    [solved] Watchguard x750e NICs LED fix for 2.2.5 not working?
    7 Posts 4 Posters 1.5k Views
    • V Offline
      vizi0n
      Hi all,
      I've just got an x750e and set it up following a few how-to's online for the tweaking.
      One thing that I still haven't managed to get to work "correctly" are the LED lights for the NICs.
      I have followed the explanations, but it seems like the modules never load
      /etc/rc.conf_mount_rw
      fetch -o /boot/modules/if_sk.ko https://sites.google.com/site/pfsensefirebox/home/if_sk.freebsd-8.3.ko
      fetch -o /boot/modules/if_msk.ko https://sites.google.com/site/pfsensefirebox/home/if_msk.freebsd-8.3.ko
      Update the /boot/loader.conf.local to add:
      if_sk_load="yes"
      if_msk_load="yes"
      /etc/rc.conf_mount_ro
      reboot
      Now even if I try to dmesg | grep LED, nothing shows.
      [2.2.5-RELEASE][root@pfSense.localdomain]/conf: ls -la /boot/modules
      total 237
      drwxr-xr-x  2 root  wheel    512 Dec 14 21:42 .
      drwxr-xr-x  7 root  wheel    1024 Dec 14 21:34 ..
      -r-xr-xr-x  1 root  wheel  103608 Nov  4 17:21 bwi_v3_ucode.ko
      -rw-r–r--  1 root  wheel  75618 Sep 25  2013 if_msk.ko
      -rw-r--r--  1 root  wheel  47627 Sep 25  2013 if_sk.ko
      Files are there
      Here is my loader.conf.local
      [2.2.5-RELEASE][root@pfSense.localdomain]/conf: cat /boot/loader.conf.local
      hint.ata.0.mode=PIO4
      if_sk_load=yes
      if_msk_load=yes
      hw.msk.msi_disable=1
      Any help would be appreciated!
      From a pfSense newbie
      • chpalmerC Offline
        chpalmer
        Try the files here.  The ones you used are for an earlier freebsd version.
        https://forum.pfsense.org/index.php?topic=20095.msg460754#msg460754
        • V Offline
          vizi0n
          that worked wonders!
          thanks to you! :)
            kobzar
            the link isn't opened.
            where i can find modules for 2.3 pfsense?
            WatchGuard x750e + 2GB + SATA-IDE 320GB
            • V Offline
              vizi0n
              I have attached both the if_sk.ko and if_msk.ko that are on my Firebox right now which is running 2.3.3.
              Just copy them to /boot/modules
              watchguard_firebox_nic_led_fix_modules.zip
                kobzar
                Thanks mate!
                You are the best!
                All working fine.
                • stephenw10S Online
                  Do you know what those were compiled against? I guess they were those posted in the old thread unless you re-compiled them yourself?
