    Phase 2 BINAT same subnet on remote and local point to point
    4 Posts 2 Posters 1.7k Views
      kapara
      Is the BINAT feature for phase to for a situation where the remote network and the local network for phase 2 in a vpn is the same?  Does it allow translating to a intermediary subnet so that VPN can still be established?
      Skype ID:  Marinhd
      • jimpJ Offline
        Yes but if both sides have the same LAN then both sides must NAT.
        Imagine a scenario where Site A and Site B have 192.168.1.1 for the LAN.
        Site A will use a fake/NAT subnet of 10.0.1.0/24, Site B will use 10.0.2.0/24
        Site A's P2 will have:
        Local: 192.168.1.0/24
        NAT/BINAT: 10.0.1.0/24
        Remote: 10.0.2.0/24
        Site B's P2 will have:
        NAT/BINAT: 10.0.2.0/24
        Remote: 10.0.1.0/24
        And then to reach each other, they each use the appropriate 10.0.x.x addresses.
        Do not Chat/PM for help!
          kapara
          Thanks jimp.
          Skype ID:  Marinhd
            kapara
            So what about this situation:
            Site A:
            Using a (Interface with) subnet with 192.168.1.0/24 different network. (Not part of VPN tunnel)
            IPSEC P2 Local Subnet is 172.20.20.0/24
            Site B:
            LAN is 192.168.1.0/24
            P2 local is using this 192.168.1.0/24 subnet.
            What would be the proper way to use BINAT or is it not needed?  Will the IPSEC tunnel know to direct traffic for the 172.20.20.0/24 going to 192.168.1.0/24 through the tunnel even though there is annother interface using 192.168.1.0/24?
            Skype ID:  Marinhd
