    Strange problem with VoIP adapter
    15 Posts 4 Posters 19.1k Views
    • E Offline
      Erik
      Hi
      Sorry, I'm quite a firewall newbie… My Grandstream 286 VoIP adapter is having problems connecting to my VoIP provider. I have just switched from m0n0wall to pfsense, and I had no problems with the device in m0n0wall. Here is some diagnosis, I can provide more (e.g. a working config file from m0n0wall):
      Setup:
      internet <--> firewall <--> switch <--> adapter
      According to my provider (Telefin.dk) I have to open UDP port 5060 og 5061, plus port 5004 on the firewall. My WAN ruleset is now:
      Proto        Source  Port Destination    Port            Gateway
      TCP          *            *    192.168.0.2    80 (HTTP)  *
      TCP          *            *    192.168.0.2    22 (SSH)    *
      TCP          *            *    192.168.0.2    25 (SMTP) *
      UDP        *            *    192.168.0.9    5060          *
      UDP        *            *    192.168.0.9    5061          *
      TCP/UDP *            *    192.168.0.9    5004          *
      and LAN:
      *            LAN net  *      *                    *                *
      where 192.168.0.2 is my www/ssh/mail server and 192.168.0.9 is the adapter. Both have a static IP adress, given to them by DHCP.
      My NAT config is:
      If      Proto          Ext. port range NAT IP            Int. port range
      WAN    TCP        80 (HTTP)        192.168.0.2    80 (HTTP)
      WAN    TCP        22 (SSH)          192.168.0.2    22 (SSH)
      WAN    TCP        25 (SMTP)      192.168.0.2    25 (SMTP)
      From the status page of the adapter I get:
      MAC Address:      00.0B.82.02.F3.D7
      WAN IP Address: 192.168.0.9
      PPPoE Link Up:  disabled
      NAT:                    detected NAT type is symmetric NAT
      NAT Mapped IP:  85.233.238.xxx    # (xxx added for extra Security(TM))
      NAT Mapped Port:55813
      This worries me; shouldn't WAN and NAT be switched around?
      IN the firewall log I see (apart from 2 million Windows-vira) the following packets blocked:
      WAN      212.130.74.61.3479      85.233.238.191.55813      UDP
      212.130.74.61 is a Telefin server. Notice that the port 55813 is the "NAT Mapped Port" announced by the adapter.
      I have tried opening port 55813 without any luck. I have tried mapping port 5060-5061 and 5004 on WAN to the same ports on the adapter in the NAT setup without any luck. I have not fiddled with any "advanced" settings... Any suggestions?
      Kind regards,
      Erik Andersen
        hoba
        I guess the voipadapter calls his interface "wan" (it looks like as it even supports pppoe, so this might be the case). So the WAN/NAT IP might be something you shouldn't worry about. Have you tried forwarding the port the adapter wants to use (55813)? Not only opening up the port but forwarding it? As you see blocks on WAN for this port you should revisit this setting and check it again. Also note that the protocol that is blocked is UDP not TCP.
        • E Offline
          Erik
          Hmm, I don't think I should be opening the port 55813 on the firewall. I tried rebooting the adapter, and the I get NATMapped Port: 53050. One more time, and I get 51048. If I understand correctly, outgoing connections are assigned a random port number, e.g. my connection to this site in the state table:
          Type  Proto  Source->Router->Destination            State
          self    tcp    216.135.66.8:80<-192.168.0.7:1407  ESTABLISHED:ESTABLISHED
          The port 1407 changes for every new connection I make to this site. Likewise, it seems the NAT mapped port is randomly assigned. My guess is that pfsense is assigning the port and somehow my adapter is picking it up. These are the relevant entries in my state table:
          self  udp  192.168.0.1:53<-192.168.0.9:26789                                          MULTIPLE:MULTIPLE
          self  udp  212.130.74.56:5060<-192.168.0.9:5060                                    NO_TRAFFIC:SINGLE
          self  udp  212.130.74.60:3478<-192.168.0.9:5060                                    MULTIPLE:MULTIPLE
          self  udp  212.130.74.61:3479<-192.168.0.9:5060                                    MULTIPLE:MULTIPLE
          self  udp  192.168.0.9:5060->85.233.238.xxx:52852->212.130.74.56:5060  SINGLE:NO_TRAFFIC
          self  udp  192.168.0.9:5060->85.233.238.xxx:51028->212.130.74.60:3478  MULTIPLE:MULTIPLE
          self  udp  192.168.0.9:5060->85.233.238.xxx:53530->212.130.74.61:3479  MULTIPLE:MULTIPLE
          I'm really on shaky ground here, but the first one is easy; it's a DNS lookup. Then we have three connections to to Telefin servers, plus three connections more, using seemingly random ports on the firewall WAN port. If I open e.g. port 51028, I will get an incoming connection from Telefin (but still no association), but otherwise I have no incoming connections.
          Erik
          • E Offline
            Erik
            Sorry to reply to myself, but Wikipedia can be your friend sometimes…
            My adapter apparently calls a STUN server to establish a connection between clients behind NAT. Quoting Wikipedia, "It will not work with symmetric NAT" and quoting the adapter status page, "detected NAT type is symmetric NAT".
            I have now tried disabling STUN on the adapter and using NAT to forward the WAN ports 5060, 5061 and 5004 to my adapter:
            WAN  UDP        5060 - 5061      192.168.0.9  5060 - 5061
            WAN  TCP/UDP  5004                192.168.0.9  5004
            My state table now reads:
            self  udp  192.168.0.9:5060->85.233.238.191:52855->212.130.74.56:5060  SINGLE:NO_TRAFFIC
            self  udp  85.233.238.191:5060<-212.130.74.56:5060                                NO_TRAFFIC:SINGLE
            Still no luck, though. Why is the last state not going through to 192.168.0.9 when I have the above NAT rules?
            Erik
              hoba
              Maybe the sip-proxy (siproxd) package is worth a try.  Give it a shot.
              • E Offline
                Erik
                Damn, there is no package support for embedded platforms. I'm on a WRAP board :-/
                I tried loading my working m0n0wall config file into pfsense, and the VoIP adapter still reports "symmetric NAT" as the NAT type, whereas it was "(port?) restricted cone" in m0n0wall. Is there any way to change the NAT type in pfsense?
                Erik
                  keefe007
                  Did you get this working ever?
                  • E Offline
                    Erik
                    No, unfortunately I had to switch back to m0n0wall since I lacked the time to investigate further. But I've aquired another CF card so testing is easier now, if anyone has suggestions.
                    Update: apparently Phil Regnauld from BSD-DK has it working with a Grandstream adapter by adding
                    set timeout { udp.first 60, udp.single 60, udp.multiple 60 }
                    nat on $ext_if from $int_net to any -> $ext_ip static-port
                    to /etc/pf.conf - the important part being the keyword "static-port". I'll try it when I have some spare time in the weekend.
                      sullrich
                      Beta 2 will include a static-port option in advanced outbound-nat.
                      • E Offline
                        Erik
                        Cool! Thanks for the notice, I'll let you know how it works out when beta2 is out.
                          keefe007
                          I was able to get my asterisk SIP server working behind the pfsense firewall by using 1:1 NAT for that box.
                          It looks like regular NAT is symmetric while 1:1 uses cone NAT, which is what SIP needs.
                            sullrich
                            Newer testing versions are available at: http://www.pfsense.com/~sullrich/?M=D
                            Look for "TESTING" dirs.
                              keefe007
                              @sullrich:
                              What does this version have do make SIP work better?
                              Will it support multiple SIP devices connecting through the router?  Such as multiple ATAs with multiple VoIP lines.
                                hoba
                                It includes the static port option.
                                • E Offline
                                  Erik
                                  So, I finally managed to get time to look at the problem. I installed BETA2 (leaps and bounds better than BETA1 in almost every area, thanks everybody!), and I'm glad to say that the static-port did the trick. Quick summary:
                                  Enabled advanced outbound NAT, changed the default outbound rule to enable static-port. Reboot adapter. That's it!
                                  I'm not sure if I still need the following rules on the NAT: port forward page:
                                  Will have to test that.
                                  Thanks to everybody who replied, end everyone who has worked so hard to make pfsense better!
                                  Erik
