    Installation help required
    24 Posts 7 Posters 10.2k Views
      cmb
      You said you disabled ACPI in the BIOS, but have you disabled it at the boot prompt when the CD starts to boot?
        di66er
        Yes
          di66er
          I have tried again today to get pfsense set up and am still having the same problems. I have been back into the bios and disabled everything except the essentials, I have also started the set up with option 2 ACPI disabled but still hangs at GEO_LABEL. I have downloaded the suggested distro from the link but its still the same.
          From the suggestions I have received I can see the only way forward it a trial and error revamp of the system which is out of the question. I may as well buy a quan wan router as it would be cheaper.
          I would like to thank everyone who has contributed to this thread and although it hasn't help me your suggestions may have helped others.
            wallabybob
            Do you have access to another computer?
            Here's a procedure I have used. I booted the CD and installed to a USB drive (a 2.5inch notebook drive in a USB caddy) which I then connected to the computer on which I actually wanted to run pfSense. I had to configure the BIOS to boot off a "USB Hard Disk" and now it works fine. This sort of thing may get you past the "CD problem". Once you have the software installed you probably won't need to use the CD again for a good while.)
            There are a number of variants, for example:
            • install to a hard drive on the other computer then move the hard drive to the computer on which you had the trouble.
            • install to a USB flash drive, take it to the real target computer, boot it then copy (dd) the USB flash drive to the hard drive on the target computer
