    Recommendations for a connection monitor
    10 Posts 3 Posters 2.5k Views
    • KOMK Offline
      KOM
      I'm looking for a small, simple utility which will:
      • monitor one or more hosts via ping
      • perform a scan every x seconds
      • play an alarm sound if scan fails n times
      • F/OSS
      That's it.  Just a simple monitor with alarm.  I don't need historical data or graph plotting or 50 MB installers.  Just a small little utility that does this one job well.  Google overwhelms me with a zillion commercial apps or monster suites like PRTG or Nessus etc.
      Thanks in advance.
        MontTech
        We use Zabbix…..Way overkill for what you're looking for, but it is free if you dont take their support options.  Bonus that it has a pfSense package for both agent and proxy too.
          cmb
          Smokeping probably the best option without getting into one of the huge fully-featured monitoring systems. You'd have to write a script to do the alarm sound part but that's easy enough (it can execute commands on alarm).
          • KOMK Offline
            KOM
            Thanks for the replies.
            I already use Smokeping to track my historical connection data.  I'm looking more for a Windows desktop utility so that I'm not the last to know when our link dies.  I used to have a decent one 10 years ago but I forget what it's called now.
              MontTech
              Was it, The Dude?  Its Windoze based and does alerting…One of my guys uses it a lot.
              http://www.mikrotik.com/thedude
              • KOMK Offline
                KOM
                Nope but I am familiar with The Dude.  No, this was like a tiny little executable that didn't even have an installer.  PingCheck or CheckPing or HostCheck or something like that.  I don't know why I ever lost it in the first place.  Very handy, small, simple, effective.
                  MontTech
                  Interesting.  Something like that could come in handy.  Let me know if you find it.
                  • KOMK Offline
                    KOM
                    I found it.  While it didn't have all the features that I thought it did, I made do.  It's called CheckHost and you can find it here:
                    http://www.ab-tools.com/de/software/checkhost/
                    I had to run the crapware installer in a VM to avoid contamination, but then it was easy to get just the program files and move them to my real machine.  For sound alerts, I also grabbed NirCmd from NirSoft and have it use the speak function to have a pleasant Englishwoman tell me my connection is down.
                      MontTech
                      Cool!  Thanks for the lead.  ;D
                      • KOMK Offline
                        KOM
                        For each host I'm checking (4 in my case), I created a batch file in the same folder as CheckHost with these contents:
                        C:\Users\KOM\Software\NirCmd\nircmd.exe speak text "Google is not responding" 0 100
                        and save it as Google.bat.  Create other batch files to handle other hosts.  In CheckHost, I have an entry for Google DNS (8.8.8.8) and when down, I use Google.bat as the Start Program action.
