    Dual wan + Failover posible problem with gateway monitor (Dpinger)
    6 Posts 4 Posters 1.5k Views
      Guest
      Hi, my problem is to try dual wan with failover.
      I have 2 Wan conections (different ISP) and one Lan, Is the typical dual wan + failover scenario.
      wan 1 –> dhcp (WAN_DHCP) (use gateway x.x.0.30)
      wan 2 --> static (GW_OPT1) (use gateway x.x.0.29)
      Problem with gateways monitoring images:
      both wans activated:
      https://drive.google.com/file/d/0B8vILEYP4QRPcU9NYnFBVy02WVE/view?usp=sharing
      after deactivate Wan 1:
      https://drive.google.com/file/d/0B8vILEYP4QRPQk1taDNYd0JSMjA/view?usp=sharing
      after reboot Dpinger with Wan 1 deactivate:
      https://drive.google.com/file/d/0B8vILEYP4QRPendPcUQyaUp0TDg/view?usp=sharing
      after activate Wan 1
      https://drive.google.com/file/d/0B8vILEYP4QRPNlhpYUdCTTgtVVk/view?usp=sharing
      at the end deactivate Wan 2:
      https://drive.google.com/file/d/0B8vILEYP4QRPU0s1WXJYc1JiV3M/view?usp=sharing
      As you can see, when I deactivate Wan 2, still online, only get offline when Wan 1 get offline, and when I activated Wan 1 automatically Wan 2 get online even if it is deactivate. This is my problem.
      both gateways have the same Rtt but when I ping separately have different ms, a difference between 10-20ms
      I using VirtualBox with PfSense 2.3-RELEASE (amd64) built on Mon Apr 11 18:10:34 CDT 2016 FreeBSD 10.3-RELEASE
      My gateway group for failover (Packet loss or high latency):
      https://drive.google.com/file/d/0B8vILEYP4QRPbGp4TG1qUHJRZFk/view?usp=sharing
      Lan rule - Firewall:
      https://drive.google.com/file/d/0B8vILEYP4QRPTHdHWUhsakZZX0U/view?usp=sharing
      I also have marked –> System / Advanced / Miscellaneous / LB / Default gateway switching / Enable default gateway switching
      If someone happens the same or a similar problem I would appreciate any possible help.
      Greeting and good morning.
      pdt: Sorry for my bad English!! ;)
        heper
        your failover group has both on TIER1 ==> thats loadbalancing, not failover
        also find it odd that the ip "the last" 2 bytes of your wan interfaces happen to be ending the same. this is unusual if there are 2 isps involved.
        Are you positive that both wan interfaces are on a different subnet & their gateways are not the same?
          Guest
          @heper:
          Right, only I had config one group of gateways for the loadbalancing, now I have two more groups for failover where wan 1 has tier 1 and wan 2 has tier 2 & vice versa and also I add the rules on the firewall.
          Maybe the problem may come from the subnet settings.
          I have both Wans in the same subnet x.x.0.1/24
          Wan 1 use dhcp with gateway x.x.0.30 and Wan 2 only use static ips in a little range into the same subnet with gateway x.x.0.29.
            azekiel
            So two network interfaces with the same subnet.
            Fail.
              grandrivers
              need to change x.x.y.x change y not the last x
              pfsense plus 25.03 super micro A1SRM-2558F
              C2558 32gig ECC  60gig SSD
                Guest
                I will try to change and reconfig my network and I will try again with pfsense.
                Thanks to all! :)
