    2 lan routing issue
    22 Posts 4 Posters 3.6k Views
      "It does not show a MAC for the 192.168.1.1 adapter, now that is odd, it shows others in the other ranges."
      Huh???
      Why are we talking about this…  This is 2 seconds to trouble shoot..
      This is your network??  See attached..  Are you plugging em0 and em1 into the same switch?  You have different switches?
      Can devices on each network ping pfsense IP in that network?  Is that IP of pfsense set as their default gateway?  Your saying device on network A can not ping device on B, but B can ping A?
      Why don't you sniff on pfsense and validate your traffic is sent to the client your trying to get to..  Does that client answer back?  Your firewall rules for lan1 and lan2 look open..  So either you have client firewall blocking the traffic.  Or a wrong mask, or wrong gateway, etc..  Or your your trying to run different L3 or over the same L2 and have some sort of async issue going on?
      So please state how these networks are connect to pfsense, and what devices are connected to in each network.  And what the clients settings are.. You mention another dhcp server - sure its handing out the right gateway??
      This is quite often a local firewall issue.. Clients not allowing traffic from other than the local network.
      yournetwork.png_thumb
        deanot
        Thanks for the reply, but i resolved the issues with a reload of pfsense.
        PFSense System Specs.
        Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
        4 CPUs: 1 package(s) x 4 core(s) 4 port HP Branded Intel Ethernet Card
