c[14001]: receive reply from fe80::ea4:2ff:fe94:7801%hn0 on hn0
              dhcp6c[14001]: get DHCP option IA_PD, len 49
              dhcp6c[14001]: IA_PD: ID=0, T1=0, T2=0
              dhcp6c[14001]: get DHCP option status code, len 33
              dhcp6c[14001]: status code: success
              dhcp6c[14001]: executes /var/etc/dhcp6c_wan_script.sh
              php-fpm[277]: /rc.newwanipv6: rc.newwanipv6: Info: starting on hn0.
              php-fpm[277]: /rc.newwanipv6: rc.newwanipv6: on (IP address: fe80::215:5dff:fe63:cc02) (interface: wan) (real interface: hn0).
              unbound: [69580:0] info: service stopped (unbound 1.5.4).
              unbound: [69580:0] info: server stats for thread 0: 7 queries, 2 answers from cache, 5 recursions, 0 prefetch
              unbound: [69580:0] info: server stats for thread 0: requestlist max 17 avg 8 exceeded 0 jostled 0
              unbound: [69580:0] info: average recursion processing time 0.771420 sec
              unbound: [69580:0] info: histogram of recursion processing times
              unbound: [69580:0] info: [25%]=0 median[50%]=0 [75%]=0
              unbound: [69580:0] info: lower(secs) upper(secs) recursions
              unbound: [69580:0] info: 0.524288 1.000000 2
              unbound: [4200:0] notice: init module 0: validator
              unbound: [4200:0] notice: init module 1: iterator
              dhcpleases: Sending HUP signal to dns daemon(4200)
              unbound: [4200:0] info: start of service (unbound 1.5.4).
              unbound: [4200:0] info: service stopped (unbound 1.5.4).
              unbound: [4200:0] info: server stats for thread 0: 0 queries, 0 answers from cache, 0 recursions, 0 prefetch
              unbound: [4200:0] info: server stats for thread 0: requestlist max 0 avg 0 exceeded 0 jostled 0
              unbound: [4200:0] notice: Restart of unbound 1.5.4.
              radvd[35097]: attempting to reread config file
              radvd[35097]: no auto-selected prefix on interface hn1, disabling advertisements
              radvd[35097]: sendmsg: Can't assign requested address
              radvd[35097]: resuming normal operation
              php-fpm[277]: /rc.newwanipv6: ROUTING: setting default route to d99-99-9-9.xxxx.xxxxx.xxx
              php-fpm[277]: /rc.newwanipv6: ROUTING: setting IPv6 default route to fe80::ea4:2ff:fe94:7801%hn0
              apinger: SIGHUP received, reloading configuration.
              dhcp6c[14001]: removing an event on hn0, state=RELEASE
              dhcp6c[14001]: exiting
                Guest
                If you want to switch to 2.3RC there are a couple of patches available that will fix  the issue with the XID's too. I'm keeping the patches reasonably up to date. If you do update and find the patches don't apply then pm me and I'll update them for you, otherwise a full fix for this is slated for 2.3.1
                The patches can be found here, always take the last ones in the attached files, there are two you'll need, interfaces.inc and interfaces.php.
                https://redmine.pfsense.org/issues/5993
                  alphaz
                  cool, i'm glad people are having the same issue as me… I kinda forgot about the issue or that I even created this topic a while back.. until I rebooted my router to upgrade it to 2.3, :\ couldn't remember what was wrong, until I found my own thread haha!
                  But apparently its still a problem in 2.3 , is there a patch now? or whats the status?
                    Guest
                    A proper fix is slated for 2.3.2
                    In the meantime, if you tell me what version you are running I'll create a patch for you and post it.
                      bimmerdriver
                      I started a thread (https://forum.pfsense.org/index.php?topic=113461.0) about this yesterday, so as to not hijack this thread, but since I'm not the only one having problems with native /56, and I got no responses there, I'll ask here.
                      My ISP requires the router to request a /56 using IA-PD, not IA-NA. If the router asks using both, it's supposed to accept the rejection of the IA-NA. Their router allocates itself a wan address in the ff subnet and uses the 00 subnet for the lan. I installed pfsense using "quick/easy install" but it did not work (i.e., no prefix was delegated and dhcp6 did not start. I'm not clear how to allocate a wan address in ff, nor how to allocate the lan subnet. Supposedly their edge router will send out an RA after the dhcp process completes. Their edge router apparently rejects RS messages for security reasons. I'm wondering if these idiosyncrasies are what's tripping up pfsense.
                        bimmerdriver
                        I had a discussion with an engineer from my ISP, which is Telus. He referred me to TR-124 - Issue 4, which uses the flow-chart below for configuring ipv6. They use that mechanism, except they have configured their edge routers to not respond to RA until DHCP is done. Based on what he said, I'm quite certain that the problems I'm having are the same as what det described above, which is that pfsense starts RS/RA before DHCP, so it hangs. While I'm not familiar enough with this issue to comment on other cases, for this specific case, it's pretty clear that pfsense needs an option to allow the RS/RA and DHCP processes to be forked so they operate concurrently and can complete in an arbitrary order.
                        There is another requirement in TR-124 - Issue 4 that bears consideration.
                        WAN.IPv6. 12 If the RG does not have a globally-scoped address on its WAN interface after having been delegated a prefix, it MUST create addresses for itself from the delegated prefix. It MUST have at least one address and MAY have more
                        There is currently no algorithm defined for address creation. It should be assumed that different service providers will want different rules for how to create the address, how many addresses to create, and in the case of multiple addresses, how the different addresses are used.
                        In the case of Telus, their gateway allocates its global WAN address in prefix+ff/64, using RFC 2464. It allocates prefix+00/64 for LAN addresses.
                        Here are the settings from my gateway:
                        IPv6 Prefix of Delegated: 2001:569:XXXX:8500::/56
                        IPv6 WAN Status: Connected
                        IPv6 WAN Address: 2001:569:XXXX:85ff:4e8b:30ff:fe19:f939/64
                        IPv6 WAN Link Local Address: fe80::4e8b:30ff:fe19:f939
                        IPv6 LAN Link Local Address: fe80::4e8b:30ff:fe19:f938
                        For users who have ISPs using TR-124, it would be very useful if there was an option which could be in the DHCP6 advanced configuration settings for pfsense to auto-create a global WAN address in a user-specified prefix using RFS 2464.
                        I'd appreciate comments on this. Should I post it in the thread for bug 5993?
                          alphaz
                          Lol bimmer,
                          its not probably the same issue, its the EXACT same issue with the Exact same provider :)
                          just run in manually or run the manual patch as some suggested above or wait for 2.3.2 for proper fix :)
                            rancid-lemon
                            I tried to install patch 3102 for this issue, but I run into a 'this patch can't be applied cleanly' error.
                            Can anyone advise how to install on 2.3.2?
                            Error text:
                            /usr/bin/patch --directory=/ -t -p2 -i /var/patches/57b8e16425366.patch --check --forward --ignore-whitespace
                            Hmm...  Looks like a unified diff to me...
                            The text leading up to this was:
                            |From efc042acd68e86e3b6c6eb0b3fbdc82ef7d17dc6 Mon Sep 17 00:00:00 2001
                            |Date: Sun, 7 Aug 2016 21:06:25 +0100
                            |Subject: [PATCH] DHCP6 Before RA. Additions and ammendments
                            |Replaced posix_kill() in kill_dhcp6client_process() with mwexec("kill -9 $pid"), this is because the posix_kill call was not reliably killing the dhcp6c process, kill -9 works every time.
                            |Changes to the rtsold script creation. The script lines starting dhcp6c should not have be written to the script when dhcpwithoutra is true.
                            |Style corrections, I spend more time doing these than changing code!
                            | src/etc/inc/interfaces.inc | 41 +++++++++++++++--------------------------
                            | 1 file changed, 15 insertions(+), 26 deletions(-)
                            |diff --git a/src/etc/inc/interfaces.inc b/src/etc/inc/interfaces.inc
                            |index 865009a..03929f2 100644
                            |--- a/src/etc/inc/interfaces.inc
                            |+++ b/src/etc/inc/interfaces.inc
                            Patching file etc/inc/interfaces.inc using Plan A...
                            Hunk #1 succeeded at 1332 (offset 32 lines).
                            Hunk #2 failed at 3058.
                            Hunk #3 failed at 3997.
                            Hunk #4 failed at 4008.
                            Hunk #5 failed at 4032.
                            4 out of 5 hunks failed while patching etc/inc/interfaces.inc
                            done
                              bimmerdriver
                              @rancid-lemon:
                              PR 3102 hasn't been backported to 2.3.2 (yet, I hope). If you want to run the patches, you need to run the development snapshot. I'm running PRs 3102/1, 3102/2, 3103, 3105, 3106 and 3107 and they are working quite well. The only patches that are specifically for the RA issue are 3102/1 and 3102/2. The rest are for dhcp6. Refer to https://redmine.pfsense.org/issues/5993 and https://github.com/pfsense/pfsense/pulls. The shapshot already has an earlier version of the fix, so it should get a prefix even without the PRs.
                                rancid-lemon
                                @bimmerdriver:
                                @rancid-lemon:
                                Understood, thank you for the explanation. I will give the snapshot a go and see how I get on before installing the patches, will keep an eye on this thread too.
                                  bimmerdriver
                                  @rancid-lemon:
                                  @bimmerdriver:
                                  @rancid-lemon:
                                  In case you didn't notice, if you upgrade to the latest 2.3.3 development snapshot, all of the pertinent patches have already been merged.
